Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
At first Glance: The new WD VelociRaptor
  • pentium
    • Mar 2006
    • 2778
    Info on the drive.
    Okay, so it is a a 10K rpm drive and so far the benchmark results have shown that the additional 2.5K rpm has sped reading and writing up but in all honesty I would be too scared to use the thing.
    With more than six years of searching the internet and two boxes of hard drives stored in my basement I have never seen a drive that is so small yet requires such a massive heatsink (and if you narrow down the field to drives used in PC's and not proprietary systems, any kind of heatsink at all).
    Ventilation would be a must and if someone had these in a RAID configuration, well there better be at least two fans on that drive cage.
    Other than that it seems like a good drive though with it's $300+ pricetag for just 300Gb of space I could not see myself getting one any time soon.
    Find Nedry!
    Check the Vending machines!!
  • kikkoman
    • Jul 2007
    • 691
    Re: At first Glance: The new WD VelociRaptor
    look at the specs... it only draws ~6W which is less than what most 3.5" disks need.
    2.5" disks run cooler anyway, so it's not gonna get MUCH hotter than a conventional 7.200rpm hdd with those fins I suppose.
    if there's a moderate airflow, a massive aluminium block would probably work, too.
    if the case design is crap however, even these fins won't help much. good they have a 5-year warranty.
    not that i wouldn't trust it (WD is still on my personal "good" list) but you get TWO samsung HD103UJ (1TB, 32MB cache, yeah) for the same money.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      looks like a SAS 2.5" with a sata connection instead, in a 3.5" frame
      SAS 2.5" are already with many installations in enterprise rackmount servers
      first time i saw them i thought if it is so small how can it be reliable.
      • gonzo0815
        • Feb 2006
        • 1600
        I would love to have this drive in an c2d laptop would make a really good desktop replacement.
        I hate expensive laptops with 5400rpm hdd`s only to get the runtime on the paper longer.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          yes it would be a dual purpose machine. notebook and sandwich toaster
          • Fatal0E
            • Jan 2004
            • 252
            I also thought about my laptop! But its to tall damnit!
            • zandrax
              Hit and miss
              • Dec 2007
              • 1157
              • Italy
              Pentium, the heatsink is so big because it adapts a 2.5" drive into a 3.5" slot. It has too few fins to be able to cool a very heating drive, so the drive itself doesn't heat much or WD made a wrong heatsink. Only time can reply.
              I think high speed drives aren't really a bargain: too expensive as disk drives and not many advantages over SSDs: Raptor strong point is its reduced latency wen compared to normal hard disks, but it's still higher that flash based devices (4 ms vs typical 0.1 ms).
              Just my 2 cents.
              Zandrax
              Have an happy life.
              • Kpug
                ROG flow z13 2023 gz301a, no life, no charge, no nothing
                by Kpug
                Earlier today I was using my rog flow z13 for programming and Arduino.
                Long story short I believe the Arduino backfed through my USB port, as when I plugged in the batteries (12v) into the circuit (for a motor driver, but the Arduino Uno was also connected for power when the robot is moving) my laptop immediately went blackout and unresponsive.
                Opened it up, unplugged the battery and cleared the power, which appeared to fix the machine. However when I closed the laptop fully back up It had returned to its bricked state.
                There is no charging...
                01-27-2026, 08:40 PM
              • TurcoLoco
                DELL U4320Qt Black Screen When On
                by TurcoLoco
                Happy New Year To All!
                This clean Dell U4320Qt monitor has no LEDs or screen when plugged in. I didn't feel any vibrations or noise either.
                My guess is something with the Power Board but as a noob, not sure.
                Upon close and careful glance at both the Power and the Controller board, no obvious faulty components or marks.
                I have not yet inject any power to the power board but when I plugged its power cord as normally done, no overheating components detected on thermal camera.
                I tried searching for this model here and online but no schematics I could find.
                Oddly...
                01-04-2026, 05:50 PM
              • Valtekken
                Lenovo IdeaPad 3 15ADA05 (model name 81W1) - Trying to flash the correct serial number, machine type and UUID without success
                by Valtekken
                Specs:
                • CPU=AMD Ryzen 5 3500U
                • GPU=(integrated) Radeon Vega Mobile
                • RAM=8GB (2x4GB, a 4GB set is soldered), DDR4; 1x4GB Ramaxel, 2400MT/s, RMSA3310MJ86H9F-3200; 1x4GB Micron, 2400 MT/s, no part number (soldered)
                • Storage=512GB, NVMe SSD, hfm512gdhtni-87a0b
                Hello everyone.
                My issue isn't massive, but I'd like to get this solved since I'm trying to fix a friend's laptop.
                A botched BIOS update by Lenovo bricked this laptop, so I used my BIOS programmer to reflash the BIOS on it and saved it from an early demise. All is good now, but the BIOS reports the S/N, MTM and UUID...
                09-10-2025, 04:14 PM
              • TamFishe
                ThinkPad X1C6 winbond 25q80dvsig chip dump request
                by TamFishe
                Hi, I got a ThinkPad x1 carbon 6th gen from a friend after in an attempt to fix it he ended up bricking the motherboard. today i tried plugging the laptop to the wall and i got no signs of life, despite the connections being proper. i've found out this winbond 25q80dvsig chip under a label near the usb c ports and i gave it a read, and the output has massive chunks of 0000 0000 0000 0000 followed by FFFF FFFF FFFF FFFF and sometimes some proper values scattered across the whole chip. I've attached the file because I've read people request it in order to fix it. Moderators, if I've posted this...
                08-22-2025, 02:20 AM
              • MaxonDomkrat
                Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                by MaxonDomkrat
                Hi everyone.
                I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                07-30-2025, 01:27 PM
