Corsair K70 RGB dead
  • lh0yd
    • Jun 2021
    • Argentina
    #41
    Re: Corsair K70 RGB dead
    Sorry for the delay,
    Is not the same USB HUB but is actually pretty similar to yours.
    I don't really know much about electronics so if you do something please let me now so i can fix mine too hahaha. Thanks !
    • double_DD
      Transformer replacement for a dead coffee machine
      by double_DD
      Hi guys,
      I have a dead coffee machine, and it seems that the culprit (no 1, at least) is a dead trafo - primary coil seems to be blown open (type shown on the picture below).
      Now, I'm unable to find direct replacement anywhere on ebay or aliexpress, and all similar that I' was able to find are rated too low (<1A).
      If someone knows a shop to buy replacement (EU/CH), that would of course be my 1st option.
      My other ideas:
      - to buy 220/20Vac trafo with 30VA, and to "manually" create secondary 12V output just via resistor
      - to buy...
      06-23-2025, 05:43 AM
    • quicknick
      Dead Corsair TX650M
      by quicknick
      PSU is made in late 2019 and seems barely used judging by the lack of dust on its innards.
      +5Vsb is all right, grounding PS_on results in a relay clicking and nothing more, all outputs dead without even a flinch.
      Checked inside, at first glance all seemed ok but then noticed something on the primary heatsink, which I promptly removed along with all its attached devices - there were clear signs of insulation breakdown above the C3D04060 diode. The device was overtightened from factory and the tab squished the sil-pad, it all was a matter of time,...
      10-09-2024, 02:52 PM
    • Andreasbest
      Dell Precision 7510 Coffee Damage. Daughterboard dead.
      by Andreasbest
      Hello!
      Today i received a 7510 with coffee damage.
      Keyboard is dead and replaced but i indicate a problem on left daughterboard.
      It's completely dead.
      Tried with 2 more boards that i have from a donor 7510 but no luck, no response at all.
      Neither USB or HDMI.
      Any thoughts?
      Schematics and boardview attach....
      07-04-2022, 09:23 AM
    • double_DD
      How can I be sure that my EC chip is dead?
      by double_DD
      As the title suggests, how can I be sure that my EC chip is really dead?
      I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
      Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
      03-12-2025, 07:47 AM
    • h0m3w0rk
      Random Shutdowns/Startup Failure with Corsair SFX 450
      by h0m3w0rk
      I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
      For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
      02-09-2025, 03:19 AM
