ALPS Electric BT/WLAN Combo Module Experiment
  • r3vsEngIT
    • Jul 2023
    • 7
    i have a 2017 volvo that i upgraded the stereo in but the week link now is the SBC codec the head unit uses to transmit audio. i took the unit apart and we have a UGKZ2 combo module with a CSR8311 bt chip. after some research it is my understanding that ALPS made another combo module that used the CSR8350 chip. this chip is capable of aptx. https://vehicle-electronics.biz/cont...s-alps-modules
    my question is, would it be possible to swap out this UGX module as plug n play? what about replacing the CSR chip itself? any idea where to get either?
Name:	Screenshot 2025-03-06 120958.jpg
    • 31286
    they are probably on aliexpress,
    but get the datasheets and compare pinouts and software compatability.
    • r3vsEngIT
      • Jul 2023
      • 7
      i've looked there and all over the internet for the past two days. the information on these ALPS modules is very scarce. using FCCid i have pieced together bits of information from similar modules but i cannot find any of these UGX modules for sale. i cannot even find the CSR8350 chip they are talking about in this article. it's odd.
      • ss45
        Soldered WLAN module replacement, any catch ?
        by ss45
        Hi guys
        ive got spectre 15 with WLAN module soldered
        in the windows device manager the device gave error 10 code.
        It is a common complain, user has to shipped the laptop back to HP for service since its a hardware problem. disabling reenabling or reinstall driver didnt help
        Can i easily order new WLAN module of the same model (Ax201),
        unsolder the damaged one, then solder new one onto the board ?
        Is there any ROM programming involved ?
        For reference the module looks like this onboard
        https://www.notebookcheck.net/file...
        07-24-2023, 02:10 AM
      • AlexVG
        Replacing the WiFi module on a vacuum cleaner iROBOT i7
        by AlexVG
        I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
        I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
        (This board does not respond, only the LEDs light up in a circle.
        The liquid damage is catastrophic and restoration is impractical).
        (I bought this board to get the WiFi module and camera).
        The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
        If...
        10-22-2024, 07:20 AM
      • japlytic
        DRIVER_PNP_WATCHDOG error re. old drivers in Windows 11 install image
        by japlytic
        In a Beelink GTR mini PC, mine has an Intel AX200NGW WLAN module.
        Tried (only with keyboard/mouse connected):
        • BIOS + database update
        • Using latest Windows 11 image built with official image creation tool
        • Previous setup version for Windows 11 installer
        • Replacing SSD without a slow block (the previous SSD had a slow block with access time > 500 mS)
        • TPM reset (worked to the point where DRIVER_PNP_WATCHDOG error message is displayed briefly after the point of stalling)
        • Disabling power to WLAN and LAN modules in BIOS (Advanced > AMD PBS > PCI Express Configuration)
        06-19-2025, 04:59 PM
      • repair-it
        TOSHIBA DLP 52HM95 How to reset timer module on bulb
        by repair-it
        I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
        Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
        10-11-2023, 07:18 PM
      • clmorre
        wireless module not supported wlan module id 702
        by clmorre
        Can someone help me regarding "wireless module not supported wlan module id 702"?
        board code is da0ax2mb6f0 rev f
        Is it possible to edit the bios?...
        01-05-2021, 01:10 AM
