Which processor would be faster
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    I'm currently running a P4 prescott 541 3.2ghz with hyperthreading disabled. 200mhz bus, 1mb l2 cache.
    I have, new in box, a Pentium e2180 2ghz dual core, 200mhz bus, 1mb l2
    Would the dual-core get me a faster PC, assuming my motherboard will support it?
    Ludicrous gibs!
  • UraBahn
    Scrapheap Hound
    • Nov 2004
    • 165
    Re: Which processor would be faster
    The pentium dual-core e2180 will blast that prescott to smithereens even though the p4 has a higher clock speed. It'll also run much cooler and eat alot less power. (65W TDP in the e2180 vs. 84W for the Prescott AFAIK).
    Just be sure your motherboard supports the e2180.
    The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
    I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      The E2180 is based on Core architecture.
      [Derived from Pentium M,, Derived from Tualatin]
      The P4 is based on NetBurst architecture.
      A 2Ghz single core Core architecture chip would probably give a single core 3.2Ghz NetBurst architecture chip a run for it's money.
      - A dual core would kick it's ass.
      Mann-Made Global Warming.
      - Dr Seuss
      • dood
        Deputy dood
        • Mar 2004
        • 2462
        Hmm... this board is from a Gateway e-4300 PC. It's an Intel D915GUX, obviously with the 915 chipset.
        http://www.intel.com/products/chipsets/915g/index.htm
        They only state support for Pentium 4. Since this processor is built off the Pentium architecture, and not the Core architecture, it should work, right?
        Ludicrous gibs!
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          Verified what PCBonez stated above... it does appear to be off the Core architecture. The question still remains whether it will work in this board or not. And, if I try it, does it have the potential to kill the processor? I just got this back from an Intel RMA.
          Ludicrous gibs!
          • dood
            Deputy dood
            • Mar 2004
            • 2462
            According to a thread on Toms Hardware, the 915 only supports the netburst processors. No e2180 for me
            Ludicrous gibs!
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Won't work in that board.
              http://support.intel.com/support/mot.../CS-026954.htm
              - Dr Seuss
              • dood
                Deputy dood
                • Mar 2004
                • 2462
                Cheaper to buy a board that supports the e2180 than it is to get a better P4 - guess I'll wait a bit for my upgrade. At least my RAM and video card will switch over without a problem.
                Ludicrous gibs!
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  I'm in the process of trying to cycle out most of my old Netburst based stuff right now.
                  Low level stuff (thin clients/NAS) are going to Tualatin or Pentium M.
                  High level (servers) are going to dual core Xeon with Core architecture.
                  Old servers are 2x single core Netburst.
                  New servers will be 1x dual core 'Core'.
                  One well chosen dual core 'Core' based Xeon beats the dual CPU Netburst setups I have in performance and the CPU's use less than 1/2 the power.
                  [2 x 85to110w] vs [1 x 65w] - Same number of cores in systems.
                  I'm ready to go with first server except the blasted CPU's aren't here yet. - ARGGG!
                  - Dr Seuss
                  • 370forlife
                    Large Marge
                    • Aug 2008
                    • 3113
                    A dual core has so much advantages over a dual processor. My AMD athlon 64x2 5000+ 2.6ghz dual core blows my dual 3.06ghz xeon prestonias out of the water, (5000+ has 2 64K L1's, 2 512K L2's, Each prestonia has a 8K L1, and 2 512K L2's,) not to mention the prestonia's have only a 533mhz bus, but have hyper-threading (4 virtual cores,) while the athlon has a 2000mhz HT bus, and no Hyper-threading.
                    • gdement
                      • Jan 2007
                      • 690
                      There shouldn't be any inherent advantage vs dual separate CPUs, other than maybe being more power efficient (not sure about that either). But the newer Core architecture is certainly faster than the P4's.
                      The only real advantage seems to be a contrived one. I discovered recently that Microsoft supports dual-core processors on XP Home, but not dual physically separate CPUs. Seems like a stupid and arbitrary distinction to me. My parents have a dual P3 Intellistation (bought used by my advice vs a then-new eMachines), and are now stuck with win2k unless they want to shell out for Pro edition or give away the use of a processor.
                      If they had a dual-core modern chip then home edition would be enough.
                      • acstech
                        GrumpyModerator
                        • Jul 2007
                        • 1432
                        I built a computer for a guy using an E2180. Works alright when at 2.0GHz.
                        When you run it at 3.2GHz though, it flies! And it will do that on stock voltage. Now obviously not all of them do this, but we set his at 400FSB with an 8x multiplier, memory at 1:1. Night and day difference.
                        Ask if you need board recommendations.
                        A man convinced against his will is of the same opinion still.
                        • Wizard
                          • Mar 2008
                          • 2296
                          I wasn't aware how much of a gap between netburst and this C2D. Thanks for that. I'm happy now that I really skipped P4 straight from socket 462 athlons from 1GHz, 1.33GHz then couple barton cores. Now Pentium Duo (E2200 had that as main pc then cpu went on to new server at my work and E5200 currently in my machine).
                          Cheers, Wizard
                          • dood
                            Deputy dood
                            • Mar 2004
                            • 2462
                            I always disable hyper threading on my single-core Pentiums. Some of the games I run will actually perform slower with hyper threading. It's still only a single core, so why even bother?
                            This prescott does run blazingly hot. Right now, I'm idling at 54C, albeit with the fan running at slow speed (temperature controlled). When it's at 100% load in games, it usually runs around 65C, with the fan running full bore. Plus it sucks down the juice like no tomorrow. My PSU fan kicks up, and if I'm playing for a long time, the PSU case will get quite warm to the touch (I only have 300 watter).
                            Dual core has a big advantage over dual processor... the direct pathways to the rest of the system. With two separate sockets, there's an inherent delay in getting the signals back and forth.
                            I'll probably hang on to this dual-core Pentium and get a decent board for it. acstech- I'd be interested in hearing your board recommendations. I've heard these e2180's overclock quite well on average.
                            Ludicrous gibs!
                            • acstech
                              GrumpyModerator
                              • Jul 2007
                              • 1432
                              If you don't want integrated video:
                              http://www.newegg.com/Product/Produc...82E16813138122
                              Or the open box version:
                              http://www.newegg.com/Product/Produc...2E16813138122R
                              You'll need to make sure your drives, video card, etc, will work.
                              The P45 based boards go much higher on the FSB, but the P43 board linked above, from what I hear, tops out around 420 which is more than you need anyway. The board I used in the computer from the last post was a TP35D2-A7.
                              I like these Biostar boards for the fan speed control, overclocking ability, and general stability. They do use some OST caps, not in the CPU voltage regulator area though. It's not a problem in a reasonably well cooled computer.
                              I guess my shopping list would be:
                              1. The board linked above.
                              2. Memory: http://www.newegg.com/Product/Produc...82E16820227371
                              3. Heatsink: http://www.newegg.com/Product/Produc...82E16835233014
                              And maybe a SATA hard drive, and video card, of your choice. Depends on what you have now.
                              Good luck!
                              • dood
                                Deputy dood
                                • Mar 2004
                                • 2462
                                Good luck!
                                I current have 2x SATA 3.0 hard drives, 1x PATA hard drive, and 1x SATA DVD burner. I have an artic cooling PWM controlled heatsink, artic silver 5 thermal paste, and OCZ DDR2 memory (not sure what speed). I'm currently running a geforce 8600gt, which should be sufficient. Really, all I'd need is the motherboard.
                                Ludicrous gibs!
                                • acstech
                                  GrumpyModerator
                                  • Jul 2007
                                  • 1432
                                  Well there you go! I figured I'd cover it all, just in case.
                                  • KeriJane
                                    Mac Enthusiast
                                    • Sep 2008
                                    • 681
                                    Hi dood
                                    Ummm... what about the availability of dual dual channel memory for a total of quad-channel memory for us dual-CPU system users?
                                    Not to mention that some dual CPU systems (like this Mac Pro) are dual dual-core and some are dual quad-core.
                                    When I added some memory to this thing I went from 2 DIMMs/1GB in dual channel to 4 DIMMS/8GB in quad channel. It made a large difference in speed and system responsiveness. Putting the original memory in added 1GB for a total of 9GB, but knocked it back down to dual channel mode and really killed the performance. One has to use 4 or 8 slots for best effect it seems.
                                    Having to buy XP Pro.... Oh well. It wasn't THAT much extra. I'm just glad I found out about Home's single-socket limitation BEFORE I bought it.
                                    Have Fun!
                                    Keri
                                    The More You Learn The Less You Know!
                                    • bgavin
                                      • Jan 2007
                                      • 1355
                                      Pay attention to your Front Side Bus first.
                                      This is where the work gets done. When the processor issues a data request, it enters WAIT until the bus is clear. A faster processor simply WAITS faster on the bus. Most applications are I/O bound, compared to processor bound. If you are doing scientific calculations that do little referencing to memory, the fastest process makes more sense.
                                      If a compromise is in order, buy the slowest processor with the fastest FSB. Intel makes their big markup $$ on the incremental processor speeds. You can plot a simple Excel sheet graph with GHz vs. $$$ and it will be readily apparent.
                                      The next attention item is the memory performance.
                                      It is worth your while to take the fastest memory throughput you can afford.
                                      Buy matched pairs so you can take advantage of the Dual Channel memory controller built into all modern boards. This is Free Speed.
                                      A benchmark such as Everest Ultimate will show you detailed performance comparisons of various processor speeds and memory configurations.
                                      After you have optimal hardware, you can tweak off the unnecessary eye candy and B.S. services. This will gain you about 23mb in recovered system memory, and an untold number of free CPU cycles. You can feel the difference in both startup time, and performance. I do this for laptops used for digital recording stations.
                                      Pick an antivirus that does not consume your machine.
                                      I have yet to find one... I use McAfee Enterprise on my client machines, but it is a huge RAM hog. I've seen it eat 100~200mb during a session. I really like this AV, but the resource consumption is damn annoying.
                                      • jpdoe
                                        • May 2007
                                        • 237
                                        nod32 v2.7 used to be great regarding RAM use.
                                        nod32 v3 changed that, but it's nowhere near 100MB
                                        I hate the way Windows loads services. There's no easy way to pinpoint which service is hogging memory.
                                        All I could find was the WinXP
                                        tasklist /svc
                                        command, or it's Win2k equivalent:
                                        tlist /svc
                                        They show which service is loaded into each svchost.exe
                                        But most of the services are always loaded by only one svchost.exe, and when you see it hogging RAM you can't determine which service is the culprit.
                                        So you have to disable several services at once to solve the problem. And two months later, when an application doesn't behave correctly, you better remember which services you disabled, or you'll have a new problem in your hands.
                                        • Joho
                                          HP PRODESK 600 G2 DESKTOP MINI starting, no picture, fan only spinning faster and faster
                                          by Joho
                                          Hi there, I've got a HP Prodesk 600 G2 Mini on my bench, that turns on but no picture.
                                          Model: HP ProDesk 600 G2 Desktop Mini
                                          Product No: Y3J22EC#ABD
                                          BID=15WWP3ET6**#SABD#DABD
                                          Serial: CZC632BBCJ
                                          First I thought maybe BIOS got corrupted. Someone sent my corrected BIOS that I flashed. Now symptoms are: Mini starts when power is plugged in, Fan turns on and gets faster and faster until it's at 100%. Nothing gets excessibly hot.
                                          When I desolder the BIOS chip I get Beep codes / LED codes "BIOS is missing"
                                          Without CPU I get "CPU...
                                          03-07-2025, 09:18 AM
                                          ACER Veriton Veriton L460 Veriton E2180 Specification for Upgrade or Repair
                                          This specification for the ACER Veriton Veriton L460 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton Veriton L460 boardview and Veriton Veriton L460 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:36 PM
                                        • harp
                                          simple win network with optimization issue
                                          by harp
                                          simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
                                          06-23-2025, 11:01 AM
                                        • DrvLikHell
                                          Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
                                          by DrvLikHell
                                          Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
                                          The...
                                          02-05-2025, 01:44 AM
                                        • bigbeark
                                          MX-Linux 19.1 - Freaking Fast!
                                          by bigbeark
                                          Finally got around to loading this OS to a couple of old boxes.
                                          First, an ASUS P5GV-MX with a 3.2G 32-bit Prescott HT CPU and 4 sticks of 512MB OCZ Dual Channel PC3200 Ram, using the Onboard Intel graphics. Board uses Intel 915 chipset.
                                          Boots and loads really fast, about twice as fast as Linux Mint. Video performance much improved, no stutter. This is on a 24 inch monitor at full resolution, but the youtube window size is smaller.
                                          Threw a couple of messages on startup "microcode 7" went by so fast I couldn't take it in.
                                          Second a Tyan...
                                          05-15-2020, 11:15 AM
