dell gx110 won't shut down
  • klein
    • Nov 2008
    • 37
    hi
    i have a dell gx110 tower, when you tell xp to shut down it does then it boots right back up buy it's self. the only way to shut it down is to pull the power cord between shutting down and reboot, has anyone came across this before? i also have two hp sff that so the same thing, all three computers run fine they just won't shut down with the switch or xp lol
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Re: dell gx110 won't shut down
    Sounds like the "wake-on-LAN" function. Does it stay off if you unplug the cat cable?
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • madmax_2069
      • Nov 2008
      • 27
      i have had this issue, My D530 SFF did that when the bios/cmos pill battery died.
      yea i have ran into my fair share of wake-on-lan fun.
      • klein
        • Nov 2008
        • 37
        update Re: dell gx110 won't shut down
        so after reading these post i unplugged it and walked away and forgot about it lol this machine was a back up xp/win98se so i needed win98 i plunged it back in after 3 or 4 mouths and it booted into the bios, battery went dead, replaced battery and set all my setting in the bios , booted it into xp rebooted in to win98 used it and it shut down normally i never had wol set up on this computer but i think resetting the bios when the battery went dead fixed it lol
        • Bowline
          by Bowline
          06-11-2025, 10:13 AM
        • Akhlz001
          by Akhlz001
          09-20-2025, 07:15 PM
        • master3112
          by master3112
          07-29-2025, 01:55 PM
          Dell Thunderbolt Firmware
          by SMDFlea
          Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
          Some models have a choice of 2 different firmwares, it depends on the dell SKU.
          The SKU is in brackets (****)
          EDIT: NVM65...
          01-26-2025, 06:22 AM
        • dell_sadness
          Dell Latitude 3440 - Service tag ending in 0001 - Locked!
          by dell_sadness
          BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
          Have extracted the BIN and want to know how to rebuild a clean BIOS
          I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
          I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
          Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
          11-12-2025, 02:54 PM
