SSD reliability and interface discussion (Previously: HDD issues)
Re: HDD issues.
TLC based flash drives have much stronger ECC algorithms than SLC based ones, so you'll never see the effects of the much higher raw BER. At least that's what the endurance tests seem to be saying.
Also, because the capacity increases as the max P/E cycles decrease, the SSD will still last a very long time before it technically wears out.
For example, if you were to write 10GB of data per day over a period of 10 years, then that amounts to 36.5 TB. A 500GB SSD with perfect wear levelling and 1:1 write amplification would rack up only 73 P/E cycles.
I don't know anything about M.2 or M.4. Sorry.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Re: HDD issues.
I could not find the exact article that states what I have stated, either it is not on the web anymore or because I am using a public computer, now, it will not search the same as there is site controls on this computer. I did not say that they are less reliable then hard drives as I was stating one aspect. I think one of the most complete comparisons is found here https://en.wikipedia.org/wiki/Solid-state_drive. One time I called up Seagate and talk to their Engineering Technical Department. I ask them how long will a hard drive last. The answer I got is they can fail at any time so if you are storing something important you should have as many back ups as you can, at least 3. That is when I researched and found that magnetic reel to reel tape last the longest of all of the storage devices. That is why movie film has lasted so long. So if one whats to retrieve some information it would be best to load it on magnetic tape and store it. If you store it in climate control conditions you might get upwards of 100 years out of it. The only time you would use it is when you have lost all other copies. You could load it up and record it to another device and then put it back into storage. I do not have anything that is that important and most people don't, but for those who are in the extreme mind this might work. The M.2 and M.4 are suppose to be rivaling the solid state drives for speed because they are using solid state components in a parallel bus.
As for important files, backups are truly the only way to be 100% safe. There's RAID arrays that can help. RAID 5, one drive can die and you don't lose any data. There's even a RAID configuration where you can lose two drives and not lose any data. For important stuff though, it's best to keep a copy off site. At DCSI, we did tape backups and kept a copy in the backup building. When the flood hit, it really saved our butts! Everything in the building was lost. We never knew the water would get so high. When it got up to our necks, we abandoned the building. It just came so quick and without much warning. The river flooded. Lost over a million worth of equipment the papers said.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Re: HDD issues.
Loved following this thread up to about post 51.
Let me know if you want me to split the discussion of SSD drives into a new thread following that post, to make it easier to follow.
Also some information for you:
AHCI is an improvement for IDE, both support the TRIM command for SSD's.
This is in no way related to the physical interface which can also be IDE or SATA.
The IDE interface is limited to 133MB/sec, SATA 6Gbps is limited to 600MB/sec minus overhead which translates to ca 525MB/sec in the real world.
That is to say a 6Gbps SSD using the physical interface SATA can still have the IDE driver installed and reach the same performance.
Only some things like NCQ and power saving features will be missing.
SSD's have been limited by the SATA 6Gbps interface for years now.
As you can see in the Anandtech review linked above they all run into the same 525MB/sec bottleneck.
That is where the M.2 interface (formerly NGFF) comes into play. (Nothing called M.4 exists btw).
It introduces a new physical interface: PCI Express.
But it can also support SATA as a physical interface for backwards compatibility.
When running on the SATA physical interface M.2 is limited to the same 6Gbps as regular SATA is.
But when running in PCI Express mode the SSD can get up to a PCI Express x4 3.0 interface which translates to 32Gbps or 4000MB/sec.
As you can understand this is quite an improvement over SATA!
The PCI Express interface can also support a new logical interface: NVMe.
It's a driver like IDE or AHCI but developed for SSD's.
Remember AHCI was developed for mechanical HDD's so it has allot of unnecessary overhead for SSD's.
Also worth mentioning is that there was another successor planned for SATA.
It is called SATA Express but basically no devices have been released for it and the standard is dead.
The reason is the clunkiness of it's connector and the fact that it's a x2 PCI Express interface so only half the bandwidth that M.2 offers.
But of course a cabled interface is required, and this is where U.2 comes into play. (Formerly SFF-8639).
Basically it's a M.2 interface with a cable attached to it, even passive such adapters exist but also active.
Perhaps it would be best to split this off to a new topic around post #51 or so. Kinda drifted away from the original topic.
On a side note, I'm all about learning and I gotta say, the users here on BadCaps really gave me some great information and filled in some blanks! For that, I thank you all!-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Re: HDD issues.
I dunno Keeney123, Per Hansson seems to be real knowledgeable in this subject. I googled it just now (hoping I'd get 100$!) and all I could find where drives called M4, like Crucial's M4 and then some IBM drive. Could it be possible you mistook a drive that has M4 in it's name for an M.4 interface?-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Re: HDD issues.
http://www.goplextor.com/Product/Det..._Edition#/SpecComment
Re: HDD issues.
Spork I am going by and article I read on the internet writing by some professor I believe in Physics like at a place like Cal Tech. Please do not ask me to go back and verify this as I have been doing this way to much. I say if you do not believe me that is OK. I am not here for people to believe me. If you have refuting evidence I will take a look at it and decide for myself if it proves your point.Comment
Re: HDD issues.
I dunno Keeney123, Per Hansson seems to be real knowledgeable in this subject. I googled it just now (hoping I'd get 100$!) and all I could find where drives called M4, like Crucial's M4 and then some IBM drive. Could it be possible you mistook a drive that has M4 in it's name for an M.4 interface?Comment
Re: HDD issues.
So you would have to know the m.2 and m.4 to say you did not know anything about them. So where did you come across them.Comment
Re: HDD issues.
I can except that there is no M.4 spec. Do you all except that I saw on one of these manufacturer sites 6 months ago a M.4 spec, or not? I guess it does not really matter. As my father use to say in 100 years it really won't matter any how. I looked for about 4 hours through everything I could think off to find the M.4 spec. on the internet and was unable to find the original. As I said I thought it was on the Plextor site or it could had been the Kingston site.These were the two site in remember that had the PCIe card for the laptop. I did not find any of the M.4 on either of those sites. What I remember was that it showed the PCIe storage cards for all of the desktops and at the very end of them there where PCIe storage card for a laptop and there was one more card one could click on and that card had the M.4 listing. After looking through everything I can think of on the web I am in agreement that there is no M.4. However, I still would like to know where fzabkar came up with the M.4 if he never saw a M.4 listing.Last edited by keeney123; 09-20-2015, 06:58 PM.Comment
Re: HDD issues.
I was told by a professor in college, with solid state, even a thumb drive, you could put a file on it and just leave it some place on a shelf and in 100 years, it should still be readable. Do you know if this is true or not? He didn't say you could use the thumb drive for 100 years, just if you where to put a file on it and then store the thumb drive, 100 years later, it should still be recoverable.
Your explanation about the M.4 makes a lot of sense. I know here in the USA, we tend to outsource to other companies for motherboards and stuff like that because it's cheaper than paying American workers. I've noticed over the years, when dealing with people who speak a different language, stuff always seems to get lost in translation. I could easily see someone mistaking PCIe gen2X2 or whatever it was for M.4.
I really enjoy discussing this stuff, lot a funLast edited by Spork Schivago; 09-21-2015, 03:09 PM.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Re: HDD issues.
Man, you have a serious ego problem. For the second and final time, the reason that I know nothing about M.4 is because there is no such thing. You "came up with the M.4", nobody else did.Comment
Re: HDD issues.
I won't ask you to find proof or anything. I wasn't trying to imply that you where wrong. I was just trying to point out, for movies, the environment seems to be key. Without the humidity controlled, temperature controlled rooms, they tend not to last long. I'm sure VHS tapes are a bit different than the stuff they actually record movies onto when they make them at the studio's or whatever, but I know VHS tapes don't last very long at all. Floppy disks don't either. I've had some sitting on a shelf since 1999 or so, at my parents house, in a closet. 1.44MB 3 1/4 inch floppies. They all worked back then, but when I went to grab something off them a month or so back, maybe 1/4 of them where still readable in Linux. Most of the bad ones, I couldn't even format.
I really enjoy discussing this stuff, lot a funComment
Re: SSD reliability and interface discussion (Previously: HDD issues)
Here's an article that talks a little bit about the restoration project with Jaws. I don't know if this was the article I had read originally or not and I don't know if they talk about the producer talking about how the film was ruined when he went to play it off his shelf a few years later or whatever it was. My memory is all messed up so I might be remembering it incorrectly. Also, they're talking about 35mm film. Maybe you where talking about a different type of media and I just assumed it was the same? Anyway, here's the article. From what I've read, it's pretty interesting stuff. If this was the article I had read originally (and it appears to be in a similar format at least, from what I remember), it's what discouraged me from trying to digitally restore Top Cat. The one I read talked about how many people worked on, 24x7, for like two years or something! Going frame by frame or something like that. It kinda put things into perspective for me. Made me realize just doing 30 minutes of one Top Cat show would probably take my whole life!!!
https://library.creativecow.net/kauf...S-Resoration/1-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
Re: HDD issues.
No, I have never thought that you were calling me wrong. I find you to be a kind person. From what I read the solid state drives have a shelf life less than the hard drives. What I read about the hard drives is their self life is about 15 years. Of course none of that matters if you plug in the hard drive and it has a mechanical failure. I think the thumb drives have a charged cell as I remember and I would think it is a matter of time before that charge dissipates. Now, do not hold me to that like my life depended on it as some people would do. However, if do find that is contrary to something you come across I would appreciated it if you would present me that information so I might read it.
Mechanical hard drives have moving parts
Solid State hard drives have no moving parts
Moving parts will always fail, sooner or later.
With no moving parts, there's nothing to break, therefore, Solid State hard drives should last a life time, if you weren't using it (ie, the electronics will fail eventually, if you use them, etc).
Now though, more is known about solid states. I always try to "update" my information in my head when new information is available. I figured here would be the place to ask. I know I got a thumb drive, 1GB, my wife found, one of the first thumb drives I ever owned. I was shocked when she popped it in and we were able to successfully read the files. Then we found some smaller ones, 512MB for sure, but I want to say there was a 256MB as well! The 1GB one is a Lexar thumb drive. http://www.geeks.com/details.asp?inv...MC1GB-431-BULK
it's a weird one though, it must have some fancy internal power supply, because it has a little bar showing you how full it is.-- Law of Expanding Memory: Applications Will Also Expand Until RAM Is FullComment
There isn't normally a power supply in thumb drives. Perhaps it's an e-ink display that only requires power to change?
Seems so http://www.lexar.com/about/newsroom/...paper-display-
Flash memory suffers from wear and has a finite life span.Comment
Here is an article on electronic paper displays if you are interested. https://en.wikipedia.org/wiki/Electronic_paperComment
https://library.creativecow.net/kaufman_debra/JAWS-ResorationComment
by welpI have a PlayStation 5 CH-1215A with a Disk drive not reading disks anymore. (accepting and ejecting very slowly.)
Knowing the PS5 has a married daughter board for the disk drive I made sure to use that and replace the rest of the disk tray as it* was owned previously by an indoor smoker.
Once the job was complete and put back everything together, I tried to insert a disk with no luck at all...
So, I checked voltage going from the ps5 to the daughter board and am only getting the 5V rail.
With that knowledge I preceded to check all the fuses for the 12v rail on the main... -
by DynaxSCHi,
I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
The behaviour is also really very strange, i.e.:- The disk shows always up in BIOS - so it is recognized, so far so good
- POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
by chth96I bought 6 second hands odd $5 at a flea market and I found that 2 odd(GCC-4521B,TS-H192) won't read any disk.
But I measured all ESR value of SMD capacitor which is located on the TS-H192's PCB and replaced two capacitor which has higher ESR value.
And To My joy,this TS-H192 odd finally recognized burned CD as well as pressed CD.😂
But there was no more good fortune for GCC-4521B..In order to dead GCC-4521B back to life, I replaced three capacitor which has higher ESR value and I rubbed silicon grease on the every glides.I even brushed lens with cotton swab which was soaked...02-13-2024, 07:31 AM -
by madura2010Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
i checked the connectivity of ribbon=good communication with hard and motherboard
changed hard disk and checked=3f0 error persist
sata power=+5v available
Then checked data capacitors=all good
Then checked data lines path connectivity to pch=all good
reflashed... -
by duwaneHi All.
Sorry ahead of time for the text wall. This is a strange problem and I have tried to explain it as best I can. I realise this is a hardware forum (mostly), but I am still not sure if this is even a hardware fault! I am hoping that someone more knowledgeable than me in the area of understanding installation logs, or someone that has had a similar issue in the past may have some ideas of what might be causing this.
The issue:
Unable to do a clean install of any macOS versions supported for this model, even after fully erasing and formatting the internal SSD,... - Loading...
