now thats a capacitor
  • pflowers
    • Jan 2009
    • 36
    I've seen some posts on here that refer to a "beer can" capacitor.....and when I do I have to chuckle......I work on some thermal transfer printers that have the mother of all capacitors in them 12000uf (not 1200) 63v 35mm in dia. and 50mm in length......now thats a beer can
    Paul
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: now thats a capacitor
    I don't recall the uF but I've seen similar in the PSU for old Laserjet 4 series.
    They are usually Rubycon too.
    Industrial caps can actually be as big as 55 gallon drums.
    Mann-Made Global Warming.
    - Dr Seuss
    • KeriJane
      Mac Enthusiast
      • Sep 2008
      • 681
      Hi Pflowers!
      Why not stop by your local Best Buy?
      They carry 1 Farad capacitors in the car audio section. I saw them when I was looking for a new car radio. They have that "I am an extremely dangerous capacitor" look about them.
      http://www.bestbuy.com/site/olspage....=1172880157454
      Have fun,
      Watch out for the Killer Caps!
      Keri
      The More You Learn The Less You Know!
      • c_hegge
        • Sep 2009
        • 5219
        Imagine putting one of them in the fire! BANG!
        • larrymoencurly
          • Oct 2004
          • 960
          I heard that the Large Hadron Coillider at CERN broke down because of Fuhjyyu caps.
          • weirdlookinguy
            • Sep 2007
            • 1638
            Lol, LHC.
            I wonder if all the doomsday stuff they say about it is true.
            • washu
              • Jul 2009
              • 310
              Many years ago I used to work for an organization which got donations of old computer junk which was fixed up for schools. Quite often we would get odd stuff that really wasn't useful like old 14" hard drives and dedicated WP stations. Usualy we would tear them down for scrap and keep anything interesting. Often the power supplies were linear designs with huge caps in them. Got several "beer can" caps out of them from 50,000 to 500,000 (not a typo) uf. Usually under 20 V rating.
              • MORETTIGIAN
                by MORETTIGIAN
                Title:
                Description:
                Procedure performed:
                - Removed backplate
                - Reapplied thermal compound
                - Reassembled card
                09-18-2025, 12:14 PM
              • Prolog
                by Prolog
                12-01-2024, 08:27 PM
              • chth96
                by chth96
                12-22-2023, 04:34 AM
              • chth96
                by chth96
                06-02-2024, 07:31 PM
              • chth96
                Is it no harm to replace with capacitor without ripple current rating?
                by chth96
                When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
                Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
                But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
                Rubycon YK DataSheet (b...
                04-19-2024, 05:19 AM
