Failure Rate
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Failure Rate
    I'm not talking about CAPS, I'm just curios to know "how many time" experienced people can't repair MOBO or at least, after recapping, it doesn't work or it is not reliable.
    I'm just curios because I don't repair PC for job, and the second time I tried to repair a MOBO with bad caps I failed .
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
  • stevo1210
    • Oct 2006
    • 4156
    Re: Failure Rate
    I have suffered from these falls a few times. Usually they are dead when I get them and they would usually have burnt chipsets or similar.
    Never have I had a recp fail on me.... even those recaps which I screw up so badly by heating up the PCB for too long and melting the paint off, unbelievably they still work?!. .... luckily I know how to properly recap a board these days so those issues are avoidable.
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: Failure Rate
      the thing is that you cannot directly compare experiences because the parameters are all different. it is not the same as if we were all building the same kit for instance and one guy failed on the first two attempts.
      some boards may be beyond help or there are multiple problems with the hardware
      perhaps you have been unlucky. i certainly would suggest that you persevere, unless you are incredibly shit at soldering which i doubt is the case.
      personally i have recapped almost every board ok but i killed one by damaging traces, long time heating.
      • linuxguru
        • Apr 2005
        • 1564
        Re: Failure Rate
        Yeah, I have nuked a few boards. However, some of those were probably already beyond repair due to sustained overvoltage, PSU or other problems outside the realm of the mobo issues alone. OTOH, I have rescued several boards that had been given up for dead - most recently an i865. On balance, recapping is worthwhile in the long run in spite of occasional failures.
        • i4004
          • Oct 2006
          • 2029
          Re: Failure Rate
          not everything can be repaired. i think there are cases when even those who made it wouldn't be able to fix it, because it's just so complex.
          (but they surely have better chances with all the tech data and spare parts etc.)
          send that board to willa, let it spoil his average a bit...hehe...
          oh, as they say, third time's a charm....
          • Gianni
            • Jul 2008
            • 681
            • Italy
            Re: Failure Rate
            Impossible I started when I was 16teen to solder in a small firm, I made pre-production for small electronics board. They wanted a very good job on prototype board.
            Ok now I'm old and probably I have some rust but I still solder almost every day for job so I must solder well otherwise my boss get angry.
            I agree with you, it is not possible to make comparison, probably I have wrote the question in the wrong way; what I meant to ask is "how many time something looks like reparable but even trying you can't get it working?".
            My English needs improvement.
            You are probably right. This afternoon when I brought the PC to my friend, when I was connecting the mouse to the USB port removing the PS/2 adaptor, she told it had never worked on the old PC on USB port. When we started the PC, win has installed it without problems. I think the previous MOBO had to much problem and the damn crap caps have given it the last shot.
            Right again!! I forgot that I have already recapped a third board since it is sleeping in my cellar waiting for someone that need a PC. With it was easy and I had no problem at all.
            Ok then I will continue, but next time I ask for curriculum-vitae of the PC before starting to do something. If you fix a problem but you don't know that there were other problems... you get crazy to do the job.
            I have to add that usually I help people for software problems (virus, corrupted OS, recovering DATA, installing SW...) only sometime I work on the HW.
            Thanks a lot guys
            Gianni
            H. J. Brown
            • npielawski
              MacBook Pro late 2016 (820-00239) with multiple failure modes.
              by npielawski
              I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
              I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
              10-15-2025, 01:53 AM
            • CovfefeMonster
              Is there an increasing GPU failure rate lately?
              by CovfefeMonster
              I have a K4200 GPU in my Z440 running Windows 10. Some time around October 28th, my GPU experienced a fault. My windows system BSOD'd with DPC_WATCHDOG_VIOLATION and restarted. On restart, the GPU drivers were rejected from loading due to an Error 43. There was some artifacting going on in both Windows 10 and Windows 8. The strange thing is, the artifacting only shows up in the Windows ecosystem. When the system is in BIOS, there are no graphical anomalies. I looked in the event viewer for some clues as to what was going on, and I noticed something new. The system was notifying that...
              11-06-2025, 07:40 PM
            • nobbnobb1
              TVs vs Computer Monitor Reliability & Failure Rate
              by nobbnobb1
              Anecdotally, it seems to me that TVs fail much more often than computer monitors judging from personal experience and looking at the classified where people are getting rid of broken/malfunctioning TVs all the time.
              So I'm just wondering if this is the case? Is there something inherent in the design of monitors that makes them more reliable? I would've thought they'd be operating under more severe conditions than a TV. For a typical family, a TV may only be on for a few hours every day. Whereas a monitor could be on 8+ hours, along with countless power cycles turning on/off as power...
              07-07-2024, 10:57 AM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • puccovelli
              Dell 9310 Memory or RAM (Random-Access Memory) failure (2,4)
              by puccovelli
              Hi all, I hope this is the right place to post.
              I'm having a problem with a Dell 9310 which is posting 2 orange, 4 white lights on startup (hangs on Dell BIOS logo). The service manual says its a RAM failure.
              I've taken the motherboard out and noticed that one of what looks like an SMA 0805 resistor has blown (see photo). The board is an LA-J144P Rev 2.0(A01).
              1] Could someone confirm what the component that has blow actually is (and where I could get another from).
              2] Whether this component is likely to cause the RAM failure issue, and if replacing...
              10-11-2025, 06:30 AM
