M-Audio Audiophile2496 soundcard help
    Hi
    i run this soundcard in my PC for low latency MIDI and overall studio quality sound...
    24-bit/96kHz digital sound....
    http://www.maudio.co.uk/products/en_...phile2496.html
    My friend got an external midi/soundcard so i was lucky enough to get a spare audiophile2496 from him...
    I read that you can run upto FOUR of these soundcards to add further midi devices and share the load across the cards DSP chip
    PROBLEM....
    runs with one card in BUT if both are installed my PC wont boot! totally annoying
    anyone got any ideas? it could be an IRQ problem maybe??
    i have no idea how to solve this.....
    any help will be great!
    DFI Lanparty NF2 Ultra B
    TICTAC 619XT Bios
    AMD Athlon XP-M 2600+ FQQ4C IDYHA I-Stepping
    Speeze Vulture spin 3 Heatsink and Fan
    2x Mushkin XP4000 1024m DDR500 (1:1) @ 2.5-3-2-8 1T
    GeForce FX 5700 256m
    Zalman VF900 CU GPU cooler
    Skyhawk 400W Aluminium psu
    Sharkoon Silent Eagle 1000 case fans
    Re: M-Audio Audiophile2496 soundcard help
    Do the cards work ok individually?
    If so, try switching slots, but there really shouldn't be an irq issue if these are the only pci cards in there, unless there's something in the bios causing conflicts with irqs.
      http://www.maudio.co.uk/index.php?do...c9e1f292fcb135
      Mann-Made Global Warming.
      - Dr Seuss
        thanks guys
        I have tried both cards individually - both are fully functional
        i do have a PCI usb card underneath - i could loose that i guess, i only put it in as it was lying about....
        looks like i need one card as master and the rest need to sync in to work...
        looks like i might have to buy a S/PDIF cable to do this???
        if need be i can open the bios and list the IRQ's.... what is the most items you should see on ONE IRQ? i think i seen 3 or 4 on one!
        cheers
        TICTAC 619XT Bios
          Perhaps you could better explain 'PC wont boot'? Does it start at all, or lock up on windows loading/start up?
            oh yes.... i should have mentioned that
            it will POST then try to load windows then it will reboot itself before the windows progress bar splash appears and will loop like this
            TICTAC 619XT Bios
              strange..
              i got emailed willawake posted a reply here....
              icome to look but there isnt one here?
              eh??
              TICTAC 619XT Bios
                Web Gremlins ???
                - Dr Seuss
                  looks like!!
                  TICTAC 619XT Bios
                    Is there any way you can boot into safe mode (F8) before it reboots?
                      Hi PM650 - i guess i could slap the card back in and try that using F8..
                      ill see if i can do that and get back on that one
                      ta
                      TICTAC 619XT Bios
