Dropped PC - Bad HDD?
  • mathog
    replied
    Re: Dropped PC - Bad HDD?
    Originally posted by shovenose
    So far nothing seems wrong just a massive amount of raw read errors and seek error rate and that number keeps getting higher and higher insanely quickly.
    In my experience once the error rates start ramping up on a disk, any error rates, the device will soon become useless. Dropping it may have broken off/knocked loose a bit of grit which is now dancing around on the platters. Get any data you want off that disk now.
  • shovenose
    replied
  • goontron
    replied
    Didn't even pop the side panel yet Everything seems to be working perfectly. I'll run an HDtune error scan and a SeaTools long test when I catch a few hours of sleep. So far so good. Basically it fell off the cart and everybody was like "OOOHHHH..." Thank god it was a shitty Dell Vostro 230 case (not the orignal internals of cuorse) not some fancy thing
    My laptop would not have even noticed the sudden change in height.
    replied
    i have a case for that type of treatment - came from ebay.
    it has big rubber corners like a speaker box, and a handle on top.
  • shovenose
    replied
    Originally posted by stj
    any cables loose?
    replied
    any cables loose?
  • shovenose
    started a topic Dropped PC - Bad HDD?
    So between the truck and the building at LANfest my friend dropped my computer. It seems to boot and SMART data shows no bad sectors but the read errors are going up rapidly. Is it broken?
    Component tester which one is worth the money from it capability to test and identify
    by sam_sam_sam
    I am thinking of buying a component tester but I want to get the most out of the device for the money that I am going to spend
    Any idea but I would prefer actual use of the device it good points and it short comings be completely truthful about the review of the device
    There are so many versions of this type of device and I do not have enough information to make a good decision at this point
    When I bought my battery testing machine I had some information to go by because of electrical experience with auto electrical experience in this field job wise (...
    06-30-2022, 08:23 PM
  • spleenharvester
    TP-Link Kasa KP105 - rapidly power cycling when plugged in
    by spleenharvester
    One of my KP105 smart plugs failed today. It started very rapidly power cycling (you could hear the relay clicking on and off and the LED was going green/orange repeatedly).
    I was going to just bin it but I opened it up out of curiosity. Found a swollen cap in the corner (bottom right of image). AiSHi brand, 470uF 10V 105*C. Not sure what purpose it serves exactly so can't comment on whether it is appropriately specced. Other members of this forum have reported similar findings with off-brand smart plugs but this is the first time I have seen evidence of this happening with a brand...
    05-21-2025, 11:26 AM
  • Jembang
    coocaa 50S5G smart tv dropped voltage when connecting power supply to mainboard
    by Jembang
    good day hoping someone can lend a hand, im repairing smart tv 50 inch, status when turning on back light is dim but you can see the tv logo then slowly fading out to black, i check the supply to tcon, i only read 5+v, must be 12v, i removed lvds cable and check voltage to mainboard turned on its also 5v, then i remove the cable mainboard to power supply, i read 12v in power supply, thinking that the problem is in the mainboard, coz theres 12v in power supply, i also check while turning on checking volts in main board 12v dropping to 5v, im just new repairing in TV, hope someone see my post t...
    11-01-2024, 09:55 AM
  • ranchhandbumper
    1992 Toyota Truck Speedometer
    by ranchhandbumper
    I am working on a 1992 Toyota pickup that has an electric speedometer. It is an analog needle speedometer and is driven by electricity.There is no cable. The transmission has a reed switch that sends a 12 volt pulse to the speedo 4 times per tire rotation.
    According to GPS, the speedo is showing speed progressively slower below 50mph and progressively faster above 50mph. This also affects the odometer.
    I've included a photo of the findings. The "control" is information I found on the net that correlates expected MPH based on a given hertz.
    I removed...
    11-12-2022, 08:12 PM
  • fuxxy
    Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
    by fuxxy
    This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
    Plug the set in, and it will turn on and functions with no issues.
    After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
    Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes...
    08-02-2022, 09:44 AM
