My Proc-Mobo Combo Choice......
  • grss1982
    • Mar 2007
    • 225
    • Philippines
    Re: My Proc-Mobo Combo Choice......
    Originally posted by Bookworm
    Y'know.. I wonder if the MSI utility is _adding_ the temperatures together, or something similar.
    I thought that as well, but its doesn't add up. (pun intended)
    Core 0 = 29C
    Core 1 = 36C
    SO..... 29C + 36C = 65C
    MSI Utility & the bios says: 57C
    CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
    GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
    Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
    • grss1982
      • Mar 2007
      • 225
      • Philippines
      ALSO...... anybody know a good benchmark for dual cores. Currently the Prime 95 I'm using can barely heat this thing up.
      • acstech
        GrumpyModerator
        • Jul 2007
        • 1432
        Take a look in the task manager. Is Prime95 loading both cores 100%?
        Are you using the latest version of Prime95? Latest is v.256. Some of the earlier versions were single threaded, and as such only load one core. See here:
        http://www.mersenne.org/gimps/
        I usually leave the motherboard software in the box. Then, I'll use this to monitor things in Windows:
        http://www.almico.com/sfdownload.php
        Another interesting program to monitor frequencies and stuff:
        http://www.cpuid.com/cpuz.php
        A man convinced against his will is of the same opinion still.
        • grss1982
          • Mar 2007
          • 225
          • Philippines
          I'm using CPU-Z 1.43, p95v2414 & Speedfan 4.31. I think I', gona get the newer versions. THANKS
          • acstech
            GrumpyModerator
            • Jul 2007
            • 1432
            Yep, 2414 is only going to load the one core, unless you run two instances of it.
            • zandrax
              Hit and miss
              • Dec 2007
              • 1157
              • Italy
              #26
              Originally posted by grss1982
              @zandrax: This one's for you :
              Readings on my PSU through the Bios then through MSI Utility. :-) Appreantly you were right. High +5v and low +12v. I pretty much suck at math though, so I'm not sure about this statement of yours: (5% on 5 v and 10% on 12 v)
              Sorry: it's 5% tolerance on both 5 v and 12 v - see the latest ATX specs, chapter 4.1.4.
              + and - 5% tolerance on 5 v line means voltage can fluctuate from 4.75 v (5 v - 5% of 5 v = 5 - 0.25 = 4.75 v) to 5.25 v (5 v + 5%); 12 v can do from 11.4 to 12.6.
              If the hardware monitor is trustworthly, your voltages (4.9 and 11.75) are lower than their nominal values but within tolerances: check them during intensive workload (e.g. prime95 while scanning or defragmenting your drive).
              Last words: did you overvolt slightly your memories? Standard DDR2 voltage should be 1.8 v
              Zandrax
              Have an happy life.
              • grss1982
                • Mar 2007
                • 225
                • Philippines
                #27
                Zandrax
                No. In bios its actually set on "AUTO." Bare in mind though that my memory sticks are Corsair Value Select DDR2 533MHz. (VS1GB533D2)
                Should I set it to 1.8v as a precaution? I did play like four hours of Counter Strike: Source while running a single instance of an old version of Prime95 (Not optimized for dual cores), and no problems were encountered, I plan to do some more stress testing in the next few weeks.
                • zandrax
                  Hit and miss
                  • Dec 2007
                  • 1157
                  • Italy
                  #28
                  Try setting the sandard voltage and testing with memtest if it runs stable: sometimes a voltage increase can make cpus and ram more stable, but never abuse of: heat production depens linearly from working frequency and on the square of voltage, so the more you increase the hotter it will be.
                  Set the lover setting at which your pc runs fine.
                  Zandrax
                  Have an happy life.
                  • grss1982
                    • Mar 2007
                    • 225
                    • Philippines
                    #29
                    Zandrax
                    Hmmm...... now that you mention it, my the sinlge chipset on my mobo does run a bit HOT. I think I'll lower the voltages.
                    Again, Thanks.
                    • grss1982
                      • Mar 2007
                      • 225
                      • Philippines
                      #30
                      Hmmm...... now that you mention it, the sinlge chipset on my mobo does run a bit HOT. I think I'll lower the voltages.
                      Again, Thanks.
                      Uhhhhmmmm..... looks like there's no way of adjusting it xandrax. Already I've updated to the latest bios, and there is still now way to manipulate the RAM voltage. The bios says taht 1.9V IS the default of my DDR2 533 sticks. :-(
                      • zandrax
                        Hit and miss
                        • Dec 2007
                        • 1157
                        • Italy
                        #31
                        Well, leave it at 1.9 v: it's about 5.5% more than 1.8, so the heat increase should be around 11% (1.055 ^2 = 1.11). A bit warmer but not hot.
                        The chipset runs warm, sometimes hot because it's a single chip solution: try installing a fan on its heatsink.
                        Zandrax
                        Have an happy life.
                        • grss1982
                          • Mar 2007
                          • 225
                          • Philippines
                          #32
                          Zandrax
                          Already planning to this weekend. How does a 70mm Delta fan from an AMD Stock HSF sound?
                          Also, I've tidied up the cabling. PLUS, I installed a 120mm fan on the side panel. It's blowing air into the Processor socket and RAM area.
                          Again, thanks for your helps zandrax.
                          • grss1982
                            • Mar 2007
                            • 225
                            • Philippines
                            #33
                            @zandrax: I think I finally found something to stress this rig to the point of locking up and only pressing the reset would solve it.
                            Recently played CS:S on this thing with all settings on high, before i played CS:S with all the settings down, recently i played at high settings, thus stressing the P.C. to the limits.
                            As I play CSS with high settings I have encountered lock-ups that render the rig unusable with only a press of the reset button as the remedy. I've noticed that after i rebooted from the lockup the 12v on my rig drops from the "11.9" value to "11.7," according to the bios's temp readings.
                            I'm thinking the PSU is the culprit.
                            I might get one that's of the ATX 2.2 standard instead of something this old (ATX 2.0). I'm actually thinking of getting one of these:
                            http://www.silverstonetek.com/produc...st400&area=usa
                            It's supposedly an FSP design. :-)
                            • acstech
                              GrumpyModerator
                              • Jul 2007
                              • 1432
                              Hook up a multimeter to the 12v line and then go watch it when you're stressing it. That's when you'll see the biggest movement. It should recover fairly quickly after the load is removed. The only thing left would be heat related. If it's changing that much due to heat, ugh...
                              I'd just get the FSP. It's cheaper. Also note the ratings comapred to the Silverstone.
                              http://www.newegg.com/Product/Produc...82E16817104952
                              • grss1982
                                • Mar 2007
                                • 225
                                • Philippines
                                #35
                                thanks acstech. :-)
                                Anyways another issue:
                                I wanted to make this an FYI to Brisbane users.
                                Apparently, according to this thread here: http://www.xtremesystems.org/forums/...103639&page=15
                                Also read here: http://forums.amd.com/forum/messagev...&enterthread=y
                                AMD has reported the DTS on Brisbanes as being "broken"
                                NOTE: Intel and AMD recently published detailed, public information about the "DTS" (Digital Thermal Sensor), which provides much higher accuracy and more relevant temperature reading than the standard thermal diode sensors do.
                                This would mean that even using Core Temp you are not getting the accurate measurements on the temps of your processor's cores., specifcally on the Athlon x2 (Brisbanes only)
                                • acstech
                                  GrumpyModerator
                                  • Jul 2007
                                  • 1432
                                  Huh. The Brisbanes on the Biostar boards I have, and have sold, have all worked correctly. On cold boot, going into the bios, they report ambient temp, then climb from there.
                                  In Windows I generally use Speedfan to read temperatures.
                                  http://www.almico.com/speedfan.php
                                  I've also seen some pretty screwed up included motherboard software, so I have to wonder if software isn't part of the problem people are having with temp readings.
                                  Like I say, I've never had a problem with it. Of course I never use the motherboard disk for anything but the ethernet driver...
                                  • grss1982
                                    • Mar 2007
                                    • 225
                                    • Philippines
                                    #37
                                    @acstech:
                                    My mobo is fairly new that Speedfan does'nt detect any sensors, heck it doesn't even know what the freakin chipset is!!!!
                                    Mobo: MSI K9N Neo-F V3 From what I gather its an Nforce 560
                                    (linky: ttp://www.msicomputer.com/product/p_spec.asp?model=K9N_Neo-F_V3&class=mb)
                                    • acstech
                                      GrumpyModerator
                                      • Jul 2007
                                      • 1432
                                      I try and avoid MSI whenever possible. I had some bad experiences with them over the years. Bad caps, unstable boards, etc. Maybe they've got better recently.
                                      I'm sure you are, but I have to ask: Are you using the latest version of Speedfan?
                                      http://www.almico.com/speedfan433.exe
                                      I've found that speedfan might not label the processor temperature correctly. Have it running and watch when you start a P95 torture test. The one that goes up quickly will be the processor.
                                      Did you ever download the newest version of Prime95?
                                      32 bit version:
                                      http://www.mersenne.org/gimps/p95v256.zip
                                      64 bit version:
                                      http://www.mersenne.org/gimps/p64v256.zip
                                      Linux 32 bit version:
                                      http://www.mersenne.org/gimps/mprime256.tar.gz
                                      Linux 64 bit version:
                                      http://www.mersenne.org/gimps/mprime255-linux64.tar.gz
                                      For memory testing, I usually do a custom test, run the FFT's in place, and set the size from double the total L2 cache size (minimum), to quadruple the total L2 cache size (maximum).
                                      For processor testing, run the small FFT's.
                                      Let it go for about 6 hours. Overnight is usually good. Once you get it set to where it doesn't crash, let it go for 24 hours. When it can pass that on both above settings, then it should be stable.
                                      Have the multimeter plugged into the 12v when you start the tests. You might be surprised.
                                      • grss1982
                                        • Mar 2007
                                        • 225
                                        • Philippines
                                        #39
                                        @acstech:
                                        Yes indeed, I did use v4.33. I just looked at it last nyt and it seems the only temps listed are that of the GPU and core 0 at 21c, which by the way is quite ridiculous for Brisbane with stock cooling. Chipset remains unidentified. No voltages and fan speed is detected or shown by SF 4.33.
                                        Downloaded and used p95v256.zip (32-bit) as well. ;-)
                                        • zandrax
                                          Hit and miss
                                          • Dec 2007
                                          • 1157
                                          • Italy
                                          #40
                                          @ grss: I didn't reply before because I was really busy. Change your psu, this behaviour is far from being normal. As astech pointed out, voltages should recover in a small time (a couple of second or less) otherwise your psu is faulty.
                                          If Speedfan doesn't recognize your hardware monitor (which is different from your chipset), then you should try RMClock or Notebook Hardware Control: the former is very detailed, showing both load and temperature of the two cores and allowing you to undervolt the cpu; the latter is notebook oriented and is recommended only if RMClock should crash.
                                          Zandrax
                                          Have an happy life.
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • r3vsEngIT
                                            ALPS Electric BT/WLAN Combo Module Experiment
                                            by r3vsEngIT
                                            i have a 2017 volvo that i upgraded the stereo in but the week link now is the SBC codec the head unit uses to transmit audio. i took the unit apart and we have a UGKZ2 combo module with a CSR8311 bt chip. after some research it is my understanding that ALPS made another combo module that used the CSR8350 chip. this chip is capable of aptx. https://vehicle-electronics.biz/cont...s-alps-modules
                                            my question is, would it be possible to swap out this UGX module as plug n play? what about replacing the CSR chip itself? any idea where to get either?
                                            03-06-2025, 11:11 AM
                                          • Cerberuska
                                            Mobo MSI B550-A PRO password popup
                                            by Cerberuska
                                            Hello guys,
                                            I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                                            BIOS I updated to last one.
                                            any suggestions?
                                            And same thing for two different 5600G, and yes, MoBo supposed to support it.
                                            Thank you...
                                            11-10-2024, 01:23 PM
                                          • mrsith
                                            Dell G3 17 3779 - no display after mobo replacement
                                            by mrsith
                                            Hi guys,
                                            I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                                            Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                                            04-30-2023, 05:11 AM
                                          • Ibod
                                            Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                                            by Ibod
                                            HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                                            With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                                            Not sure where to go from here ?
                                            Is the PSU at fault or is the mobo causing the problem
                                            Look forward to any help :-)
                                            If I plug the 24...
                                            02-08-2023, 11:00 AM
