Re: Ratdude's main rig V5.0
I'm an idiot... I did post it, and it was lost in the bowels of the forum.
https://www.badcaps.net/forum/showthread.php?t=74328
Apparently I never updated this thread.
Awhile back the remains of this system (along with a replacement X7DWA-N and an identical case) were built up into a replica of the original build... which is my wife's current rig.
No pics because it's literally the exact same thing other than different optical drives (maybe).
Posting this because I'm linking this in a new thread.Leave a comment:
New theory:
When I first swapped GPUs, the board did get hit in that area. While there is no visible damage, I wonder if a BGA joint failure at the NIC (which is in the area hit) could have happened... would explain why it would sometimes come and go, but usually not work at all.
Sadly I don't have a hot air station, so no good way to test it... but I'd like to sometime.Leave a comment:
^and pin 1 wasn't well marked
Ended up passing on the board. Ended up selling for $68, but truth be told it was a money pit due to RAM required.
I'll keep my eyes open for another x7DWA-n board (or other capable board)... no teaming sucks, but It's not worth spending hundreds of dollars I don't have.Leave a comment:
Yep, at work we have a 5-year replacement cycle on servers and many other companies have similar replacement schedules, so Westmere and even Sandy-Bridge Xeons out of scrapped servers are flooding the market driving down prices.Leave a comment:
I saw all sorts of westmeres for dirt cheap. Yay blade server scrapping (which is where I bet most come from).I thought those ribbons were keyed..... lol....
...but if you do move to the X8 platform, nehalem/westmere processors are wonderful.
Fastest quad-core westmere: http://www.ebay.com/itm/352155915956
Fastest hex-core westmere: http://www.ebay.com/itm/192291451054
I went with the 3.6GHz dual quads. I just don't have anything that will tax 12 cores (or even 8 for that matter)....so I went with the extra MHz....and they're about half the price.Leave a comment:
Boy genius here did something smart all right
... I both had the front panel ribbon backwards, and also screwedriver'd the wrong end of the header. Doh!
No LAN activity. The controller isn't even getting warm... and it's a die'd chip with a heatsink. Even with all cards pulled and cmos fully cleared.
Grr...
Yes.
Not spinning fans makes me think I'm missing something. Before I go to bed I might try rigging a different PSU to see if the backplane for the PSU modules is the issue.
Another option:
http://www.ebay.com/itm/Supermicro-X...torefresh=trueLeave a comment:
Looking at Supermicro AMD boards:
http://www.ebay.com/itm/Super-Micro-...gAAOSwnF9Y7szn
They make 6 core CPUs for those. I'd need to get RAM (or rob V4.1's 16GB or use the 8GB that used to be in it) if I went down that road. Unlike the the socket 940 version of this (what's in V3.8), NIC teaming in windows 7 is supported. Pending a benchmark check, I might put in a lowball offer on it... thoughts? Edit- the fastest 6 core one can drop in is 50 passmark points ahead of what I have (Read: a wash). However, while CPUs are cheap for these ($16 for a pair of slightly slower 6 core units!), it's only PCIe 1.0 which for my GPU could be a bottleneck (the GTX 970 ran fine on PCIe 2.0 but 1.0 is probably cutting it close).
If I had my druthers I'd nab a H8DG___ board... those support up to 12 core CPUs and have LSI SAS built in. But they're still pricey as **** right now.Last edited by ratdude747; 09-01-2017, 08:30 PM.Leave a comment:
I think I f*cking killed her.
Pulled the main board to look for PCB damage (resetting CMOS didn't help). Upon inspection I found 5 wrong jumpers: watchdog, and 4 for I2C over PCIe and PCI-X; all were enabled and according to manual are disabled by default.
I also found a large bypass SMD ceramic cap that had both solder joints cracked (hanging by a thread), which was knocked off at some point. Board removal didn't go well, so it's very possible that's fresh damage. I resoldered it, which seemed to go well.
Reassembled it, she won't even spin fans. Nothing. tried both hot swap PSU bays and two known supply modules. also tried starting it with a screwdriver to the header. Not looking good for the board.
Suggestions for what would cause such?Leave a comment:
But the X8DAH+-F does.
I don't see how a GPU conflict would do this. No option ROM. No port activity in standby. That's a failed chip or a bad enable jumper (which I've confirmed isn't the issue).
Edit- did see this: http://www.tomshardware.com/forum/30...plug-upgrading
I'll hard reset the BIOS and see what happens.Last edited by ratdude747; 09-01-2017, 04:13 PM.Leave a comment:
More window shopping:
http://www.ebay.com/itm/Adaptec-ASR-...IAAOSw7ZlZny1y
Cheapest 8 Port SAS controller with BBU. I have brackets of similar size to hack on... cheapest one with a bracket (and 8 ports/BBU) is $47, so for $27 I'll cannibalize an old 3ware 9500 or the like.
Best part is being adaptec, my array would be a direct swap... uses PCIe 8x so might even be the same chip.
And for RAM: From what I'm seeing the going rate for PC3-10600R DDR3 (ECC) is $10 per 4GB Module and $30 per 8GB module. F*ck. The board will cost less than the F*cking RAM!
So If I do snare an upgrade board, it might be awhile until I can afford the RAM.
The DTI doesn't have onboard audio.
The odds of that NIC frying are pretty low....I still think its some kind of conflict with that GPU....thats when all the NIC trouble started.Leave a comment:
And yet they make a board with both Matrox AND onboard audio...
I could brag about having more case space than you, but nah, I need good karma right now. Stupid fried LAN controller
Found another one with fanned coolers... but the CPU's are 80W Nehalams, not 40W Westmere's like the auction one: (edit- the auction's CPUs are only $11 for a pair... did westmere have a 6 core version?)
Maybe that's why the auction one had fanless coolers? 40W per CPU, combined with a matched 2U-high air duct and two high performance rear 80mm fans, is a working setup (which is what my case is, rear fans and 2U clear air duct).
I'd prefer another X7xxx board so my parts would transfer, but I'm also cool with westmere's!Last edited by ratdude747; 08-31-2017, 07:13 PM.Leave a comment:
The one shown with the Quadro FX5800 isn't the X8DTI, its an X8DAI. The DAI is the workstation version (no onboard graphics, yet has onboard audio). The DTI is the server version with the onboard Matrox GPU that you love so much!Leave a comment:
Scams:
http://www.ebay.com/itm/SuperMicro-X...QAAOSwUIhZYpNK
http://www.ebay.com/itm/Supermicro-X...4AAOSw9ENZn0m0
Graphics workstation boards my ass
"Server" board that would work for what I need:
http://www.ebay.com/itm/Supermicro-X...8AAOSw-4BXYevk
As I don't need more than 1 PCIe x16 slot. IIRC Topcat is using these (or very similar boards) in his dual board build (and based on his last post, the slot will work with a GPU).
Another workstation board:
http://www.ebay.com/itm/Supermicro-X...wAAOSw7ZRZi53n
Also has onboard matrox, but the audio ports give it away as a workstation board. Same as the auction above but just a board with no CPUs.
No drop in solutions. Damn, almost makes me want to look at Tyan boards
by cheeky2I suppose the real question is whether the existing pinouts from ether a 17IPS71 psu are cross compatible with a 17IPS12 psu? If they are then the exchange of the main boards should have no issues providing the screen is compatible with both main boards. Obviously you can change the screen configurations easily enough (providing you have the correct files) for the main board. Why may you ask would I do this? Well a lot of the smart features are no longer working on a Hitachi 48HBT62U main board I wish to give it a new lease of life!
Obviously the same LVDS connector for the screen connection... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by ygorsanHi everyone,
Iām looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
š§© Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
07-28-2025, 08:34 AM -
by Asraf AtbHi everyone,
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by semiRocketThe set is not turning on, when buttons on the front are pressed the button press sound is coming from the speakers, but the set is not trying to turn on, consuming only couple of watts.
I am troubleshooting a Vestel 17PW26-5 from the set. Not sure how it is supposed to turn on main supply, but with the main board disconnected not getting the main supply to turn on either.
Standby supply is working, PFC is working (390V), but the main supply is dead. Checked the mosfets and driving transistors and found they are not shorted and showing a diode junction. The suspicious... - Loading...
