Windows 8.1 -Digitally signed Drivers?
  • bigbeark
    • Jan 2010
    • 661
    I attempted to install a wireless Driver for my D-Link Xtreme N Dual Band USB Adapter on a Windows 8.1 desktop. Windows disallowed the install, even though I had downloaded the Driver from the D-Link website. The message advised me to go back to the D-Link website and get a "digitally signed" driver.
    There is only one Driver for Windows 8 in the D-Link site. I guess this is an older wireless card and D-Link does not want to pay MS to approve the Driver.
    Is this an issue for Windows 7 as well?
    I built this machine so my wife could do her genealogy program.
    Since then I have gotten her genealogy program to run under Linux.
    The D-Link card won't run under Linux without a lot of diddling around so it's just about useless.
    So much for Windows 8 and D-Link!
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8663
    Re: Windows 8.1 -Digitally signed Drivers?
    I can't really blame MS. They are tired of people blaming them for people who write bad drivers and the end user blames Windows for the crash when really it's the poorly written driver...
    I thought that driver signing was done since XP, but at least XP I recall it was possible to override.
    • Uranium-235
      Comrade Glimmer
      • Aug 2007
      • 5042
      • US
      use windows update and see if it offers a generic wireless chip driver from M$
      • diif
        • Feb 2014
        • 6978
        • England
        You can disable driver signing to install it.
        Hold shift and shutdown the PC
        On reboot click troubleshoot and then advanced options, then startup settings.
        F7 should be the key to disable driver signature enforcement.
        Reboot your PC and you should be able to install.
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          yeah but every time it will disable the device if you DON'T do that, here is a guide that should make it permanent, of course this is windows and it probably wont' work for some stupid reason
          http://www.isunshare.com/windows-8/h...8-and-8.1.html
          • osrex
            LED DRIVER KEEPS DYING
            by osrex
            Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
            i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
            i have no datasheet at all for the LED lights, all i have is its length.
            long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
            as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
            05-05-2025, 03:36 PM
          • howardc64
            Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
            by howardc64
            Problem
            Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
            Model & Board Pics
            Conflicting Spec
            Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
            https://www.shopjimmy.com/vizio-gj-2k1...
            10-10-2024, 01:16 PM
          • charif
            Audio Driver for Thomson P14C4BK128
            by charif
            Need Audio Driver for Thomson P14C4BK128 (Windows 10/11)
            I'm looking for help finding the correct audio driver for my Thomson P14C4BK128 laptop.
            The sound is not working properly, and I believe the audio driver is missing or not installed correctly.
            Here are the details:
            • Model: Thomson P14C4BK128
            • Operating System: Windows 10 64-bit
            If anyone has a working link to the driver or knows where I can download it, I'd really appreciate it.
            Thanks in advance for your help!
            04-30-2025, 05:41 PM
          • Daveleone
            UN55D6900 BN44-00428B partial led driver circuit failure
            by Daveleone
            Hello TV experts! I have a UN55D6900. The successfully TV turns on, and the backlights light up, and I get a picture, but there is a section that is dim. I took it apart and 1 out of 4 segments of backlight LEDs are not lighting on both sides of the TV (in other words, the same segment is out on both LED strips).
            I tested the LED strips with my LED tester and all of the LEDs light properly, so I believe the problem is with the PSU/LED driver board (BN44-00428B). The voltages at CNM810 (between PSU and main board) look ok to me. The voltages at CNL801A and CNL801B look off for one...
            07-23-2021, 06:31 PM
          • master3112
            Lenovo T480 NM-B501 no picture
            by master3112
            I have a T480. After pressing the power button, the device boots up. I can hear the Windows welcome melody. However, the screen remains black.
            The device has a CPU with an integrated GPU. If the device is switched on briefly without the CPU cooler, only the CPU core area heats up under the thermal camera. I measured the PU402 and PU403 inductors. These are responsible for the core voltage. I have 1.1V at these. Everything is OK, therefore the device starts up.
            But I have 0V at the PU404 inductor, which is responsible for the GPU voltage. The power management of the CPU is solved using...
            03-04-2025, 04:19 PM
