pop-up issue
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: pop-up issue
    Originally posted by zandrax
    @ Pentium: usually zero filling clear the Smart log too, so after the operation the drive would show more "Reallocated sectors" and way less "Unstable sectors", "Uncorrectable sectors", "UDMA CRC Errors" and other bad sector related errors.
    @ Scenic: I have a 3 GB IBM 2.5" drive I don't use anymore: full specs here. If you're interested, send me a PM.
    Zandrax
    Zero Fill does not reset SMART directly.
    SMART is basically a Self Test Program.
    It runs from and results are stored in an IC chip on the drive's PCB.
    If SMART detects no errors (or a lower number of errors) so many times it resets itself to the new value(s).
    If you take a PCB from a drive reporting SMART errors and put it on a good drive it will still report the errors from the old drive a few times until it resets.
    Mann-Made Global Warming.
    - Dr Seuss
    • zandrax
      Hit and miss
      • Dec 2007
      • 1157
      • Italy
      #62
      Re: pop-up issue
      Sorry, I wrote it badly: overwriting the whole disk with zeroes (litteral meaning of "zero filling") doesn't change SMART values, that's right.
      Anyway manifacturer's tools usually clear part of the Smart log before performing a "zero fill": while writing zeros, they check bad sectors one by one and eventually repair (correctable damages) or remap them (uncorrectable ones). I noticed this behaviour with Hitachi's Drive fitness tools and Seagate's Seatools while repairing my drives: I have WD, Samsung and Maxtor disks too but they didn't have bad sectors yet or are too old to support SMART (the 1.2 GB Maxtor ) so I don't check the utilities of these manifacturers.
      Zandrax
      Have an happy life.
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Re: pop-up issue
        A pre 1998 HDD is usually too old to support SMART.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • madmax_2069
          • Nov 2008
          • 27
          #64
          Re: pop-up issue
          i use Avast Pro and man i like it, its always cought bad sites trying to download infected crap (usually from googling around for hard to find pinouts and from casual searches from google) i am so far infection free for like 4 months now. before i used avg and i always got infected eventually.
          i dont know whats up with google lately but its been coming up with a bunch of crap that has nothing to do with what your searching about ( altho the link info on google shows diffrent)
          • Hondaman
            • Sep 2008
            • 1069
            Re: pop-up issue
            I had some trouble recently too. Please research "XP Activation". Something (the "volume label" or "serial number" or something) is also checked for WPA, and it must be the same (or else you get "points" against you toward having to re-activate). The "wpa.whatever" files mentioned earlier are correct, but are not the only part. It should be pretty easy to research this and record the old "volume label" or whatever it is in the correct spot at the beginning of the new disk, using a disk editor (like Norton Utilities 2001's disk editor).
            I am sorry your disk is dying, but I'm grateful for the warning and for every document, spreadsheet, etc. you can remove.
            As for the spyware, here's something I've used repeatedly:
            "Startup Monitor" from www.mlin.net
            Spyware loads every time Windows starts. This program lists every single startup item. Googling from a different computer (or going to spywareinfo dot com or castlecops dot com or whatthetech dot com [formerly TomCoyote] or bleepingcomputer dot com) lets you research suspicious ones.
            Plug the drive in to a different PC* (I prefer linux, you might prefer Windows), delete the bad stuff, and put the drive back in to the "infected" computer. Make sure it is NOT connected to the net.
            * (A 2.5 to 3.5 inch adapter is only about $10 and will let you plug notebook drives into a standard ribbon cable for your desktop motherboard.)
            Start the (desktop) PC. Weird programs (the spyware) will complain that some file cannot be found, but Windows will *_usually_* continue without loading the file in question. IT IS GOOD that the spyware file can't be found. Registry cleaners can now be used (along with Mike Lin's program and programs found at the websites I mentioned above like "Hijack This", "Spyware Search and Destroy", etc.) will help you clean the registry and "suspicious" startup entries.
            PCBONEZ was absolutely right. If you are re-infected each bootup, it is because the "nasties" load each time Windows starts because of their entries in the Windows startup process. Once loaded, they are programmed to reach out across the net to re-download themselves. Disconnecting from the Net like this lets us 'break the chain'.
            Typically I alternate between deleting the bad files and deleting the startup entries with Mike Lin's tool and registry cleaners (Safe mode might work for some of this, but WILL NOT be 100 percent effective**. Put the hard drive in a different PC to do the file deletions). As you go along, all the various tools will become more and more effective.
            ** Windows puts some stuff to be deleted (on next bootup) in the registry, but some spyware intercepts and deletes this info from the registry before rebooting can take place, thus preserving the bad stuff on your PC.
            When you boot the PC and work without a Net connection, many times a window will pop up and tell you that you are not connected, that it could not find an internet connection. Since you did not click on IE or Firefox or anything, this is likely spyware trying to reach out to re-download, so you know you are not done finding it and eradicating it.
            There is one thing you cannot fix with these instructions: a rootkit. The nasty files used unofficial sneaky methods, so normal directory listings wouldn't show the files EVEN IN SAFE MODE, and registry editors would be tricked into not showing the startup entries for the evil files EVEN IN SAFE MODE (if registry editor even worked in safe mode, don't remember). I can't remember how I fixed it (it was the rootkit SRIZBI) but I can probably find it in my notes somewhere. Post again if you need.
            Other suggestions here are good: A/V, firewall, using browsers OTHER THAN IE and mail clients OTHER THAN Outlook. And keep Windows patches up to date.
            Creating a limited user account helps somewhat, but I've seen examples where this doesn't work. You can forbid limited users from installing random garbage that MySpace users tell them to click on, so for that alone you should do this last suggestion.
            Last edited by Hondaman; 11-20-2008, 02:48 AM. Reason: Suggest limited user accounts
            • bgavin
              • Jan 2007
              • 1355
              #66
              Re: pop-up issue
              The www.malwarebytes.org scanner works equally well in SAFE mode. This avoids loading most of the nasties.
              If this fails, build a BART-PE boot cd, and install McAfee or your favorite scanner on the CD. This will get you around all boot-loaded bugs. If that doesn't work, FDISK/FORMAT works every time.
              If you install fresh, GHOST your system before using the Internet. You can safely download Windows Updates, but don't go anywhere else until you image your system.
              • rounin
                MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                by rounin
                I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                🛠 Original Issue
                The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                04-19-2025, 01:18 AM
              • ugamazing
                Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                by ugamazing
                I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                12-17-2024, 07:05 PM
              • ahmarzo
                Acer laptop battery draining issue
                by ahmarzo
                Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                08-02-2025, 06:39 AM
              • elmark
                HP 15-cw1002ua strange keyboard issue
                by elmark
                HP Pavilion 15-CW1002UA
                S/N 5CD0251CBC
                P/N 7KE54EA
                Hello guys!
                I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                It powers on OK and has no other issues except the following:
                • CAPS LOCK does not work at all
                • Fn button toggles Flight Mode
                • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                • (with SHIFT pressed: 't%' and 'y^' respectively)
                I initially thought it was a keyboard malfunction (internal short, etc.),
                but when I press and hold...
                06-27-2025, 01:10 AM
              • Simone Vergani
                Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                by Simone Vergani
                I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                To assist with troubleshooting, I'm attaching two power circuit schematics:
                • Power
                03-05-2025, 02:25 PM
