How to clean desktops, or wash it.
  • Rockfella
    • Feb 2016
    • 13
    • India
    A friend's 6 year old HP desktop's PSU finally gave up, so I was the one to rescue him. First I had to make sure it was the PSU which died nothing else so I connected the tower with my corsair vs350 and it booted. Post that my itch to clean it took off..
    Some "before" pics
    On arrival:
    Testing:
    Dismantling:
    Cleaning:
    Foxconn mainboard:
    Old CMOS battery was dead so got new:
    New PSU (I ordered VS350, they probably had no stock so shipped VS450 for the price of 350!)
    Assembled:
    Front audio/USB ports tested fine.
    All sleeved cables:
    I was puzzled to find out my old ddr2 ram stick didn't fit on these ddr2 dimm slots :o
    It was fun. Next time I will remove all heatsinks/jumpers possible from the motherboard pre-washing.
    PS: Yes, it booted the first time, zero issues. I kept it under the sun for 5/6 hours before powering it up.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: How to clean desktops, or wash it.
    Nice job!
    Might have something to do with the board using DDR3 memory
    http://support.hp.com/us-en/document/c01903990
    • Rockfella
      • Feb 2016
      • 13
      • India
      Nice job!
      Ohk.. this one one of those rare boards that supports next gen memory on old gen chipset. Wow. Thanks.
      PS: I could not find the board in foxconn.com, didnt bother checking HP
      Hey, does this mean it won't support single stick of 4 GB DDR3?
      Memory upgrade information
      Supports DDR3 DIMMs only
      Dual channel memory architecture
      Two DDR3 DIMM (240-pin) sockets
      DIMM types:
      PC3-10600 (DDR3-1333)
      PC3-8500 (DDR3-1066)
      PC3-6400 (DDR3-800)
      Non-ECC memory only, unbuffered
      Supports 2 GB DDR3 DIMMs
      Supports up to 4 GB on 64-bit PCs
      Maximum memory only if using 2GB DDR3 DIMM modules
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Might work with 8GB total with 2x4GB sticks, depends on BIOS, only way to know is to try it
        • Rockfella
          • Feb 2016
          • 13
          • India
          Just did. Working. Don't know if it is worth spending more on this old system. It is used for browsing only.
          • cyjun1990
            • Jan 2016
            • 16
            • Philippines
            nice job... i gonna try soon. thanks rockfella
            • dmill89
              • Dec 2011
              • 2534
              If you want really weird/rare the Gigabyte EP45C-UD3R (P45 Chipset) in my desktop takes both DDR2 and DDR3 memory (though you can't mix them together it is one or the other).
              • Rockfella
                • Feb 2016
                • 13
                • India
                Nice to know. I bought a hynix 4 GB ddr3. Now this will be good for few more years
                • lbwlow
                  • May 2015
                  • 125
                  • Malaysia
                  Yeap, I give them a bath as well. But in the drying process i use air conditioner instead of heat source. Just leave it on the floor, after 1 day or 2, it dried completely.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Good work
                    • Rockfella
                      • Feb 2016
                      • 13
                      • India
                      Sun bathing is best.
                      Thanks.
                      Originally posted by ReeceyBurger123
                      Good work
                      • Rockfella
                        • Feb 2016
                        • 13
                        • India
                        I can't find the BIOS of this board man. Installed ATI R7 240, doesn't work.
                        Nice job!
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          You need to search the HP site with the actual model number of the machine, that way you will find the BIOS.
                          • Rockfella
                            • Feb 2016
                            • 13
                            • India
                            It is this one : HP Pavilion p6310in. Site has everything that I don't need except BIOS.
                            GOT IT:
                            http://www.findlaptopdriver.com/for_hi41uatx_eton/
                            • Rockfella
                              • Feb 2016
                              • 13
                              • India
                              GOT IT:
                              EDIT: Well I had to change graphics to PCIx in BIOS and it worked! No BIOS update needed.
                              • Uranium-235
                                Comrade Glimmer
                                • Aug 2007
                                • 5045
                                • US
                                I would have washed it in isopropyl, not soap
                                • vallllliiii
                                  Gigabyte motherboard GA-H110M-S2PH (rev. 1.0) DDR3 | Boot loop and 5 beeps
                                  by vallllliiii
                                  Hi, last month i bought a broken pc that i tought i can fix for myself but it turned out to be time consuming. The pc turn on and shows no display and beeps 5 times and restarts again and again, i think it s the motherboard because i tested/replaced all the parts except the motherboard. The pc was used mostly for light gaming and i think it wasnt overclocked or something. I tried all the basic fixes(cleaning the ram slots, removing the cmos battery, reseat the GPU/CPU/RAM). I think the last thing to do is to replace or repair the mobo but i prefer to try to repair because i don t want to spent...
                                  08-18-2024, 09:21 AM
                                • eccerr0r
                                  pairing DDR3 in supermicro boards...
                                  by eccerr0r
                                  I just found out my supermicro ddr3 motherboard enforces dual channel - if I have unpaired or incorrectly paired DIMMs in a bank, it will give up and start beeping... is this common on server boards?
                                  I was trying a combination of two 4GiB modules and an unpaired 8GiB module. The only combo that worked is if I had both 4GiB modules installed. Having either size paired with an empty slot or dissimilar module, the machine would beep memory failure on power up. My other DDR3 boards would happily deal with mismatched modules though may not enable dual channel.
                                  This is a microserver...
                                  06-13-2023, 09:54 AM
                                • eccerr0r
                                  DDR3/DDR4 laptop SODIMM to desktop DIMM adapters
                                  by eccerr0r
                                  Anyone have/use these SODIMM to desktop DIMM adapters, well, not to convert signaling types but just change socket types. Are they stable? Do they slow things down and force downclocks?
                                  I have an unused DDR3 4GB SODIMM and have a need for a 4GB DDR3 DIMM. Wondering if I should:
                                  - buy a 4GB DIMM (and selling the 4GB SODIMM seems unlikely)
                                  - get an adapter for the SODIMM?
                                  - Find a cheap 8GB DIMM somewhere and hope it's not a SODIMM...
                                  Though DDR3 is my highest technology module out there I suspect I really should be getting 8GB modules especially for a...
                                  03-02-2022, 01:56 AM
                                  Gigabyte GA-B150-HD3 DDR3-WP Motherboard Schematic
                                  Gigabyte GA-B150-HD3 DDR3-WP Motherboard Schematic...
                                  10-31-2024, 03:17 AM
                                  Gigabyte GA-H110M-S2V-DDR3 Motherboard Boardview
                                  Gigabyte GA-H110M-S2V-DDR3 Motherboard Boardview...
                                  10-26-2024, 03:36 AM
