Dead onboard audio... again?!
  • stevo1210
    • Oct 2006
    • 4156
    I have a PC here with an Asus P4P800S-X motherboard, anyway, everything works fine except for my onboard audio!
    Onboard audio was working fine before I disabled it a few months ago to install my Creative PCI512 sound card. Today I removed the Creative and reenabled the onboard audio and it doesn't even get detected in Windows. I've even gone through the trouble of reformatting my hard drive and reinstalling Windows because I thought my Windows was screwed. No change at all. Even after a CMOS reset, the onboard audio is still not being detected by Windows XP. I can't understand why my onboard audio has died out. For the time being, the Creative PCI512 sound card is back in there.
    Does anyone know how to get the onboard audio working again? Never have I had a completely dead onboard audio symptom. I have a Gigabyte 8IPE1000-G that has a faulty right channel and that's the worse I've been through with faulty audio.
    Thanks.
  • Newbie2
    • Sep 2005
    • 885
    Re: Dead onboard audio... again?!
    Just get a cheap sound card or continue to use that Creative sound card, faulty onboard audio shouldn't be a big issue since cheap sound cards don't cost a fortune these days, and your Creative sound card should be better than the onboard audio in terms of sound quality.
    Did you change any jumpers or BIOS settings to disable the onboard audio? Check the motherboard's manual.
    My gaming PC:
    AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
    ASUS M4A77TD AMD 770 AM3 Motherboard
    PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
    G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
    TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
    WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
    ASUS Xonar DG 5.1 Channel PCI sound card
    Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
    Antec Three Hundred Mid-Tower Case
    Microsoft Windows 10 Pro 64-bit
    Microsoft Windows 7 Ultimate SP1 64-bit
    • jpdoe
      • May 2007
      • 237
      I've known some boards where integrated components get automatically disabled if a particular pci socket is occupied with an external pci card. I would uninstall all pci cards, leaving only the bare minimum installed.
      The other problem i've faced recently regarding onboard audio is the microsoft package needed to recognize some high definition audio chips. It seems these chips are connected through a new bus, and if you don't have the microsoft windows xp package neccesary to support that bus, you can't install the audio driver. But it doesn't seem to be your case, since it seems your audio chip is a AD1888, a basic ac97 codec without high definition audio.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Thanks.
        Did you disable the on-board audio in the BIOS when you installed the sound card?
        If so need to turn it back on.
        Mann-Made Global Warming.
        - Dr Seuss
        • stevo1210
          • Oct 2006
          • 4156
          I have reenabled onboard audio in the bios, still nothing is being detected in windows. I have also stripped all pci card except for agp card and the audio still isn't detected in windows. Oh, and now for some strange reason my usb ports don't work. I plugged a usb flash drive in and bios detects it but windows says it's an unknown device or sometimes it will detect the usb drive but it will say it malfunctioned with a 'code 10' error. I tried different usb drives with same effect. Is this a software or hardware issue?
          Thanks.
          • stevo1210
            • Oct 2006
            • 4156
            no, I didn't change any jumpers. it's all bios controlled. i've checked the manual to confirm that. anyway, thanks for the tip.
            thanks.
            • jpdoe
              • May 2007
              • 237
              Well... misbehaving peripherals are usually a consequence of an overtaxed PSU. When out of the blue LAN or USB ports start to act out, a common reason is the PSU is on the way out, and can't supply enough amperage to feed the whole system anymore. Try another PSU. If you don't have one, try leaving the system with the bare minimum (only one hard disk, no optical drives, no floppy drives, etc.)
              • Newbie2
                • Sep 2005
                • 885
                Solutions for your problem stevo1210:
                1. Use a PCI sound card.
                2. Use a USB 2.0 PCI card.
                3. Check your power supply.
                Those are three good tips or solutions to your problem.
                Also, try updating the BIOS if it isn't already the latest version.
                My gaming PC:
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Thanks.
                  If Windows can see the USB gadget then it has power.
                  But if it has bad power windows may not be able to ID the device and then can't load the right drivers.
                  Sound might be doing the same thing.
                  I think you have bad/dirty 5v power on the board.
                  That could explain both USB and sound problem.
                  - Dr Seuss
                  • zandrax
                    Hit and miss
                    • Dec 2007
                    • 1157
                    • Italy
                    I agree with PCBONOEZ: check the psu in all cases and internal cables if front usb ports are the ones misbehaving.
                    Regarding the onboard sound, it seems that any PCI frequency different from 33 MHz causes the audio chip not to be recognized so check PCI freq in bios. Clear the cmos again and check battery voltage too.
                    Zandrax
                    Have an happy life.
                    • stevo1210
                      • Oct 2006
                      • 4156
                      The PSU is a brand new Delta Eletronics one that is rated at 350W. I bought it a month ago and has barely done 10 hours of use. But anyway, I will try and replug the ATX connector as it may be oxidised? There is no way I can think that my Delta PSU has issues.... unless my unit is a dud. But then again, voltages are in spec.
                      Thanks.
                      • Newbie2
                        • Sep 2005
                        • 885
                        Delta PSU = very high quality
                        Now I suspect there is a fault on the motherboard. Try updating its BIOS to a newer version if it isn't already updated to the latest version that ASUS released for it.
                        If nothing works, the best and easy solution would be to use a PCI sound card and PCI USB 2.0 card. It's a regular-size ATX motherboard, so I wouldn't doubt it would be able to take two PCI cards.
                        My gaming PC:
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Fake Delta (I think) - UL is "Sun Pro" out of China.
                          http://cgi.ebay.com/DELTA-500W-ATX-D...mZ250294502091
                          - Dr Seuss
                          • Newbie2
                            • Sep 2005
                            • 885
                            The fake "DELTA" power supply has a UL number of "E210743".
                            stevo1210, check the UL number on the label of your Delta power supply and see if it's really a Delta power supply.
                            My gaming PC:
                            • jpdoe
                              • May 2007
                              • 237
                              Man... And I though only third world countries like mine had to deal with fake electronics.
                              • stevo1210
                                • Oct 2006
                                • 4156
                                I can't get to my the Asus PC at the moment. But I know it has a real Delta PSU because the PSU came out of an Asus ATX case and also has a "certified by Asus" sticker on it. It also look very boring compared to the Delta PSU on eBay and the sticker has no fancy text, just lain words that say : "Delta Electronics Inc." etc.
                                Thanks.
                                • jpdoe
                                  • May 2007
                                  • 237
                                  Then you might have a component mismatch. Maybe you're trying to power a motherboard that consumes mostly 12v power with a PSU engineered to deliver mostly 5v power.
                                  • stevo1210
                                    • Oct 2006
                                    • 4156
                                    This is strange, but I replugged the atx connector of the psu to the motherboard and my usb ports worked again. I haven't tested onboard sound yet, but I will give it atry tomorrow.
                                    Thanks.
                                    • Newbie2
                                      • Sep 2005
                                      • 885
                                      Thanks.
                                      A bad connection of the ATX connector can sometimes cause mysterious problems.
                                      If the onboard audio still doesn't work, chances are the onboard audio chip has somehow died and a PCI sound card will be the solution to that.
                                      My gaming PC:
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Yes.
                                        [Talking about the metal, not the plastic]
                                        The female side of the connector can be bent a little with a stiff needle or a pointed DMM probe to tighten up the fit. Not too much or it may not plug back in.
                                        - Dr Seuss
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • i_am_patch
                                          Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                                          by i_am_patch
                                          Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                                          04-30-2024, 08:20 PM
                                        • Piaskos
                                          Dell Vostro 5490 - no sound, no audio device
                                          by Piaskos
                                          Hi, i've got problem with Dell Vostro 5490.
                                          Board - Mantis CML 18788-1
                                          Windows says "no audio device detected". The other functions work properly.
                                          What i've done:
                                          1. I checked motherboard
                                          2. I changed audio codec (ALC3204)
                                          3. I reflashed bios with clear ME
                                          4. Audio is enable in bios
                                          5. Both speakers are good
                                          6. After installing the drivers from the Dell website, the devices visible in the manager:
                                          - Audio for intel displays
                                          - Intel Smart Sound Technology...
                                          01-30-2023, 02:58 AM
                                        • CapLeaker
                                          Motorola Minitor V pager no audio / sound repair
                                          by CapLeaker
                                          Got a bunch of Motorola Minitor V pagers from Fire Departments here trying to fix some out of the non working ones. These pagers are known for either no sound / audio or they don’t charge. The internet is full of suggestions like metal shavings inside the speaker?
                                          Anyway so I took one of the Minitor’s apart for my amusement in order to see why that is and nobody can fix em. There are no service manuals or schematics for these that I know of. However… I did find the problem!
                                          On the main board of this unit where the speaker connects to there is a metal shield....
                                          06-10-2025, 07:44 PM
                                        • televizora
                                          HP 8470p - distorted sound and noise when playing audio
                                          by televizora
                                          Hello.
                                          I have an issue with HP 8470p - rather strange one.
                                          I have a noise and sound distortions on both internal speakers and external speakers, when I plug such into the 3.5mm audio jack.
                                          Seems like the noise is present especially when I play audio, where there are parts/sections where the volume of the actual recorded sound is low.
                                          Interestingly, when I play the windows sound test, everything seems to be almost okay. The sound/distortions are similar to when you have interference from some other piece of equipment nearby or when you have an audio receiver with bad amplifier...
                                          12-31-2021, 10:25 AM
