P6VAA: is it worth to repair?
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Hi have this PC to fix but I don't know if it is worth to spend money and time on it; every now and than it crashes suddenly and restarts but very often BSOD appears.
    MOBO is ECS P6VAA 1.0 VIA 133 SKT370, the CPU is Celeron 700MHz.
    As you can see from attached pics, there are some leaking and bulged caps, they are G-Luxon series LZ 1000uF 6.3V.
    Also in the PSU I found a leaking cap, it is a Canicon.
    About the PSU, it is very similar to a Deer I repaired few days ago but the brand is Tecnoware; compared to the Deer, there are less caps on the output and also missing inductance.
    I hope today they use better caps otherwise I have bought the wrong item ( https://www.badcaps.net/forum/showpo...0&postcount=32 ).
    By the way this PSU probably is not the original one that came with the case because the date is 2003 on the warranty label.
    I dislike to trash something that can be repaired, but in this case I don't know if it is worth because this MOBO is very old (warranty label date 2001) and very slow for today OS and software.
    The person that gave me this PC has bought a new one so he doesn't need it back, I can repair it and give it for free to someone, but how long it can run changing only badcaps?
    Ciao
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
  • linuxguru
    • Apr 2005
    • 1564
    Re: P6VAA: is it worth to repair?
    If recapped with known good caps for both the mobo and PSU, there's no reason it can't run for another 10 to 15 years - the only limitations are electro-mechanical (fans and hard drives).
    • Gianni
      • Jul 2008
      • 681
      • Italy
      Hi linuxguru
      I'm browsing with my notebook because my monitor, keyboard etc... are connected to ECS Mobo and I'm installing Win.
      I have replaced all caps with Panasonic FM series but only when I will have finished with Win and tested the PC I could be sure everything is OK.
      Ok I don't expect somebody will be still using it in 2018, but maybe it can be useful again for 3 or 4 years .
      I have worked at home and it was not so easy to free the holes especially where the tracks are very large; usually I do this kind of work in my company lab, with desoldering station it is easy.
      Well I have do it to save the PC and to make more experience with "home tools" .
      Ciao
      Gianni
      H. J. Brown
      • ChaosLegionnaire
        by ChaosLegionnaire
        09-13-2022, 09:02 AM
      • kotel studios
        DEER B350ATX PSU - tips on making it safer and "better"
        by kotel studios
        Since it looks like my excellent power PSU chances at living are now close to zero, I decided to give a shot at upgrading this DEER B350ATX PSU.
        At first glance it looks like, well.... a shitty cheaped out DEER garbage (cause it is). Although it does have an LF 1250CD00 filter transformer (at least I think that's what it is) 😆
        Tiny heatsinks, small transformators, single-pole ON/OFF switch. You name it.
        Now since this one works, I'd like to know how can I make it safer and better (besides burning it with napal 😃). My plan is to make the switch double-pole...
        03-04-2025, 12:09 PM
      • Cerberuska
        Mobo MSI B550-A PRO password popup
        by Cerberuska
        Hello guys,
        I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
        BIOS I updated to last one.
        any suggestions?
        And same thing for two different 5600G, and yes, MoBo supposed to support it.
        Thank you...
        11-10-2024, 01:23 PM
      • mrsith
        Dell G3 17 3779 - no display after mobo replacement
        by mrsith
        Hi guys,
        I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
        Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
        04-30-2023, 05:11 AM
      • Ibod
        Corsair cx600 psu & ASRock B450Pro4 mobo wont start
        by Ibod
        HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
        With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
        Not sure where to go from here ?
        Is the PSU at fault or is the mobo causing the problem
        Look forward to any help :-)
        If I plug the 24...
        02-08-2023, 11:00 AM
