Test equipment using variants of the UNIX operating system
  • japlytic
    • Oct 2005
    • 2086
    This thread concerns a computer component, being operating system software.
    On an eBay listing for a Hewlett-Packard logic analyser, I saw the X Window System logo on the screen, indicating that this piece of equipment uses some variant of the UNIX operating system.
    One possible indication that a piece of test equipment (with a graphic display) which uses UNIX (but not DOS or Microsoft Windows) is the SCSI interface, which was a standard feature on many UNIX workstations at one time.
    But a very likely indication that a particular piece of test equipment uses UNIX (but not DOS or Microsoft Windows) is trying to change the year in the Real Time Clock beyond 2037 (the Year 2038 bug, a known UNIX bug) without success in the normal manner - I found this bug in a LeCroy LC Series oscilloscope (firmware version 9.3.0).
    If a particular piece of test equipment uses a variant of UNIX, there could be some hackability in it, including unlocking Software Options for particular measurements (FFT etc.)
    I think a number of test equipment manufacturers had significant experience with the UNIX operating system and therefore, used some variant thereof in a number of models of microprocessor-controlled test equipment.
  • Compgeke
    • Feb 2014
    • 524
    Re: Test equipment using variants of the UNIX operating system
    A lot of HP logic analyzers and such are based on a PA-RISC processor with a variation of HP-UX running on them. They even often came with additional features\programs on floppy disks you could install to the internal IDE or SCSI hard drive. I believe there's a way to exit out and get to a terminal but I wouldn't know personally, my fanciest gear is Tek and it's proprietary OS.
    • chth96
      How Can I test PWM DM0365R?
      by chth96
      Hello
      I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
      So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
      I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
      I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
      06-18-2025, 04:14 PM
    • khelane
      test active pfc power with lamp test
      by khelane
      Hello
      I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
      Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
      Is there a way...
      06-03-2025, 01:00 AM
    • chronic519
      Mats / mods: detected and repaired GPU fault. Cant seem to test after!
      by chronic519
      Hello.
      GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
      Found issue with a RAM block
      Replaced, green lines gone.
      Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
      Used a good card to test and same results low errors 32+.
      I am just search for some form of command to do a full test on the GPU.
      I just ran the mats command with my good GPU and passed after roughly 40 min.
      The repaired one, ran...
      05-20-2025, 07:56 PM
    • hemant_2222
      Yamaha 2064 No sound but Test audio working
      by hemant_2222
      Hello Guys,
      Greetings!
      Hope you all are doing well.
      I am looking for suggestion on Yamaha 2064. The problem with this receiver is that it has no sound however when the test tones are activated it does outputs from all the speakers. It is working in two channel stereo mode but when you select other sound modes, it doesn't. The last time it had a problem, I had replaced the DAC
      PCM1681DBQR - IC263 and it worked fine.
      Other issue with it is one of the STK ICs is getting more heated then the other one but that can be looked at later.
      11-01-2025, 11:20 PM
    • alltvrepairs
      Lg TCon test pins for screen test
      by alltvrepairs
      i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
      Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
      Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
      Appreciate your help....
      06-13-2025, 06:33 AM
