Which processor would be faster
  • bgavin
    • Jan 2007
    • 1355
    Re: Which processor would be faster
    Link to EMSI Software
    Their free version is a comprehensive process explorer for both visible and hidden processes. Note the section for Tricky Startups.
    This software leaves behind a running process after it exits.
    Uninstall after you are done with it.
    • RJARRRPCGP
      • Jul 2004
      • 6304
      My E2180 is OC'ed to 2.9 Ghz. (363x8.0) (on an Asus P5QL Pro, in the sig)
      But my system, when not at the default multiplier and RAM-to-FSB ratio, the majority of apps report 3.6 Ghz! LOL!
      So far, CPU-Z is the only app that's confirmed to report the right processor frequency.
      ASRock B550 PG Velocita
      Ryzen 9 "Vermeer" 5900X
      Arc A770 16 GB
      eVGA Supernova G3 750W
      Alienware AW3423DWF OLED
      • acstech
        GrumpyModerator
        • Jul 2007
        • 1432
        That happens a lot. It's not just the Asus. My Biostar boards do it too. I think they just look at the maximum multiplier and multiply it by the current FSB.
        Dood, you make any progress yet? Get the board yet?
        A man convinced against his will is of the same opinion still.
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          Haven't ordered anything yet. I'm going to have to get the mobo, a new PSU, and new RAM to make the change. It all adds up to about $180, so I'm going to sit on that for a bit and see what happens with my bills this month.
          Ludicrous gibs!
          • Joho
            HP PRODESK 600 G2 DESKTOP MINI starting, no picture, fan only spinning faster and faster
            by Joho
            Hi there, I've got a HP Prodesk 600 G2 Mini on my bench, that turns on but no picture.
            Model: HP ProDesk 600 G2 Desktop Mini
            Product No: Y3J22EC#ABD
            BID=15WWP3ET6**#SABD#DABD
            Serial: CZC632BBCJ
            First I thought maybe BIOS got corrupted. Someone sent my corrected BIOS that I flashed. Now symptoms are: Mini starts when power is plugged in, Fan turns on and gets faster and faster until it's at 100%. Nothing gets excessibly hot.
            When I desolder the BIOS chip I get Beep codes / LED codes "BIOS is missing"
            Without CPU I get "CPU...
            03-07-2025, 09:18 AM
            ACER Veriton Veriton L460 Veriton E2180 Specification for Upgrade or Repair
            This specification for the ACER Veriton Veriton L460 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Veriton Veriton L460 boardview and Veriton Veriton L460 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-12-2024, 03:36 PM
          • harp
            simple win network with optimization issue
            by harp
            simple win network with optimization issue I like to ask some question about configuring simple room win network. So, there is 2 win computer, android4 device and wifi router not connected to internet. The purpose is storage space and manipulation with large files between any device. 1 pc - 192.168.0.2 (winxp sp2) wired to router port#1 2 pc - 192.168.0.5 (win10, enabled smb1.1) wired to router port#2 3 router - 192.168.0.1 with dhcp for wifi (192.168.0.101...) 4 main tablet - 192.168.0.101 (android4) wified to router wifi port I generally work and control transfer with my tablet via ES3 file...
            06-23-2025, 11:01 AM
          • DrvLikHell
            Sharp (Hisense) LC-55p6050u - Flashing/dimming row of pixels
            by DrvLikHell
            Hello again! I have come back for some wisdom and hopefully for some guidance with this problem I'm having. The TV is a 4k 55" Sharp LC-55p6050u and the problem is every other line of the bottom 32 lines flickers out, comes mostly back, then flickers out again, and repeats this continually. The lines on the bottom right of the screen go out completely while the lines on the bottom left are affected so slightly that it's almost impossible to see it. There is a gradual gradient from appearing almost perfectly fine on the bottom left, to an obvious problem on the bottom right.
            The...
            02-05-2025, 01:44 AM
          • bigbeark
            MX-Linux 19.1 - Freaking Fast!
            by bigbeark
            Finally got around to loading this OS to a couple of old boxes.
            First, an ASUS P5GV-MX with a 3.2G 32-bit Prescott HT CPU and 4 sticks of 512MB OCZ Dual Channel PC3200 Ram, using the Onboard Intel graphics. Board uses Intel 915 chipset.
            Boots and loads really fast, about twice as fast as Linux Mint. Video performance much improved, no stutter. This is on a 24 inch monitor at full resolution, but the youtube window size is smaller.
            Threw a couple of messages on startup "microcode 7" went by so fast I couldn't take it in.
            Second a Tyan...
            05-15-2020, 11:15 AM
