Pc fan help
  • ITSYSTEMSALBANIA
    • Mar 2015
    • 37
    • Albania
    Pc fan help
    Hi all i want to know the name of that white plastic ring.Thank you all.
  • keeney123
    Lauren
    • Sep 2014
    • 2536
    Re: Pc fan help
    I do not usually take these fans apart, but it looks like a plastic lock washer.
      • 30934
      Re: Pc fan help
      sometimes called a nylon split-washer.
      but split washers can also refer to locking metal washers so be carefull.
      a circlip would be a good replacement if the thickness matches.
      • ITSYSTEMSALBANIA
        • Mar 2015
        • 37
        • Albania
        Re: Pc fan help
        I want to buy some of this can anybody provide me a link where i can buy.
        • brethin
          • Dec 2008
          • 1907
          Re: Pc fan help
          You don't need to replace them, as they provide no real function. just add a few drops of oil and make sure you cover the hole with a sticker or something to keep dust and dirt out and the oil in.
            • 30934
            Re: Pc fan help
            no real function till you move the equipment and the blades start shifting around.
            • brethin
              • Dec 2008
              • 1907
              Re: Pc fan help
              The blades aren't going anywhere. Its a paper washer its not a shaft ring, the shaft is not going to fall out or anything of the sort, it was just a paper seal to keep dust out and oil in.
              • c_hegge
                • Sep 2009
                • 5219
                Re: Pc fan help
                No. That is the plastic shaft ring which keeps the shaft in place.
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  Re: Pc fan help
                  Usually a lock washer whether it is plastic or metal is use to keep tension on a nut so the nut will not loosen up.
                    Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                    The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                    Securing a good thermal interface between...
                    10-07-2024, 04:35 AM
                  • RolandVossen
                    How do I remove a plastic split washer from a VHS VCR ?
                    by RolandVossen
                    I am trying to repair a JVC HR-D530E VHS recorder, the cassette does not eject. I discovered that the rubber belt of the loading motor is slipping, so I'd like to replace it. I think I have to remove the (nylon?) washers at each end of the worm axel, labeled '2' in the photo. I tried using a small screwdriver and a pair of tweezers, but to no avail.
                    Is there perhaps a special tool or a trick required to remove these ?
                    Thanks in advance, Roland.
                    12-30-2023, 07:48 AM
                  • howardc64
                    by howardc64
                    Problem
                    08-04-2024, 10:36 PM
                  • corrize
                    Desoldering - soldering BGA chip close plastic mini fpc connectors ?
                    by corrize
                    Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
                    There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
                    I have :
                    - hot air, and a
                    ll stuff around
                    - true kapton tape
                    - 140 and 180 degree soldering paste
                    - bismuth
                    - little hot plate 250 degree max
                    - the new BGA chip with probably
                    05-20-2025, 01:26 AM
                  • corrize
                    Soldering plastic low profile FPC close camera CMOS sensor ?
                    by corrize
                    Hello, I will have to solder a very small FPC connector (pins : 0.3mm), on the pcb of CMOS sensor, it is very close. I was surprised by movie on ytb, someone soldering directly with hot air directly on the sensor without kapton, nothing.
                    CMOS sensor seems resist to high temps.
                    But I also directly saw sensor broken because a blocked motor at the corner became very hot and probably bent the metal frame and cracked the sensor.
                    I have low melting point solder.
                    I will probably test hot air directly on one of plastic connector (I have a lot) at 320 degree on a test
                    07-12-2024, 02:21 PM
