What can I use to copy a system disk
  • travistee
    • Sep 2008
    • 68
    I want to copy a disk with the os already installed.
    Is there anything that can do that.
    I tried hdclone. It copied the disk, but it would not boot.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: What can I use to copy a system disk
    Ghost
    • Junk Parts
      Court Jester
      • Jun 2006
      • 8953
      I have never used the progie myself but the shop where I get my "new" junk parts does. I do know that you have to make sure the progie gets the size of the drive being copied to right. Its like if you are copying from a 40 Gig to a new 80 gig sometimes the progie will also format the new larger drive down to the size of the drive being copied.
      "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
      Mark Twain
      "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
      John Paul Jones
      There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
      Rod Serling
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        ghost or acronis
        you will have a choice whether to increase the size of the partition(s) to the new size of the disk
        • gustie
          • Dec 2008
          • 76
          acronis is good apps
          DFI Lanparty NF2 Ultra B
          TICTAC 619XT Bios
          AMD Athlon XP-M 2600+ FQQ4C IDYHA I-Stepping
          Speeze Vulture spin 3 Heatsink and Fan
          2x Mushkin XP4000 1024m DDR500 (1:1) @ 2.5-3-2-8 1T
          GeForce FX 5700 256m
          Zalman VF900 CU GPU cooler
          Skyhawk 400W Aluminium psu
          Sharkoon Silent Eagle 1000 case fans
          • travistee
            • Sep 2008
            • 68
            easeus works fine.
            copied system disk and it booted.
            free
            • DynaxSC
              ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
              by DynaxSC
              I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
              Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
              Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
              The behaviour is also really very strange, i.e.:
              • The disk shows always up in BIOS - so it is recognized, so far so good
              • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
              02-23-2025, 01:33 PM
            • reformatt
              Intel iMacs, 3rd party SSD failures and Fusion setups
              by reformatt
              I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
              As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
              So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
              12-18-2024, 10:34 PM
            • welp
              PS5 Disk Tray issues.
              by welp
              I have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
              Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
              Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
              So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
              With that knowledge I preceded to check all the fuses for the 12v rail on the main...
              12-19-2024, 02:04 PM
              Copy DMI info easily with Hex editing software and Macro script
              by SMDFlea
              Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
              Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
              02-28-2023, 02:14 PM
            • madura2010
              DAY11AM6E0 hard disk drive and optical disk drive not detected
              by madura2010
              Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
              i checked the connectivity of ribbon=good communication with hard and motherboard
              changed hard disk and checked=3f0 error persist
              sata power=+5v available
              Then checked data capacitors=all good
              Then checked data lines path connectivity to pch=all good
              reflashed...
              03-12-2023, 09:09 AM
