Does FB mean fuse also?
  • Nama
    • May 2009
    • 127
    I have a board with fb01 fb02 fb03 ect. Fuse?
    ^Learning to walk on rice paper without leaving a trace,
  • NxB
    • Feb 2009
    • 1595
    Re: Does FB mean fuse also?
    Does it have continuity or a burn mark? Probably an smd fuse.
    • Nama
      • May 2009
      • 127
      here is a picture
      • NxB
        • Feb 2009
        • 1595
        All fuses.
        • Nama
          • May 2009
          • 127
          awesome thank you!
          • Wizard
            • Mar 2008
            • 2296
            Whoa!
            Dark grey SMD of this type are ferrite that has physical characteriscs that filters DC of (blocks) noise and is NOT a fuse. And does not have a marking on it to state the fuse current rating. Like a letter, or a number even a number with "A" on the end.
            Have to be careful with the location marks. I have seen different markings like FSxxx, etc, CV, QV etc, even TVxxx lately that could mean anything for component locations (transistor, resistors, diode etc).
            Cheers, Wizard
            • Nama
              • May 2009
              • 127
              thanks. I got it working with out touching them.
              • NxB
                • Feb 2009
                • 1595
                http://www.garrettelec.com/div_detai...ite%20bead.cfm
                Like these? I stand corrected. They had continuity so I ASSumed.
                • Bobdee
                  • Jun 2008
                  • 461
                  Just curiosity but do Motherboards have fuses, Anyone
                  Thanks in advance
                  bob
                  • shadow
                    • Feb 2007
                    • 732
                    I do not know about all the fuses on a motherboard. However I do know any half decent board will have fuses on the USB interface. However some of the cheaper boards do not have fuses and some just use a jumper instead of a fuse.
                    • Wizard
                      • Mar 2008
                      • 2296
                      USB usually have fuse of some types, two types actually. One that is thermal resettable fuses that opens up when it get too much current. Remove current and cools off, conductivity restored. Cheap boards had one time fuse that blows and you are SOL.
                      The crummiest boards have none and is dangerous to have (insurance adverse and fire hazard).
                      Cheers, Wizard
                      • Harvey
                        • Apr 2007
                        • 264
                        USB is supposed to be current limited - you shouldn't need a fuse at all.
                        Of course, very few chipsets have USB that actually adhere to standards....
                        • corrize
                          A funny fuse story – Lumix LX100 II
                          by corrize
                          Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                          I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                          The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                          There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                          And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                          10-19-2023, 09:58 AM
                        • jesterace
                          Samsung UE46ES8000 Blown fuse but no other signs of short
                          by jesterace
                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                          09-11-2024, 03:14 PM
                        • howardc64
                          Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                          by howardc64
                          Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                          • Backlight on, no image
                          • Disconnect right buffer board (view from front), left side display comes on
                          • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                          • Buffer board is pretty simple
                          Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                          07-11-2025, 04:04 PM
                        • jmandawg
                          samsung ln46d630 power supply fuse blown and burn mark
                          by jmandawg
                          picked up this curb alert TV. Looks like the fuse is blown, i don't have a fuse to replace is with, is it safe to short with something just to test it? There is also a burn mark in the white glue near a transistor so maybe the transistor is gone as well. Attached is a picture with the burn circled as well as the fuse that is blown.
                          Board is labeled as: BN44-00463A
                          What's my next best steps?
                          Thanks....
                          07-05-2020, 03:10 PM
                        • jshhh
                          Help replacing fuse on my Mimaki CJV300-160 vinyl printer
                          by jshhh
                          Hi guys,
                          I'm inexperienced with electronics repairs, I've done a little bit of soldering caps and whatnot, but i have a blown fuse on this mimaki printer I got which I have bought a replacement for.
                          How do I remove this type of fuse (see picture)...it kinda looks like it would pull out of that bracket but it didn't come at first pull and I didn't want to brute force it incase it's soldered on there like most of the rest of the components.
                          Anybody know how to remove this type of fuse?
                          (The fuse is toward the bottom of the image labeled F2)...
                          06-17-2025, 01:35 AM
