overheating southbridge/chipset
  • byteexp
    • Oct 2006
    • 10
    no boot/dead board, need help in finding the fault
    motherboard 1 (ecs s754)
    died after finding bulding caps, then no boot
    recapped but had overheating chipset, with power, 2 vrm/mosfet (near cpu socket)has no measure voltage, others are good
    motherboard 2
    automatically turns-on, measured voltage, some caps has voltage measured, while others dont have.
    does torroid coil fail? if yes, what are tell-tale signs
    too hot chipsets?what are possible causes
    what makes board to automatically power on after plugging atx power connectors.
    thanks
  • stretch0069
    Screwed Up Super Moderator
    • Oct 2003
    • 2658
    • oooo ess aaaaaaaaa
    Re: overheating southbridge/chipset
    moved it in here. hopefully someone will be along shortly to answer your questions.
    "Its all about the boom....."
    Guns kill people like spoons made Rosie O'Donnell fat.
    We now return you to your regularly scheduled drinking.
    "Fear accompanies the possibility of death.....calm shepherds its certainty"
    Originally posted by Topcat
    AWD is just training wheels for RWD.
    • stevo1210
      • Oct 2006
      • 4156
      How hot is the chipset we are talking about? Is it so hot that when you put your finger on it, it will burn your finger?
      If that is the case then you might as well throw the board in the bin or use it for parts because the chipset is internally shorted. This is usually caused when you use a no-name PSU (Like a DEER etc.) and overvoltage on the +5VSB or excess ripple current occurs.
      I've had quite a few people bring their PCs in with the same problem. Usually the PSU is a no-name generic one with bad caps which in turn burns the southbridge chipset.
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        I agree; the second more likely cause is a badly installed heatsink (e.g. no thermal paste) or a dust clogged fan on really hot chipsets like nVidia nForce 2, 3 and 4.
        Can you post any detail about the boards? Photos are appreciated.
        Zandrax
        Have an happy life.
        • byteexp
          • Oct 2006
          • 10
          thanks for the reply, 1 board is asrock socket754 with nvidia chipset
          the other one is ecs nforce 3a s754, yes, the chipset is so hot that it will burn your fingers when you try to touch it.
          the other one i think used to have its chipset overheat, but after further testing and i think recapped it again have had the chipset return to normal temp.
          btw. again, thanks for the help
          • bgavin
            • Jan 2007
            • 1355
            If you have a PCI slot unused, you might consider a Rocket cooler.
            Link to Newegg
            I use this for passive cooled video cards (MSI, etc) that run too hot. These coolers are a bargain at $10, and worth the money. On the slow setting, they run quiet and move a good amount of air.
            A side benefit of these, is most Southbridge and numerous Northbridges are also cooled. It comes with a 2nd bracket to allow down draft as well as side draft operation. It has a plastic tang that sticks into an unused PCI slot, but does not draw power... just a locator tang. It bolts in like any PCI card, and uses a Molex power connector.
            • mikail13
              • Aug 2013
              • 93
              • Turkiye
              i have same issue.
              my msi g31m3 board doesn't post. no action...
              only south bridge is overheat.
              the caps around the rem and south bridge they must be 1000 mF is overrated.
              4800 mF or 34 mF..
              after i change i see no effect. South bridge overheats anyway.
              but one mosfet don't the for earlier.
              if i recapp 470 mF? there are 6 caps.
                • 31158
                is it hot enough to burn yourself ?
                because if it is, it's shorted out.
                • Ven
                  Dell Latitude 3510 Overheating & Fan Control Issue – Need Help
                  by Ven
                  Dell Latitude 3510 (Intel Core i7-10510U) CPU Overheating
                  Issue Description:
                  1. CPU Overheating to 100°C
                    • When I start the laptop from a cold state, it takes about a minute to reach temps around 80-90-100°C, and CPU thermal throttling triggers.​
                    • When the CPU fan is running at full speed (by disconnecting PWM and TACH cables), CPU temperature stays around 50-60°C.
                    • However, when the fan is connected normally to the motherboard, it does not kick in at high temperatures.
                    • I also noticed a few times that the fan kicked in for a very short time, but it does not stay on consistently.
                    • Thermal
                  02-12-2025, 03:57 PM
                • qayyum786
                  *Use Full MOST COMMON I.C FOR LAPTOP YOU SHOULD HAVE IN STOCK*
                  by qayyum786
                  *MOST COMMON I.C FOR LAPTOP*
                  *YOU SHOULD HAVE IN STOCK*
                  *Charging IC
                  8682L OZ8682L OZ8682LN QFN-16 Chipset
                  OZ8681LN OZ8681L OZ8681 8681 8681L QFN-16 Chipset
                  ISL88731CHRTZ ISL88731C 88731C QFN-28 Chipset
                  ISL88731HRZ ISL88731QFN-28 Chipset
                  ISL6251AHAZ ISL6251A ISL6251 SOP-24
                  ISL95521HRZ ISL95521 95521HRZ QFN-32 Chipset
                  AXP288 QFN-76
                  AXP288C QFN-76
                  CD3301 CD3301RHHR QFN-36 Chipset
                  CD3301BRHHR CD3301B QFN-36
                  BQ24705
                  BQ24707 BQ707
                  BQ07A BQ24707A QFN-20
                  BQ715 BQ24715 BQ24715RGRR
                  05-26-2020, 06:13 AM
                • DynaxSC
                  Activation of Management Engine after exchange Z590 chipset - ASUS PRIME Z590M-PLUS
                  by DynaxSC
                  Hi, i have an ASUS PRIME Z590M-PLUS board, which had an shorted Z590 chipset. I have succesfully exchanged the chipset to a factory new one, however there is a serious problem with the Intel Management Engine (later on: ME) not beeing activated after the chipset device replacement.
                  For lower chipset families (on ASUS boards) it worked to program the oldest bios version into the SPI rom, and the bios had activated the Management Engine itself by default - there was a message on the screen prior booting - "BIOS is updating Management Engine ..... . Do not shut down to prevent...
                  06-10-2023, 11:30 AM
                • sikocan
                  Lenovo X1 Carbon 9th Gen Black Screen
                  by sikocan
                  I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                  SN: PF3G1REP
                  MODEL: 20KW-00J1AU
                  PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                  Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                  06-24-2025, 09:01 PM
                • Nagyesz
                  Dell inspiron 13 5000 - Doesn't turn on, overheating
                  by Nagyesz
                  I have a Dell laptop with me, a DELL inspiron 13 5379. It doesn't turn on. After some investigation, I found that the charger is delivering 0-3V instead of 19.5V, and this voltage fluctuates constantly. Additionally, two ICs are overheating. I searched for these ICs, and it seems they are likely related to the issue of not having 19V.
                  Should I inject voltage somewhere, or should I replace the ICs right away?
                  So, PU4301 is overheating, and the surrounding area is hot, possibly just because of this IC.
                  07-13-2024, 11:27 AM
