dont buy lenovo!
    • 31090
    dont buy lenovo!
    bastards!
    http://www.theregister.co.uk/2015/08...irmware_nasty/
  • c_hegge
    • Sep 2009
    • 5219
    Re: dont buy lenovo!
    So? It's all fixed now. At least they did the right thing by fixing the problem, rather than just shoving it under the carpet and pretending it never happened. I'd have very little hesitation about buying a new Thinkpad, in spite of this. They are still one of the few laptops left with 3-button Tackpoints (other than a handful of Dell Latitudes)
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      ^Dell latitude for the win. Screw lenovo, they inherited IBM's dirty tactics and made them worse (whitelisted bios, blacklisted wifi cards, etc.). Add shitty build quality and I don't see any good reason.
      Then again, they did get Ashton Kutcher for a spokesperson (a lot of the Yoga ads at least)... so if you buy lenovo, you got Punk'd!
      sigpic
      (Insert witty quote here)
        • 31090
        they didnt fix anything.
        they put a tool online to disable (NOT remove) the function if you actually find it.
        why didnt they put it in a bios update?
        because they didnt want to remove it.
        • c_hegge
          • Sep 2009
          • 5219
          Add *censored* build quality and I don't see any good reason.
          Half agreed. That's true of the IdeaPads and other consumer-oriented products, but Thinkapds (particularly T series) are built like tanks - even more so than modern Dell Latitudes IMO. I hate the way that Dell shaft retailers too by not allowing any of their products to be sold except through them directly. They are worse than Apple in that regard.
          That's good enough IMO. As long as it's not active I couldn't care less.
          • diif
            • Feb 2014
            • 6978
            • England
            They fixed it by removing it from newer laptops.
            Over here we can buy Dell from supermarkets and third party sellers you don't have to buy direct.
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              Umm, updated BIOS files are right there in the article you linked
              https://support.lenovo.com/us/en/pro..._bios_notebook
              • Mad_Professor
                A Mech Warrior
                • Feb 2011
                • 1587
                I don't know about that. I like my lenovo y480, it seems pretty well built, doesn't flex, and the screen doesn't feel like it's going to break off it's hinges and it's held up pretty good for last 2 years; unlike the flimsy toshiba's and hp's I've worked on and repair numerous times.
                  • 31090
                  it sounds like we need a tool to display what's in this bios table - and maybe edit it.
                  and not just for lenovo.
                  think of the evil company's could get upto with that function!
                  install win10 and it could copy the win10 installer into the bios to stop you downgrading to 7 afterwards.
                  that's just one possible (miss)use.
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Who is we ? the common user that doesn't have a clue or professional techs that are now aware of this. A tool to edit the BIOS is just another attack vector for miscreants to abuse.
                    What needs to be done is a way to disable WPBT or not have it in the first place.
                      • 31090
                      it's all about the bios, if some scum like ms has had the bios compromised then your shit-out-of-luck because it's the first thing that gets executed.
                      you want to talk about "attack vector for miscreants to abuse." then i give you the UEFI bios.
                      that can have extensions installed by trusted sources. IE: windows.
                      • goodpsusearch
                        • Oct 2009
                        • 2850
                        • Greece
                        I am shocked by Dell policy about the AC adapter. A client brought in a Latitude for service. Among other issues, the battery wasn't charging. I already knew that Dell and HP had this 3rd identification pin and when the cable breaks the laptop would start complaining if you are lucky or stop charging the battery.
                        What I didn't know and found using the laptop is that the bios locked the centrino dual core 2.2GHz processor at......... 600MHZ!
                        This is terrible. none should have the right to do that. When you buy a product you pay for a certain cpu, RAM hdd, gpu etc. This lockdown of speed makes the laptop a completely different product.
                        The worst part is that more than 90 percent of users won't even notice what happened and would continue using the laptop but their everyday user experience will change dramatically.
                        From yesterday I advise everyone that I know against buying a Dell laptop.
                        Notice that this happens with the original ac adapter, not with a third party and that the signal cable and pin are ridiculously thin and fragile.
                        • kevin!
                          recapping PCB.
                          • Jul 2013
                          • 195
                          • España
                          How sad...
                          With how good they were the IBM ThinkPad at the time ...
                          I now trust only on portable MSI, Acer, Asus.
                          between malware Internet Explorer, and now this BIOS, will run out of customers.
                          To my Lenovo he has died.
                          When you change the wifi card in my HP, I found that it was not compatible ...
                          Upon seeing the tactics of HP and DELL with their BIOS, stop buying these brands.
                          Bye
                          Gaming pc:
                          nVidia RTX 3080 TI, Corsair RM750I.
                          Workshop PC:
                          Intel core i5 8400, Intel SSD 256GB, nvidia gt1030, asus b365-a.
                          Server:
                            "why didnt they put it in a bios update?
                            because they didnt want to remove it."
                            Owners of LSE-afflicted computers urged to update their firmware
                            A tool quietly released on July 31 will uninstall the engine if it is present in your machine: it is available here for notebooks, and available here for desktops.
                            On Tuesday this week, Lenovo published a full list of affected desktop and notebook models. Desktop machines built between October 23, 2014 and April 10, 2015, with Windows 8 preinstalled, have the LSE inside them.
                            http://support.lenovo.com/nz/en/downloads/ds104373
                            Think-branded PCs did not include the LSE, we're told.
                              • 31090
                              standard "feature", runs the cpu at lowest frequency, refuses to charge the battery.
                              going into the bios gives a message about unrecognised charger.
                              i'm surprised nobody has released a patched bios yet though.
                                Lenovo 3000 Series Schematic
                                Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                3000 C100 laptop with Braille keyboard
                                Lenovo 3000 C
                                C100, C200 - 15-inch XGA screen
                                Lenovo 3000 N
                                N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                N500 - 15.4 inch screen.
                                Lenovo 3000 V
                                V100, V200 - 12.1-inch WXGA models
                                Lenovo 3000 G
                                G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                10-04-2024, 06:05 AM
                                Lenovo IdeaPad 120S Notebook 100 Specification for Upgrade or Repair
                                This specification for the Lenovo IdeaPad 120S Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 120S boardview and 120S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 120S...
                                09-06-2024, 06:40 AM
                                This specification for the Lenovo IdeaPad 320 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 320 boardview and 320 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad 320...
                                09-06-2024, 06:06 AM
                              • derradji89
                                Need help Lenovo MIX 320-10lCR domaine name SERCOL
                                by derradji89
                                Hi everyone 🤗
                                I have a Lenovo MIX 320-10lCR computer.**
                                1. **Operating System**: Windows 10 ** Education** 64-bit.
                                2. **User Account Restrictions**: The account I'm using has heavily restricted permissions via **UAC** and **Group Policy**. This means I cannot install any software without admin rights, adjust system time, run Command Prompt as administrator, or modify the registry via Regedit—all are blocked.
                                3. **BIOS Password Protection**: The BIOS is locked with a password, preventing me from installing a new operating system.
                                4. **BIOS Chip Reflashing**: Currently,...
                                04-19-2025, 03:04 PM
                                LENOVO Legion Y720 Legion i7-7700 Specification for Upgrade or Repair
                                This specification for the LENOVO Legion Y720 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Legion Y720 boardview and Legion Y720 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for LENOVO Legion...
                                09-12-2024, 02:30 PM
