M-Audio Audiophile2496 soundcard help
  • gustie
    • Dec 2008
    • 76
    Hi
    i run this soundcard in my PC for low latency MIDI and overall studio quality sound...
    24-bit/96kHz digital sound....
    http://www.maudio.co.uk/products/en_...phile2496.html
    My friend got an external midi/soundcard so i was lucky enough to get a spare audiophile2496 from him...
    I read that you can run upto FOUR of these soundcards to add further midi devices and share the load across the cards DSP chip
    PROBLEM....
    runs with one card in BUT if both are installed my PC wont boot! totally annoying
    anyone got any ideas? it could be an IRQ problem maybe??
    i have no idea how to solve this.....
    any help will be great!
    DFI Lanparty NF2 Ultra B
    TICTAC 619XT Bios
    AMD Athlon XP-M 2600+ FQQ4C IDYHA I-Stepping
    Speeze Vulture spin 3 Heatsink and Fan
    2x Mushkin XP4000 1024m DDR500 (1:1) @ 2.5-3-2-8 1T
    GeForce FX 5700 256m
    Zalman VF900 CU GPU cooler
    Skyhawk 400W Aluminium psu
    Sharkoon Silent Eagle 1000 case fans
  • PM650
    • Dec 2008
    • 37
    Re: M-Audio Audiophile2496 soundcard help
    Do the cards work ok individually?
    If so, try switching slots, but there really shouldn't be an irq issue if these are the only pci cards in there, unless there's something in the bios causing conflicts with irqs.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      http://www.maudio.co.uk/index.php?do...c9e1f292fcb135
      Mann-Made Global Warming.
      - Dr Seuss
      • gustie
        • Dec 2008
        • 76
        thanks guys
        I have tried both cards individually - both are fully functional
        i do have a PCI usb card underneath - i could loose that i guess, i only put it in as it was lying about....
        looks like i need one card as master and the rest need to sync in to work...
        looks like i might have to buy a S/PDIF cable to do this???
        if need be i can open the bios and list the IRQ's.... what is the most items you should see on ONE IRQ? i think i seen 3 or 4 on one!
        cheers
        TICTAC 619XT Bios
        • PM650
          • Dec 2008
          • 37
          Perhaps you could better explain 'PC wont boot'? Does it start at all, or lock up on windows loading/start up?
          • gustie
            • Dec 2008
            • 76
            oh yes.... i should have mentioned that
            it will POST then try to load windows then it will reboot itself before the windows progress bar splash appears and will loop like this
            TICTAC 619XT Bios
            • gustie
              • Dec 2008
              • 76
              strange..
              i got emailed willawake posted a reply here....
              icome to look but there isnt one here?
              eh??
              TICTAC 619XT Bios
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Web Gremlins ???
                - Dr Seuss
                • gustie
                  • Dec 2008
                  • 76
                  looks like!!
                  TICTAC 619XT Bios
                  • PM650
                    • Dec 2008
                    • 37
                    Is there any way you can boot into safe mode (F8) before it reboots?
                    • gustie
                      • Dec 2008
                      • 76
                      Hi PM650 - i guess i could slap the card back in and try that using F8..
                      ill see if i can do that and get back on that one
                      ta
                      TICTAC 619XT Bios
                      • zombie.guitarist
                        Reading Serial Midi data with an oscilloscope
                        by zombie.guitarist
                        Hey all, I have one last thing I'm looking to fix with my Synthaxe. This time, the schematics I have are actually the same as the PCBs I have.
                        The Synthaxe, works as its a guitar midi controller hooked up to a floor pedal. Thats the most basic way of using it, and it has a midi output. You also can connect a console to it, that stores your tunings and other things. The console has 8 midi outs, as well as a midi in and midi thru.
                        When I first got the unit, I thought I was using it wrong, but it turns out its just broken. The 8 midi ports on the console don't output...
                        07-05-2023, 09:29 AM
                      • zombie.guitarist
                        Synthaxe Midi Controller footswitch
                        by zombie.guitarist
                        Hey all! I have this midi controller called a "Synthaxe" which is pretty rare. It was made around 1986 and the company only made about 100. I was told less than 25 still work today. Theres a guitar player I love that is known for using this and to play his material you basically need one of them because it does things no other midi-guitar controller can do. So since I got it, ive been trying to learn about it so I can extend its live as long as possible.
                        The one that I bought has 2 issues. One I'll cover another time but I think this one is easier and simpler to fix....
                        06-25-2023, 12:06 PM
                      • paparazzo79
                        sound card dead after graphics card installation
                        by paparazzo79
                        Hi guys.I own Z690 F Strix board in one of my PCs....everything was working fine with integrated graphics card.I turned off power from it, installed graphics card from another PC, connected all the peripheral cables, optical sound cable of course when everything was switched off.Then I powered on the machine and integrated soundcard is dead.How did this manage to happen and if there is a way to diagnose and replace damaged component?
                        The new pci-e soundcard costs here 80 euros which is half of money I spent on motherboard.
                        I still can not believe that I am such a looser and don't know...
                        07-23-2024, 12:22 PM
                      • falcontech
                        Denon Mc6000 channel 1 completely non-functional
                        by falcontech
                        Hello
                        I need your help with a non-functioning channel on this Denon controller. I noticed the problem because, with the mixing software, the channel appears completely off and none of its controls work. At the top of the channel, like the others, there's a selector switch that moves between MIDI and external audio inputs. I also tried connecting an audio source (since it's also a standalone mixer) and I got no input. The flat cable connecting this panel to the sound card is fine. I'm attaching a photo and the service manual. I hope someone can help me resolve the issue. Thanks....
                        09-04-2025, 09:03 AM
                        DELL Precision T5810 Precision E5-1620V3 Specification for Upgrade or Repair
                        This specification for the DELL Precision T5810 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Precision T5810 boardview and Precision T5810 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                        09-12-2024, 03:44 PM
