So.... How do I work this??
  • stevo1210
    • Oct 2006
    • 4156
    My uncle gave me a Quantum Altas V, 3.5 series hard drive earlier this year and I have no idea how to work the thing whatsoever. It is a SCSI hard drive, utilising the 68 pin SCSI interface. I have an Adaptec AHA-2940 SCSI controller and also a 68 pin SCSI cable that has 2 connectors. Do I need a terminator as well? because my friends told me that the SCSI controller I have auto terminates unplugged connections or something like that?
    And I don't even know what size this hard drive is, but it has marking on the top saying 36.7L. Does this mean it is a 36.7GB hard drive or something like that?
    So how exactly do I work this hard drive? and do I need a terminator?
    Thanks.
  • stevo1210
    • Oct 2006
    • 4156
    Re: So.... How do I work this??
    Also found a sticker near the power connector saying "Ultra 160/LVD/SE" what does that mean? Is it relevant to anything?
    Thanks.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      this card a bit slow for u160
      The Atlas IV, Atlas V, Atlas 10K, Atlas 10K II, and Atlas 10K III drives are Ultra160 Multi-Mode LVD devices and do not support onboard termination. It is recommended that a 68-pin twisted pair SCSI cable with a LVD/SE multi-mode terminator be used.
      might need to terminate with that card though
      • Wizard
        • Mar 2008
        • 2296
        LVD means low voltage diffenertial SCSI. Not compatible with consumer and pro-consumer stuff. LVD is usually used on high end stuff. See if this drive have a jumper that change LVD or HVD modes?
        What is needed is 5V aka HVD high voltage SCSI Diff or wide SCSI 68 pin.
        Cheers, Wizard
        • pentium
          • Mar 2006
          • 2778
          -Snippage-
          Didn't read the last post.
          Find Nedry!
          Check the Vending machines!!
          • Wizard
            • Mar 2008
            • 2296
            Oh, one more, this is 7200rpm drive. SATA 320GB for 55 locally will kick it's butt all over
            and doesn't cost you anything more because you do not have controller for that drive orphan.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              you need a 2940W card or newer.w means wide.uw ultra wide.u2w is lvd80
              lvd drives will fall back to se and 40mb rate.
              • stevo1210
                • Oct 2006
                • 4156
                After digging around my shelves, I found this SCSI controller .... kinda repaired it a while ago, used it once or twice and then stored it away on a shelf.
                It's an Adaptec 2940UW and works perfectly without an issue for as far as I know. So is this controller card compatible with the hard drive my uncle gave me? I dunno, but he also gave me that AHA-2940UW controller and it was the only one he had, so I presume it has to be for this SCSI hard drive.
                Thanks.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  yes.
                  now all you need is a 68 pin cable and a terminator.
                  • stevo1210
                    • Oct 2006
                    • 4156
                    I have a 68 pin cable here already, so is this the terminator I need?
                    http://cgi.ebay.com.au/FOXCONN-68-PI...3286.m63.l1177
                    I dunno, it's a Foxconn one and supports the 68 pin interface and also has LVD support?
                    Thanks.
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      Because the drive seems to be LVD (Low Voltage Differential), but SE (Single Ended) capable, chances are it does not have an inbuilt terminator option
                      LVD drives normally need a SCSI cable with a terminator on the end
                      You'll need to find a manual for the specific drive, and see if there's a jumper labelled TE (Terminator Enable) or equivalent
                      Given you sort out termination, it should work with an Adaptec 2940UW, but limited to the adapter's 40mbps maximum, rather than the drive's 160mbps
                      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                      • pfrcom
                        Oldbie
                        • Jun 2006
                        • 1230
                        A cable like this would do, and suitable for the future, if you got a faster controller
                        LVD SCSI cable with terminator
                        • stevo1210
                          • Oct 2006
                          • 4156
                          Today I went to an E-waste recycling place and I bought a 68 pin LVD SCSI cable that had a terminator attached at the end. I haven't tried it out yet, but I bought two cables just in case and I will try it out tomorrow.
                          Better yet, the cable and terminator as well only cost me $1AU and they are in pristine condition as well.
                          Thanks.
