Re: Dropped PC - Bad HDD?
SeaTools is useless as a SMART diagnostic. It simply reports pass or fail. A drive could have 2500 reallocated sectors, but SeaTools would still tell you that it is OK.
To test the surface for "slow" sectors I recommend HDDScan (Windows) or MHDD (DOS, better). I like CrystalDiskInfo for SMART data. HD Tune's author doesn't understand that raw SMART values are 48/56-bit numbers, not 32-bit. Also, many attributes, eg Seek Error Rate, are more meaningful when expressed in hexadecimal rather than decimal.
Seagate's raw Seek Error Rate, Raw Read Error Rate and Hardware ECC Recovered SMART attributes are sector counts, not error counts. The numbers for RRER and HER steadily increase and eventually roll over to 0 before increasing again.
Seagate's Seek Error Rate, Raw Read Error Rate, and Hardware ECC Recovered SMART attributes:
http://www.users.on.net/~fzabkar/HDD..._RRER_HEC.html
The author of the BackBlaze blog does not understand Seagate's attributes. He invites people to explain them to him, which I did, but he appears to be too proud to amend his article.
I'm still using a 40GB Seagate drive that has had 50 or so bad sectors for the past 2 years, without increase. Modern drives, OTOH, tend to fail quickly after developing bad sectors. AIUI, these bads are not usually due to media problems, but weak heads, probably as a result of too many "head slaps".
All seagates increase the raw read error rate, seek error rate, and hardware ecc recovered, its something that all seagates do for some reason so your drive is probably fineLeave a comment:
Originally posted by Kevin!Errors in readings Seagate is a wrong value.
All seagates always worth reading errors are rising steadily, and this does not indicate a failure.
Raw Read Error Rate and Seek Error Rate can be ignored for Seagate hard drives. They will always show very high and ever-increasing values. In fact, I think I remember reading somewhere that these parameters were used to indicate something else for Seagate HDDs.
Either way, don't worry about those. Only look for increasing values in Reallocated Sector Count, Current Pending Sector Count, and sometimes Offline Scan Incorrect Sector Count.
That said, I would also like to point out that Seagate HDDs (especially older ones) often tend to develop a few bad sectors over time without affecting the reliability. I have quite a few Seagate HDDs like that - from Barracuda ATA-IV to 7200.10 series. I think I even posted the SMART logs for a few here (will look in my attachments if anyone is interested).
Originally posted by ChaosLegionnairethe only way to know for sure is to run a benchmark NOT an error scan judging from the error.
Have seen many HDDs (and from different brands) that were starting to go bad, and while some of them did not show anything with a surface read scan (like the free version of HDTune does), all of them acted weird with a benchmark test. Two of them, a Fujitsu MHW2120BH and a ST3500620AS, crashed. With the Fujitsu permanently (it had a head stuck on the platter that I got unstuck by opening the HDD, so I was expecting that HDD to fail).Last edited by momaka; 08-23-2015, 11:37 AM.Leave a comment:
hm... well might not be getting a new drive dont really want to put my friend on the hook for something yes it was his fault but i am the idiot that loaded the computer on the edge of the cart.Leave a comment:
This varies. Some drives will keep error counts when they write a sector, it fails, they swap it out, etc. until they find a good spare sector. Others don't. So two disks can read "no errors" even though one is down to its last spare block and the other hasn't touched a single one. Some WD's are like that. I have seen these on linux systems where they fail a SMART test, and I force it to swap it out by writing to that block with "dd", and when it is done all the relevant error counters are back to zero. Others keep accurate counts, so you can tell a good drive from a bad one.
Regarding the "rising error rate", I took that to mean that it was rising faster than before, that there had been some change. It is true that Seagate drives accumulate a huge number of certain types of errors normally.Leave a comment:
the only way to know for sure is to run a benchmark NOT an error scan judging from the error. excessive rises in the seek and read error rate and having a smart failure in the seek error rate primarily mean mechanical failure and/or mechanical defects in the drive head and/or actuator seeking to the wrong position thus resulting in a seek error.
bad sectors typically mean defects in the disk surface or the magnetic bipoles of the hard disk platters. damage to the disk surface is unlikely when the drive is off since the heads are in the park position. its more likely the head or actuator got jarred by the shock of the drop instead and developed mechanical issues. this is considered a type of mechanical failure of the hard drive and the hard drive should be replaced.
this can be proven by running a benchmark of the drive like i said. the speed graph should spike up and down and the seek time benchmark result should be abnormally high. sometimes the drive may even freeze and cause the test to be aborted with a read error msg.
i have a hard drive with the exact same issues as shovenose. the hard drive is considered toast if it exhibits the spikes and high seek times regardless of whether there are bad sectors or not since the hard drive will freeze and lock up your programs/games while using/playing them. its unusable and unplayable like this.
i'd be really pissed at your friend if he didnt compensate u for at least part of the cost of a new hard drive. if u want really reliable, then hitachi pwns all from the backblaze hard drive study.Last edited by ChaosLegionnaire; 08-22-2015, 11:23 AM.Leave a comment:
Your drive not only has 87,157 power on hours but 2,348,146 power cycles.That's over 2 million power cycles! Don't you think that's a tad unhealty?
I would also recommend replacing the OP's drive. Modern Seagate drives (desktop drives at least) aren't very good anyway.
Now I have it mounted on my server without hdd case with PSU FSP, and without any corrupt sector. Good Seagate
Many people have had problems, and more with the 7200.12 series,
but I had one and never entered BSY.
and a case of a family that has a 500GB Maxtor has 22.000h, and no faults.
Personally I prefer Seagate over WD in recent years. 7200.11 and 7200.10 series were crap though. I have deployed many ST1000DM003 through clients, friends, personal computers, and work and have had good luck. The few WD10EZEX I have used have been good as well.
The older WD Blacks and Greens are absolute garbage. The latest ones are fine. It bothers me they have a half dozen series now though.
I've also had WDC, but his performance in multitasking was appalling.
All drives get read errors. They are going to increase over time. The SMART read error rate is basically useless information as the links that Per gives show. In addition, it doesn't tell us what sectors are associated with the errors, it could be the same sectors giving read errors over and over again. It does not indicate the drive will fail soon. Of course back up data important to you, which should be done anyway, continue to use the drive and keep an eye on it. I have seen LOTS of drives suffer a fall (in and out of computers) and keep working just fine for years. If you want to replace the drive anyway of course that is your choice.
Bye (sorry my bad english)Last edited by kevin!; 08-22-2015, 10:24 AM.Leave a comment:
I don't know, I've seen just about all makes fail prematurely and I've seen all makes take a beating and get bad sectors and go on working fine for years. Modern drives in general aren't very good in my opinion. I don't always trust SMART data either. It's better than nothing to monitor disk condition though.
The older WD Blacks and Greens are absolute garbage. The latest ones are fine. It bothers me they have a half dozen series now though.Leave a comment:
I don't know, I've seen just about all makes fail prematurely and I've seen all makes take a beating and get bad sectors and go on working fine for years. Modern drives in general aren't very good in my opinion. I don't always trust SMART data either. It's better than nothing to monitor disk condition though.Leave a comment:
Look at my Seagate, it has the value of read errors that continues to rise, and already has 87,000 hours
The disc you can use, but do not use to store important things.
if the computer, she fell, off, I can say that this hard drive has not passed anything, because when you park off, and has a mechanism, in case of fall, the heads not moving.
ByeThat's over 2 million power cycles! Don't you think that's a tad unhealty?
I would also recommend replacing the OP's drive. Modern Seagate drives (desktop drives at least) aren't very good anyway.Leave a comment:
All drives get read errors. They are going to increase over time. The SMART read error rate is basically useless information as the links that Per gives show. In addition, it doesn't tell us what sectors are associated with the errors, it could be the same sectors giving read errors over and over again. It does not indicate the drive will fail soon. Of course back up data important to you, which should be done anyway, continue to use the drive and keep an eye on it. I have seen LOTS of drives suffer a fall (in and out of computers) and keep working just fine for years. If you want to replace the drive anyway of course that is your choice.Leave a comment:
See here:
https://www.backblaze.com/blog-smart...014-8.html#S7R
And here (SMART 1: Read_Error_Rate):
https://www.backblaze.com/blog/hard-drive-smart-stats/Leave a comment:
ByeLast edited by kevin!; 08-22-2015, 06:25 AM.Leave a comment:
SMART won't show any bad sectors until it reads them.Leave a comment:
what brand of drive?
Three years ago i knocked off a running 2tb samsung bare drive off my desk on to the floor, it made a loud bang. I thought for sure the drive was toasted. It was fine, the read and seek error rate kept climbing though. The drive is still running today without issues and in my desktop now.Leave a comment:
Three years ago I knocked off a running 2TB samsung bare drive off my desk on to the floor, it made a loud bang. I thought for sure the drive was toasted. It was fine, the read and seek error rate kept climbing though. The drive is still running today without issues and in my desktop now.Leave a comment:
yeah, that HDD is a goner... swap it NOW.Leave a comment:
by sam_sam_samI am thinking of buying a component tester but I want to get the most out of the device for the money that I am going to spend
Any idea but I would prefer actual use of the device it good points and it short comings be completely truthful about the review of the device
There are so many versions of this type of device and I do not have enough information to make a good decision at this point
When I bought my battery testing machine I had some information to go by because of electrical experience with auto electrical experience in this field job wise (... -
I am working on a 1992 Toyota pickup that has an electric speedometer. It is an analog needle speedometer and is driven by electricity.There is no cable. The transmission has a reed switch that sends a 12 volt pulse to the speedo 4 times per tire rotation.
According to GPS, the speedo is showing speed progressively slower below 50mph and progressively faster above 50mph. This also affects the odometer.
I've included a photo of the findings. The "control" is information I found on the net that correlates expected MPH based on a given hertz.
I removed... -
by fuxxyThis is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
Plug the set in, and it will turn on and functions with no issues.
After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes... -
by SluggerBSo I bought an 04 Ford Ranger, and it looks like the former owner made some electronic mods. I want to get rid of them and make this thing stock, but I'm not sure what I am looking at. I am hoping there is an overlap between computer electronics and truck mod electronic nerds here
Here is the microphone
It clips onto the visor, and has a wire that is (poorly) run behind the plastic cover over the corner pillar. That wire runs to below the steering wheel, and connects to this thing. Some sort of plug? The thin wire from the microphone is running to it,...-
MacBookPro 2012 15” A1398.
No visual damage was found.
Mac was inside of suitcase and it was inside of a bag.
Mac boots up,I can hear the chime,but the screen is totally black,not even “light” black. Caps lock light doesn't work.
I tried SMC,PRAM reset, didn't work.
Reconnecting screen display by unplugging those two things didn't work. I used this video
Reconnecting battery didn't work.
I also tried SMC,PRAM reset while the battery was disconnected and Mac was getting... - Loading...
