Corsair K70 RGB dead
  • alindumitru46
    • Aug 2015
    • 255
    • Romania
    In new times, new problems . It is understandable here, being a forum dedicated to repairs.
    So my problem is with one Corsair K70 that I received from my brother-in-law.
    Initially it started normally but after installing the Corsair software it started to trouble: keyboard lock, computer lock, restarts and finally dead...
    I opened it and I found that there were a lot of coffee grounds
    I thoroughly cleaned with a brush and isopropyl alcohol and re-assembled.
    After 3 attempts to start, it was not recognized by any computer.
    I tried to research but I did not have a chance, so I appeal to your guidance and advice.
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    • Romania
    Re: Corsair K70 RGB dead
    Tried checking the PCB(s) where the USB comes from? Coffee might've shorted something.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
    • Sparkey55
      • Jan 2010
      • 1523
      Are you sure it was coffee grounds? Cockroach feces look like coffee grounds too.
      • alindumitru46
        • Aug 2015
        • 255
        • Romania
        Mehhhh...Nevermind....
        I just said I cleaned with isopropyl alcohol. Right now I'll upload some pictures.
        LE: little troubles with uploading...
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          Maybe start by checking wires between USB connector and keyboard's PCB. Then, when plugged into a USB port, make sure the keyboard is getting a steady 5V supply.
          • alindumitru46
            • Aug 2015
            • 255
            • Romania
            Yep, the voltage is 5V at the terminals on the keyboard pcb, unfortunately I studied too little the NXP LPC11U3X datasheet to check the voltages.
            Besides, I do not have so thin terminals to risk measuring pins.
            And there would be a VRM, or something like that ...
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              If the power and data lines are okay, then next check the input and output voltages of that SOT-223 voltage regulator.
              If good, I would take the entire PCB out and give it a good wash with soap (dish detergent) and water. The let it dry completely and try the keyboard again.
              • alindumitru46
                • Aug 2015
                • 255
                • Romania
                I would have wanted to sink the keyboard into such a solution and let it take some time to act on it, but I thought there might be some lubricant inside the contacts and it would be dissolved.
                • alindumitru46
                  • Aug 2015
                  • 255
                  • Romania
                  Last night late, tired and in a hurry, I checked the VRM. It's a typically L1117S33 .
                  The measurements was made with both USB cables (keyboard and RGB) connected to the computer and the sockets on the keyboard's PCB.
                  The voltage on the input pin is ~ 5.1V, but the output voltage on the output pin quick tends to zero.
                  Hardly unpleasant ...
                  Is it relevant to measure the voltages only with the keyboard cable, ie without the RGB cable connected? Could there be any additional clue?
                  What happened and how do you explain that such a solid VRM can creep so easily?!
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    Yes, should be fine, unless the RGB backlight cable has some type of feedback (which I seriously doubt).
                    It could be that there is something shorted on the output of that voltage regulator or it could also be that the regulator went bad (rarely happens, but not impossible).
                    If there is anything shorted on the regulator's output (you should check resistance from the regulator's output to ground with your multimeter), I would most likely suspect a shorted ceramic capacitor somewhere. Reason being is because ceramic capacitors like to become short-circuited when flexed or vibrated too much - something that isn't too hard to do on a keyboard PCB (think about all that slapping and hitting the PCB takes as buttons are pressed).
                    So if you do identify that there is a short-circuit on the regulator's output (I would say any resistance of less than 50 Ohms is certainly suspect), you should check the resistance of ALL the ceramic capacitors on the board. The ones that appear shorted should be removed until the shorted one is found (tedious annoying process, I know :\ ).
                    • alindumitru46
                      • Aug 2015
                      • 255
                      • Romania
                      Thank you @momaka, I'll try to check today all this.
                      Yesterday I searched for a VRM L1117 and found a LD1117ST C413 but I'm not sure that it covers the minimum requirements for the replacement part.
                      • alindumitru46
                        • Aug 2015
                        • 255
                        • Romania
                        0.857 kOhms is the resistance value of the voltage regulator from output to ground.
                        Capacitor values are here, but nothing under 850 Ohms.
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          Sounds like there is nothing shorted then and possibly only the regulator is bad. If you have a small breadboard, you can pull the 1117 regulator out, solder some leads to it, and built a basic circuit on the breadboard to test it.
                          Well, if your regulator really is a L1117S33 as you stated in post #9 above, then you need a 3.3V *fixed* voltage regulator. Technically, you could adjust an adjustable one to output 3.3V or "tweak" the circuit for a 1.8V fixed 1117 regulator... but for a direct replacement, find a 1117 with a fixed 3.3V output (usually you will see it labeled as 1117....33). As for the current rating - as long as it's in the same package (looks like SOT-223), it should be okay. Most 1117 regulators have a standard rating of 800 mA of current. You can also use a TO-252 part if that's all you can find and don't mind a small "bodge job" on the PCB. (Been there, done that... got a 19" LCD monitor working fine again ).
                          • alindumitru46
                            • Aug 2015
                            • 255
                            • Romania
                            So why I was afraid, I did not escape ... To desolder that regulator from there is too much for me, that's why I did not insist too much. I'm trying to use the hot air station, but I have not worked for a while with it, and I'm afraid of destroying the pcb.
                            And the candy on the alms: one of my old monitors died; I'm going to post the problem with him too.
                            Thank you, again.
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              No need for hot air then.
                              Just use two irons. One should preferably be rated for 50 Watts or more. The other 30-50W is fine. Flood the pins of the regulator with leaded solder with the more powerful iron. Then, heat the tab of the regulator with the bigger iron and use the smaller iron to alternate between heating the 3 leads of the regulator. Once all the solder melts, just slide the regulator away from its spot elsewhere on the PCB (looks like towards one of the white connectors is the best way to go). This is usually the tricky part, as there are other small SMD components around, and you have to be a bit more careful around those. But all in all, it's not too difficult. Maybe practice on another board for your first try. I thought of this method by myself way back when I still couldn't solder too well, and I was successful right from the first time without destroying anything. Of course, I practiced on a dead board first.
                              • alindumitru46
                                • Aug 2015
                                • 255
                                • Romania
                                I know, you told me this from the first posts, about 2 years ago
                                • alindumitru46
                                  • Aug 2015
                                  • 255
                                  • Romania
                                  Hi there,
                                  After many, too many days, when I did not get to the place where I have my little workshop, I had a way up there today and I got my heart on my teeth and I replaced that vrm. Very easy, just with 1 iron and a lot of flux.
                                  Because I kept some of the experience gained over time, I managed to desolder but also the soldering almost perfect. I cleaned with IPA at the end.
                                  I put that one ST LD1117 C413 because I did not have another one ready.
                                  The voltage measured after that on pin 2 is Vout=5.07V and on pin 3 Vin=1.343V
                                  Still not working and no lights .
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    That's not right.
                                    Your V_out pin cannot measure higher voltage than your V_in pin. Either you're measuring something incorrectly, or there is something very wrong with the circuit. Try re-taking those measurements again, and make sure you are measuring the correct pins.
                                    Also, like I mentioned in post #13 above, you cannot use any 1117 regulator you like - it has to be one with a *fixed* 3.3V output. If you use a regular adjustable 1117, then you have to add a resistor network on the ADJ pin to set the output voltage at 3.3V. Otherwise, it's not going to work.
                                    • alindumitru46
                                      • Aug 2015
                                      • 255
                                      • Romania
                                      I wrote the message from my cell phone and I tangled Vin with Vout. And I could not even correct it.
                                      I actually realized that you are right about using another type of vrm, different from the specified one.
                                      It's hard to find quickly that vrm with a fixed 3.3V Vout. I await the moment when someone to make an order to put that vrm, which nevertheless has an insignificant cost of $0.45.
                                        master hoarder
                                        • May 2008
                                        • 12175
                                        • Bulgaria
                                        Well, if the replacement 1117 regulator you have now is an adjustable one or fixed for 1.8V, you can turn it into a 3.3V regulator with a few small resistors. A picture of it would help to see what it is.
                                        • quicknick
                                          Dead Corsair TX650M
                                          by quicknick
                                          PSU is made in late 2019 and seems barely used judging by the lack of dust on its innards.
                                          +5Vsb is all right, grounding PS_on results in a relay clicking and nothing more, all outputs dead without even a flinch.
                                          Checked inside, at first glance all seemed ok but then noticed something on the primary heatsink, which I promptly removed along with all its attached devices - there were clear signs of insulation breakdown above the C3D04060 diode. The device was overtightened from factory and the tab squished the sil-pad, it all was a matter of time,...
                                          10-09-2024, 02:52 PM
                                        • Andreasbest
                                          Dell Precision 7510 Coffee Damage. Daughterboard dead.
                                          by Andreasbest
                                          Hello!
                                          Today i received a 7510 with coffee damage.
                                          Keyboard is dead and replaced but i indicate a problem on left daughterboard.
                                          It's completely dead.
                                          Tried with 2 more boards that i have from a donor 7510 but no luck, no response at all.
                                          Neither USB or HDMI.
                                          Any thoughts?
                                          Schematics and boardview attach....
                                          07-04-2022, 09:23 AM
                                        • zunasthegreat
                                          Chieftec GPS-450-AA with dead 20N60C3
                                          by zunasthegreat
                                          Hello everyone hope all doing well!
                                          I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                          09-01-2024, 07:12 PM
                                        • Beton
                                          Finding a dead short component
                                          by Beton
                                          Hi guys!
                                          I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                          So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                          I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                          I have a bench PSU and if I try to inject voltage the voltage...
                                          12-10-2021, 01:05 PM
                                        • FiguringITout
                                          MSI Raider GE75 - Not posting, probable dead CPU
                                          by FiguringITout
                                          Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                          Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                          07-25-2024, 07:27 AM
