How do I remove a plastic split washer from a VHS VCR ?
  • RolandVossen
    • May 2023
    • 11
    • Nederland
    I am trying to repair a JVC HR-D530E VHS recorder, the cassette does not eject. I discovered that the rubber belt of the loading motor is slipping, so I'd like to replace it. I think I have to remove the (nylon?) washers at each end of the worm axel, labeled '2' in the photo. I tried using a small screwdriver and a pair of tweezers, but to no avail.
    Is there perhaps a special tool or a trick required to remove these ?
    Thanks in advance, Roland.
  • nomoresonys
    • 12323
    • U.S.
    Should pop off without much trouble, maybe use a straight tip screwdriver to spread it a little.
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • Kemer
      Led status indicator light transfer plastic
      by Kemer
      Hello, the LED status indicators on my Lenovo Z580 are not working. Actually the motherboard LEDs are working but the light doesn''t coming to the front view. The plastic part is which you can see in photo must transfer the light to the frontview but just half of the plastic is illuminating.
      There are three status indicators on the front (power, battery, caps lock), and none of them are illuminated.
      The plastic piece doesn't appear to be broken.
      1. What are your suggestions for resolving this issue?
      2. Is the plastic piece made of special ma...
      08-19-2025, 07:02 PM
    • acedogblast
      by acedogblast
      11-02-2024, 05:13 PM
      Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
      The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
      Securing a good thermal interface between...
      10-07-2024, 04:35 AM
    • longmt1990
      Panasonic Cf-w5 bios password remove
      by longmt1990
      Hi, i have a Panasonic Cf-W5 with the bios password, I tried remove cmos but problem didnot solve.
      I uploaded the picture after remove cmos battery, It look like this is a Phoenix bios. The bios dump file in the link i attached
      Please help me remove bios password.
      Thank you so much
      07-06-2025, 10:50 PM
