Failure Rate
  • Gianni
    • Jul 2008
    • 681
    • Italy
    Failure Rate
    I'm not talking about CAPS, I'm just curios to know "how many time" experienced people can't repair MOBO or at least, after recapping, it doesn't work or it is not reliable.
    I'm just curios because I don't repair PC for job, and the second time I tried to repair a MOBO with bad caps I failed .
    Gianni
    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
    H. J. Brown
  • stevo1210
    • Oct 2006
    • 4156
    Re: Failure Rate
    I have suffered from these falls a few times. Usually they are dead when I get them and they would usually have burnt chipsets or similar.
    Never have I had a recp fail on me.... even those recaps which I screw up so badly by heating up the PCB for too long and melting the paint off, unbelievably they still work?!. .... luckily I know how to properly recap a board these days so those issues are avoidable.
    Thanks.
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      Re: Failure Rate
      the thing is that you cannot directly compare experiences because the parameters are all different. it is not the same as if we were all building the same kit for instance and one guy failed on the first two attempts.
      some boards may be beyond help or there are multiple problems with the hardware
      perhaps you have been unlucky. i certainly would suggest that you persevere, unless you are incredibly shit at soldering which i doubt is the case.
      personally i have recapped almost every board ok but i killed one by damaging traces, long time heating.
      • linuxguru
        • Apr 2005
        • 1564
        Re: Failure Rate
        Yeah, I have nuked a few boards. However, some of those were probably already beyond repair due to sustained overvoltage, PSU or other problems outside the realm of the mobo issues alone. OTOH, I have rescued several boards that had been given up for dead - most recently an i865. On balance, recapping is worthwhile in the long run in spite of occasional failures.
        • i4004
          • Oct 2006
          • 2029
          Re: Failure Rate
          not everything can be repaired. i think there are cases when even those who made it wouldn't be able to fix it, because it's just so complex.
          (but they surely have better chances with all the tech data and spare parts etc.)
          send that board to willa, let it spoil his average a bit...hehe...
          oh, as they say, third time's a charm....
          • Gianni
            • Jul 2008
            • 681
            • Italy
            Re: Failure Rate
            Impossible I started when I was 16teen to solder in a small firm, I made pre-production for small electronics board. They wanted a very good job on prototype board.
            Ok now I'm old and probably I have some rust but I still solder almost every day for job so I must solder well otherwise my boss get angry.
            I agree with you, it is not possible to make comparison, probably I have wrote the question in the wrong way; what I meant to ask is "how many time something looks like reparable but even trying you can't get it working?".
            My English needs improvement.
            You are probably right. This afternoon when I brought the PC to my friend, when I was connecting the mouse to the USB port removing the PS/2 adaptor, she told it had never worked on the old PC on USB port. When we started the PC, win has installed it without problems. I think the previous MOBO had to much problem and the damn crap caps have given it the last shot.
            Right again!! I forgot that I have already recapped a third board since it is sleeping in my cellar waiting for someone that need a PC. With it was easy and I had no problem at all.
            Ok then I will continue, but next time I ask for curriculum-vitae of the PC before starting to do something. If you fix a problem but you don't know that there were other problems... you get crazy to do the job.
            I have to add that usually I help people for software problems (virus, corrupted OS, recovering DATA, installing SW...) only sometime I work on the HW.
            Thanks a lot guys
            Gianni
            H. J. Brown
            • nobbnobb1
              TVs vs Computer Monitor Reliability & Failure Rate
              by nobbnobb1
              Anecdotally, it seems to me that TVs fail much more often than computer monitors judging from personal experience and looking at the classified where people are getting rid of broken/malfunctioning TVs all the time.
              So I'm just wondering if this is the case? Is there something inherent in the design of monitors that makes them more reliable? I would've thought they'd be operating under more severe conditions than a TV. For a typical family, a TV may only be on for a few hours every day. Whereas a monitor could be on 8+ hours, along with countless power cycles turning on/off as power...
              07-07-2024, 10:57 AM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • Sus256
              HISENSE 65E7KQ PRO - no boot
              by Sus256
              Hi all!
              HISENSE 65E7KQ PRO
              RSAG7.820.13512 - chassis
              MT9618BAATAB - cpu
              RSAG7.820.12059 - power
              HD650Y3U77 - panel
              KLM8G1GETF - emmc
              Replaced emmc.
              Terminal log
              UART
              AC_ON
              E-B
              FDE enabled
              06-01-2025, 02:11 AM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • ctroxtell
              Carrier HK50AA063 display controller common failure help
              by ctroxtell
              I've got a control display for a Carrier chiller that I'm trying to understand what the common failure with these boards are. This is the board in question https://www.supplyhouse.com/Carrier-...arquee-Display all of them seem to develop a failure with the up and down arrow buttons on the right side of the display, the esc and enter keys I've never seen fail. Once these boards are plugged in they run 24/7, you used to have to press extremely hard with the end of the blunt screwdriver and you could still get the arrows to work but now it has completely stopped working. The button...
              02-05-2025, 05:31 PM
