NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628 mm² and 28,300 million transistors. Unlike the fully unlocked GeForce RTX 3090 Ti, which uses the same GPU but has all 10752 shaders enabled, NVIDIA has disabled some shading units on the GeForce RTX 3080 to reach the product's target shader count. It features 8704 shading units, 272 texture mapping units, and 96 ROPs. Also included are 272 tensor cores which help improve the speed of machine learning applications. The card also has 68 raytracing acceleration cores. NVIDIA has paired 10 GB GDDR6X memory with the GeForce RTX 3080, which are connected using a 320-bit memory interface. The GPU is operating at a frequency of 1440 MHz, which can be boosted up to 1710 MHz, memory is running at 1188 MHz (19 Gbps effective).
Being a dual-slot card, the NVIDIA GeForce RTX 3080 draws power from 1x 12-pin power connector, with power draw rated at 320 W maximum. Display outputs include: 1x HDMI 2.1, 3x DisplayPort 1.4a. GeForce RTX 3080 is connected to the rest of the system using a PCI-Express 4.0 x16 interface. The card's dimensions are 285 mm x 112 mm x 40 mm, and it features a dual-slot cooling solution.
The GeForce RTX 3090 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3090. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628 mm² and 28,300 million transistors. Unlike the fully unlocked GeForce RTX 3090 Ti, which uses the same GPU but has all 10752 shaders enabled, NVIDIA has disabled some shading units on the GeForce RTX 3090 to reach the product's target shader count. It features 10496 shading units, 328 texture mapping units, and 112 ROPs. Also included are 328 tensor cores which help improve the speed of machine learning applications. The card also has 82 raytracing acceleration cores. NVIDIA has paired 24 GB GDDR6X memory with the GeForce RTX 3090, which are connected using a 384-bit memory interface. The GPU is operating at a frequency of 1395 MHz, which can be boosted up to 1695 MHz, memory is running at 1219 MHz (19.5 Gbps effective).
Being a triple-slot card, the NVIDIA GeForce RTX 3090 draws power from 1x 12-pin power connector, with power draw rated at 350 W maximum. Display outputs include: 1x HDMI 2.1, 3x DisplayPort 1.4a. GeForce RTX 3090 is connected to the rest of the system using a PCI-Express 4.0 x16 interface. The card's dimensions are 336 mm x 140 mm x 61 mm, and it features a triple-slot cooling solution.
RTX3080
RTX3090
RTX3080Ti
RTX3090Ti
RTX3080
RTX3090
RTX3080Ti
RTX3090Ti
- Asus_ROG-STRIX-RTX3080-10G-GAMING-2I3S_CG132BS3_MIC_r1.00X60YV0FA0-VG0A02.fz (176.2 KB, 777 views)
- Asus_TUF-RTX3090-24G-2I3S_CG132P_MIC_r1.01X60YV0FD0-VG0A02.fz (185.0 KB, 556 views)
- Colorful_BATTLEAX_RTX3080_GA102BC-E11_BoardView_PDF.pdf (2.06 MB, 2217 views)
- Gigabyte GV-N3080AORUS M-10GD Rev1.01 Boardview(tvw).tvw (23.04 MB, 508 views)
- Gigabyte GV-N3080AORUS_M-10GD_Rev_1.01_BoardView.tvw (23.04 MB, 370 views)
- Asus_TUF-RTX3090-24G-GAMING_GA102_CG132P_Rev_1.01X_BoardView_PDF.pdf (1.42 MB, 484 views)
- MSI GeForce RTX3080 MS-V389 Rev2.0 Boardview(CAD).cad (8.45 MB, 442 views)
- MSI GeForce RTX3080 MS-V389 Rev2.1 Boardview(CAD).cad (8.47 MB, 480 views)
- MSI GeForce RTX3080 MS-V389 Rev5.0 Boardview(CAD).cad (8.56 MB, 375 views)
- MSI GeForce RTX3080 MS-V389 Rev1.0 Boardview(CAD).cad (8.57 MB, 319 views)
- MSI GeForce RTX3080 MS-V389 Rev6.2 Boardview(CAD).cad (8.72 MB, 312 views)
- MSI GeForce RTX3080 MS-V389 Rev6.1 Boardview(CAD).cad (8.71 MB, 310 views)
- MSI GeForce RTX3080 MS-V389 Rev1.1 Boardview(CAD).cad (8.84 MB, 284 views)
- MSI GeForce RTX3080 MS-V389 Rev1.2 Boardview(CAD).cad (8.81 MB, 344 views)
- 3080 Founders Edition 600-1G133-0030-900_PG133-A03_Rev_A.pdf (2.09 MB, 399 views)
- NVIDIA_GeForce_RTX_3090_600-1G132-0030-300_PG132-A02_Rev_C_.pdf (1.95 MB, 408 views)
- Gigabyte GV-N3090EAGLE OC-24GD Rev1.0 Boardview(tvw).tvw (23.49 MB, 342 views)
- Gigabyte GV-N3090EAGLE_OC-24GD_Rev_1.0_BoardView.tvw (23.49 MB, 272 views)
- Gigabyte GV-N3090EAGLE_OC-24GD_Rev_1.0_BoardView1.tvw (23.49 MB, 234 views)
- Gigabyte_GV-N3080AORUS_X-10GD_PG132-A02_Rev_1.0_.pdf (1.61 MB, 351 views)
- Gigabyte_GV-N3090AORUS_X-24GD_GA102_DT_Rev_1.01_.pdf (1.91 MB, 289 views)
- Gigabyte_GV-N3080AORUSX_W-10GD_PG132-A02_Rev_1.0_.pdf (1.91 MB, 293 views)
- Gigabyte_GV-N3090AORUS_X-24GD_GA102_DT_Rev_1.01_-1.pdf (1.91 MB, 246 views)
