Ratdude's main rig V5.0
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Guess what? It's ratdude main rig build time again!
    This one is special, for a couple reasons.
    First, Main rig V3.5 died (VRM cooked, see post #196 of it's thread) and I more or less have a hollow shell of a kickass workstation sitting.
    Second, topcat is, by a lucky coincidence, giving me a new (to me) board + RAM + CPUs to play with, and this is what will form V5.0. However, revealing where it's coming from (how Topcat got it) would reveal some stuff Topcat hasn't gotten to posting, so I'll let that be topcat's story to tell.
    Here's what I will post about the board: (just enough to make the rest of this OP make sense, plus what topcat has already posted himself)
    • It's EATX and made by supermicro
    • It's socket 771 with twin quad cores, no coolers included
    • It has 32GB of RAM
    • It has twin PCI X16 slots, but no SLI
    So, in addition to a new board+RAM+CPUs, there will be some more changes:
    -No SLI means no real point in running twin GPUs. This board also uses more power, so unless I swap PSUs, that's not a good combination. So, for now, I'll be running a single Geforce 250GTS although I will be looking for better GPU. That said, if you have a somewhat newer (geforce 200 or newer, AMD equivalents are also fair game) higher-end GPU you want to sell, shoot me a PM; I have a real job now so I'm not super cash-strapped (although I'm not blowing $$$$ on this obviously).
    -That leaves me with a free x16 PCIe slot... what to do there? Well, a cheap and simple upgrade is this:
    http://www.ebay.com/itm/252356891045
    I don't have drives fast enough to warrant a higher end card, although I have the option to.
    FWIW I did look at the supermicro UIO RAID cards but the price of admission is high and nothing had a BBU (they made them but nobody's selling them). Not to mention I like 3ware better than adaptec.
    -I need some coolers... and found these:
    http://www.newegg.com/Product/Produc...82E16816101288
    They use 80mm fans and if my temps stay low enough I might be able to swap in some Arctic Cooling CO fans to quiet it down a bit. I'll have to see.
    It's a good thing I'm running a SM case, as otherwise I'd have to get different (read: pricier) coolers. This one has the mount holes already punched and tapped, so I'm in good shape to run them. Speaking of SM case and board combos:
    -SM makes their cases so if you use their boards (like in a barebones), you can plug the ribbon cable for the lights and switches right in. Which is no good for RAID cards. Once upon a time I fixed that issue on another rig:
    However, that board was the only one of it's batch to turn out as anything decent. Not to mention it was made as a PCB mill test and one can get PCBs made super cheap these days. So, I took a night to redesign that a bit:
    https://oshpark.com/shared_projects/zszsAHZa
    It's a board that allows one to at the flip of a switch redirect the HDD and NIC2 lights to something other than the motherboard.
    I have the parts already but the boards have yet to come in, so no actual pictures.
    I eventually plan to get better hard drives too, but that will wait. For now, this is as far as I'll go.
    Look like a plan for a decent rig?
    sigpic
    (Insert witty quote here)
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Ratdude's main rig V5.0
    Looks like you are starting out a business. Good for Ratdude747.
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      Umm what?
      This is my hobby. My day job is as an engineer at Arvin Sango in Madison, IN.
      sigpic
      • diif
        • Feb 2014
        • 6978
        • England
        Not too shabby RD.
        It might not do SLI, but the real reason for twin PCI-E is multiple monitors.
        I can get far more work done with 4 screens than i can with 2.
        Now you have a job, surely SSDs are the way to go ?
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Originally posted by diif
          Not too shabby RD.
          My desk barely has room for two of my 22" HP LCDs... no room for more.
          SSDs are still pricey... for the amount of storage I'd need I'd be spending a few hundred at least. Maybe down the road, but not off the bat. That said, SM makes an addon for my case that allows one to add four 2.5" drives (that empty are in front of the intake fan) so If I changed cards and rewired I could do some fun stuff. I think I'll stick with 10K spinners though.
          sigpic
          • diif
            • Feb 2014
            • 6978
            • England
            At least put the OS on one or two.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Nah, that wrecks my setup plans; a 4 drivr RAID 0 array, just like it currently has.
              sigpic
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Looked closer for UIO cards:
                http://www.ebay.com/itm/AOC-USAS-S8I...8AAOSwoudW2bnc
                Making an offer... The trick is not to search for "UIO" as listings that mention that also seem to have higher price tags.
                sigpic
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  Four disk RAID 0 ?
                  Two sets of two ?
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    ^Nope. One of 4.
                    Well shit.
                    Looks like SM cheaped out and only gave me one USB header. Bye Bye card reader (unless I add in a USB card and use my floppy combo card reader, which is an option)
                    This build isn't going the best it seems... too much shit that doesn't quite fit. I'll make it work, but dang. I have older SM Boards with twin USB headers (4 front ports total)... Why???
                    sigpic
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      Umm ok, 10 would be better you know. I suppose you do have your other machines for backup.
                      • Topcat
                        The Boss Stooge
                        • Oct 2003
                        • 16956
                        I think the motherboard would reject that like a human rejects the heart of a baboon.
                        <--- Badcaps.net Founder
                        Badcaps.net Services:
                        Motherboard Repair Services
                        http://folding.stanford.edu/
                        Team : 49813
                        Join in!!
                        Team Stats
                        • TechGeek
                          Computer Geek
                          • Jan 2015
                          • 2254
                          LOL. Best comment 2016.
                          Permanently Retired Systems:
                          Kooky and Kool Systems
                          sigpic
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            ^ I think he meant RAID 10, not windows 10. I don't run RAID 10 because at 74GB a pop, The only way to get a decent (for a main rig) amount of space is to either JBOD it or RAID 0. RAID0 has a performance boost, so that's why I went the way I did.
                            I have a server which holds backups of all the important files.
                            sigpic
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              Yes, were were on the topic of RAID, and as an IT pro certainly don't recommend 10 although there are a couple of nice features in it.
                              I'd be interested in seeing your read/write speeds RD with your RAID. Your chance of corruption is increased 80% using 4 drives in RAID 0. You might have backups but its a lot of effort. A Samsung Evo 850 500GB is a little over £100. I do appreciate that you might not be building for practicality and more the cool factor.
                              • Topcat
                                The Boss Stooge
                                • Oct 2003
                                • 16956
                                I skimmed it...and stumbled @ 10... RAID10 is nice for non critical stuff, its fast with a touch of redundancy. RAID in ANY form is NOT BACKUP! Very common misconception!! Raid is purely a redundancy to to reduce downtime or immediate dataloss for a drive failure....but RAID is no substitute for good backups. I'm off my soapbox now. Carry on.
                                Team : 49813
                                Join in!!
                                Team Stats
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  Umm what?
                                  Just better watch out that your hobby doesn't become your Day Job. Seems to me that is were you are heading.
                                  • TechGeek
                                    Computer Geek
                                    • Jan 2015
                                    • 2254
                                    Hey, what happened to my other posts? :/
                                    sigpic
                                    • Topcat
                                      The Boss Stooge
                                      • Oct 2003
                                      • 16956
                                      They were useless, I removed them.
                                      Team : 49813
                                      Join in!!
                                      Team Stats
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        these ones?
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
                                        • JSin21
                                          Compatibility of main boards between different variations of samsung MU6100
                                          by JSin21
                                          Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                                          I have Samsung Smart TV UA65MU6100WXXY version DA01
                                          Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                                          11-27-2023, 04:54 AM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
