Bsod!!!!
  • Junk Parts
    Court Jester
    • Jun 2006
    • 8953
    Bsod!!!!
    I was just on the net and got a windows protection BSOD. After this the pig wouldn't boot past the BIOS start screen. I knocked her apart and reseated everything then it booted again. I have not had a BSOD in maybe years! Whats going on here Mates!
    Mark Twain
    John Paul Jones
    Rod Serling
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: Bsod!!!!
    It happens.
    I'd start by checking the voltage out of the power supply and checking for bad caps. Then I'd run memtest. Then run an antivirus scan. After that, run chkdsk /f. Then, run a stability test such as Prime 95 for a minimum of 24 hours. One of those ought to find it.
    I don't know what good reseating would do, if everything was connected right to begin with. But since it worked, I would suspect that something was getting hot, and the time spent reseating it let it cool off. Check fans for dust buildup and functionality.
    A man convinced against his will is of the same opinion still.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: Bsod!!!!
      give some info about the hardware and age
      imho any incident is going to become a bigger incident later which is why i never deliver a build with one error cos they always come back later
      • i4004
        • Oct 2006
        • 2029
        Re: Bsod!!!!
        well, what was the bdos?
        what did it say?
        you have extensive list on aumha
        http://www.aumha.org/errors.htm
        you can also use windows debugging tools, but let's hope that's not needed...if it's tough you'll send minudump and i'll take a look....
        oh yeah, you can also take a look at even viewer under administartive tools(in control panel)
        if it only happens while on the web, then you look at network interface...
        • zandrax
          Hit and miss
          • Dec 2007
          • 1157
          • Italy
          Re: Bsod!!!!
          @ Junk: bsods happen for a reason, be it a voltage transient or an hardware issue. Pity you didn't note down the error message, it could have been useful.
          However check the hardware: open the psu (if out of warranty), check caps on the motherboard, clean ram contacts and dust on heatsinks, clear the coms then test the computer according to acstech's instructions.
          You may even update the network card driver if you suspect it's a network related error, however if doesn't happen again then it's temporary so don't worry too much.
          Zandrax
          Have an happy life.
          • Junk Parts
            Court Jester
            • Jun 2006
            • 8953
            Re: Bsod!!!!
            Sorry guys but I'm not as good as you. When I saw it saying it stopped windows to protect the system I hit the power buttom and dumped everything. The warning did seem to concern a memory address but I could be wrong.
            Mark Twain
            John Paul Jones
            Rod Serling
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Re: Bsod!!!!
              Just post the minidump file here if you want to know
              it's in c:\windows\minidump
              • Junk Parts
                Court Jester
                • Jun 2006
                • 8953
                Re: Bsod!!!!
                Per Hansson I would like to know what the error means but I can't find the c:\ windows\minidump file. Could this file be called something other than Minidump? This PC is a Dell Dimension 4550, and is running the Dell version of Xp Home that shipped with it.
                Mark Twain
                John Paul Jones
                Rod Serling
                • Junk Parts
                  Court Jester
                  • Jun 2006
                  • 8953
                  Re: Bsod!!!!
                  Its fixed! I ran Prime95 for a few hours, and got no errors. I then cracked the case and wiggled things a bit. As soon as I touched one of the Ram sticks I got a BSOD. As it turns out, this stick of Ram has no markings on it so I don't know who made it. It seems to be just a little thinner than the Dell stick, and is loose in the slot. I grabbed the other stick out of the busted Dell which is a Dell stick and put it in this one. Now I can wiggle it and I don't get any BSOD's.
                  Mark Twain
                  John Paul Jones
                  Rod Serling
                  • i4004
                    • Oct 2006
                    • 2029
                    Re: Bsod!!!!
                    good call.
                    it always easier to fix hardware first and then to take the software path, if needed...
                    • Junk Parts
                      Court Jester
                      • Jun 2006
                      • 8953
                      Re: Bsod!!!!
                      Found the sticker that was on the bad ram. I used Westley's Tire white to clean the old one up, and I guess it ate the glue up. It reads as follows:
                      Advance Modules
                      AM256D08A3C-PC2700 32M X 64 DDR
                      S33715 256MB,333MHz,CL2.5
                      Mark Twain
                      John Paul Jones
                      Rod Serling
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        Re: Bsod!!!!
                        Advance Modules
                        advance modules=trash with no customer support.break in half and shitcan.
                        50%doa rate on several orders a friend made.why he ordered a second and third time is beyond me.
                        • guyandpit
                          Asus tuf fa507r BSOD
                          by guyandpit
                          Hi there! Need help! its been 2 months finding the cause of BSOD ntoskrnl and other error, this has water damaged before no power, i replaced sio and pwm control for gpu and cpu. It will boot 3 times in BSOD before succesfully boot in windows. I done stress on cpu, gpu and ram no errors found. Any opinion guys with same exprience? Thank you see attached bsod error
                          05-09-2025, 11:46 PM
                        • alambrose
                          LG GRAM random bsod SOLVED
                          by alambrose
                          LG Gram 15Z980 picked up on Ebay for $200 (was sold as parts because no M2 drive and bios pw locked), but otherwise intact and working.
                          Threw a 500gb M2 in, and was able to install Windows. On Gram, Win activation is stored in the bios, so Windows was automatically activated. I still kept getting random bsod's. Also bought a pw and unlocked the bios.
                          Upgraded Windows to 11, still didn't solve the random & frequent bsod's. Cleaned & reseated all cables, RAM, etc... still getting frequent bsod's. Bought & installed a new stick of RAM, still getting frequent...
                          02-12-2023, 06:12 PM
                        • alleotechno
                          HP Omen RTX2060 BSOD while nothing presure on CPU
                          by alleotechno
                          Details:
                          Model : Omen HP Laptop 15-DH0038TX
                          Serial Num : CND93433LW
                          Product ID : 7LJ89PA#UUF
                          Bios Version : AMI F.53 4/24/2024 (8600)
                          Laptop Input Voltage : 19.5Vdc | 10.3a
                          My Adapter Charger : Original HP 200Watt 19.5V | 10.3a
                          My laptop keep on blue screen after 10 second successfully windows loaded, BSOD while installing new windows and cannot windows update, if update ask me to perform to restart and the laptop will BSOD while installing the update.
                          The blue screen comes after nothing stress/pressures my CPU not GPU. I need to use...
                          02-04-2025, 10:37 PM
                        • the Benninger
                          Vostro 14 3468 w BSOD KernelPower aleatory
                          by the Benninger
                          HI Folks, I have a problem randomly a BSOD screen appears in the event viewer indicates KernelPower failure, discard the source/memory and SSD, only the battery is in bad condition, it will be possible that the battery is causing this BSOD event , I mention it because the times he gave BSOD he happened to have the battery installed, and last Friday it ran all day without the battery installed and didn't generate any events
                          At the moment I am checking the mosfets and voltges in general everything seems to be perfect on the main board
                          Vostro 14 3468
                          CPU: Core...
                          04-29-2024, 08:54 AM
                        • Nikolai Danylchyk
                          Lenovo T480s usb-c charging port replacement - Knocked off a couple of diodes.
                          by Nikolai Danylchyk
                          Hi folks. As the title says, I was doing a port replacement on a Lenovo Thinkpad T480s and in the process of post-solder cleaning, I somehow knocked off 2 or 3 diodes (i think they are diodes) near the main usb-c. I can't seem to find what kind of a diode is that. I know it's ultra tiny and just has a letter "G" on it. Would someone maybe have a proper schematic for the t480s model? I can only find the non-s one and it's quite different to the "s". Would love to figure out what component that is.
                          Thanks in advance!...
                          05-08-2025, 06:18 AM
