No boot now!
  • Toasty
    • Jul 2007
    • 4171
    Re: No boot now!
    Yes, I did. 40 pin vs 40 wire. He was/is having a frustrating time of it. I simply want(ed) confirmation by looking at the pictures.
    @370forlife-
    Do you have a know working HD with an OS that you can swap in temporarily to test this? Just a HD, no CD.
    veritas odium parit
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      Re: No boot now!
      I am completely baffled by this motherboard. It is completely fine in the bios, but as soon as it gets past post and tries to boot, it completely freezes up.
      Anyone have any suggestions, because it is not the IDE cables, and not to the power supply either. I think it might need a new bios, but you have to update it from one of the worst medias ever created...floppy, and of course it dosen't boot so you can't boot off the floppy to update the bios.
      • Harvey
        • Apr 2007
        • 264
        Re: No boot now!
        Originally posted by sofTest
        If on separate cables, your HD should be set to master and connected to the middle of the cable, and the DVD as slave connected to the and of the cable. This is how it should work. If you run into trouble, try connecting the DVD to the end of the cable with the HD, as a slave.
        I dunno where you got that from as I was always told and have read that the master goes on the end of the cable with slave in the middle.. although in practice it makes no difference.
        However, if you have only one drive connected to a cable, it should be on the END of the cable, as otherwise you have a length of cable unterminated.
        • Harvey
          • Apr 2007
          • 264
          Re: No boot now!
          I assume you've tried it with JUST the floppy connected, set to the correct size in the bios, and a Bootable floppy in the drive [and a CMOS clear just for good luck] ?
          hit <esc> to boot...
          reminds me of the GRUB boot sequence...
            master hoarder
            • May 2008
            • 12175
            Re: No boot now!
            Agreed. I have 2 different cables in front of me atm, 1x 80-pin and 1x 40-pin from an HP PC. Both are labled "Master" at the end plug and "Slave" in the middle.
            However, I too believe that it shouldn't make a difference as long as the jumpers are set correctly. In that case, they should override cable setting.
            370 - have you tried booting with the CD in another system? Maybe the program you used does not support burning bootable CDs.
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              Re: No boot now!
              used imgburn with a legitimate windows xp pro 64bit iso downloaded from microsoft MSDN (my brother has a subscription through his company,) imgburn is what I used to burn my server 2003 disk, and that worked on my other server.
              • Harvey
                • Apr 2007
                • 264
                #27
                Re: No boot now!
                Is this the same board as in your other threads - the X6DAL-G?
                If so, then I'd guess the countdown is coming from the RAID controller. Disabling it and/or the SATA ports might help.
                • Logistics
                  • Apr 2007
                  • 721
                  Re: No boot now!
                  Originally posted by Toasty
                  40 wire should be used on the CD as it is not recommended to use 80 wire.
                  Enjoy running your UltraDMA-capable optical drive in PIO mode.
                  I've had motherboards that didn't want to boot from the CD unless I set ALL the boot devices to CD-ROM so it could not argue with me. Was this tried?
                  • Toasty
                    • Jul 2007
                    • 4171
                    #29
                    Re: No boot now!
                    "recommended" is the key word there. Up until now.
                    He's not talking about using new drives here. It's not a new system. We had to pry the info out as to what cable(s) he was/is using.
                    Maybe we should have a form to fill out before you start a topic. You'd need to describe exactly and precisely what equipment and all the nuances of same before you can begin the thread. Then we can start crucifying people when they make an error or mis-statement.
                    ~She's a witch! She's a witch~
                    Whatcha think?
                    Toast
                    veritas odium parit
                    • Logistics
                      • Apr 2007
                      • 721
                      Re: No boot now!
                      First... I would have to have a basis for believing that there is something bad about using an 80-wire cable for any device on the IDE channel. As I recall it, the only difference is that the 80-wire has several more ground wires in-between the data wires to prevent cross-talk.
                      So what is the reason for not recommending running an 80-wire cable on older PIO-only devices?
                      • Toasty
                        • Jul 2007
                        • 4171
                        #31
                        Re: No boot now!
                        Arrrgh! My brain hurts. Ahhhhh... much better...
                        Sorry if I sounded a bit gruff there. Just my nature. Seems like I've had my junk jumped on in this thread and others in the past few days.
                        It did/does depend on the mobo and how the secondary port was wired. Some would not work with the 80 wire, only with the 40. The CD Freaks forums for a long time recommended it. Now their tune is changing as the newer mobo's are making both channels 80 wire compatible.
                        There were problems that the CD/CD-R/DVD drives connected to the secondary IDE port on the mobo would not be recognized or would respond poorly using the 80 wire cable. I had the experience personally with several systems, and just got used to doing it that way. My ASUS P5AD2-E from 3 years ago, came with the 80 wire for the primary and 40 wire for the secondary.
                        If it was on the primary port, the the 80 was not a problem. Except, hooking the optical to the same channel as the hard drive can/does kill system I/O performance.
                        The X6DAL manual says both channels are ATA-100, so the 80 wire should work here.
                        Toast
                        veritas odium parit
                        • privato89
                          Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
                          by privato89
                          I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
                          Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
                          Let's begin:
                          Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
                          03-26-2024, 06:37 AM
                        • Luke Anders
                          Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
                          by Luke Anders
                          A few details about the laptop itself:
                          Name: Lenovo Legion 5
                          Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
                          BIOS Version: GKCN60WW
                          EC Version: GKEC65WW
                          Serial Number: PF39AQ7Z
                          Board Model: NM-D562 Rev 3.0
                          RAM: 16GB Installed, DDR4 (brand new)
                          NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
                          I bought this laptop recently from eBay as a faulty device....
                          10-12-2024, 05:13 AM
                        • hinisa
                          Xiaomi router freezes at boot after re-capping
                          by hinisa
                          I'm using Xiaomi Router 4A gigabit edition as wireless repeater. It worked fine for 2 years or so, but last week, wireless started to disappear.
                          When I unplug/replug the power, it was working fine for a day/half a day or so until it freezes again.
                          After testing with different power supply adapters and concluding it wasn't the issue I finally opened the case and this was the situation:
                          Anyway I proceed to clean up the mess and replace all caps but unfortunately it made the situation worse. Now router can't even boot, either it freezes during...
                          07-08-2023, 05:58 AM
                        • NolesFan
                          Samsung un82ru88000f - Boot loop sort of but can correct with taping of LVDS ribbon
                          by NolesFan
                          Hello all... TV started boot looping. Opened the back panel and tried to isolate the problem. Just PSB no boot loop. PSB and MB no boot loop. Plug in the LVDS from panel to MB and boot looping starts up. It doesnt matter of order that I plug the LVDS ribbons back in, only 1 and no boot loop but as soon as 2nd one plugs in boot looping. I then noticed a flicker on the screen when I was closing the clip on the harness to the LVDS. Shut the lights off so I can see better, and I noticed as i slowly close it, I will get a picture, but as soon as it clips in, I lose picture and booting happens. So I...
                          10-24-2024, 06:36 PM
                        • praveenramavath
                          Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                          by praveenramavath
                          Hello All,
                          I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                          https://www.hifivision.com/threads/m...-screen.98243/
                          Troubleshooting Summary: Majority Internet Radio - Flash Chip
                          04-26-2025, 09:08 AM
