Wassa Good Burn-in/Testing Program? ??
    I want something that doesn't require a full blown OS install to run it so I can move it from MoBo to MoBo without reconfiguring the software/drivers.
    - But it needs to actually work/test everything. (As much as possible.)
    All the ones I have now are Windows based.
    Only had to do this now and then the last couple years but I have about 40 boards I need to go through at the moment and I don't wanna fuss with the software.
    Any good ones that I can add to say a Knoppix or Ubuntu CD or something?
    Recommendations???
    ~~ Pretty Please ~~
    Mann-Made Global Warming.
    - Dr Seuss
    Re: Wassa Good Burn-in/Testing Program? ??
    Most products that you need cost money.
    I guess you are aware of Ultra-X: http://www.uxd.com/
    I have in past purchased from a company called Toolstar. They has good software that loadeda minimal op system and tested most functions.
    Check this out: http://www.majorgeeks.com/ToolStar_Test_d349.html
    Google: toolstar
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
      In past I used Hot Cpu Tester Lite (freeware), but it requires Windows.
      Now I use Ultimate Boot CD: a linux based cd with some nice dos diagnostics and tools.
      There isn't a burn-in tool, but Mersenne test (for cpus), Memtest (ram) and drive diagnostics (hard disks) work fine for me as a replacement.
      Zandrax
      Have an happy life.
        I use UBCD also. There should be Lucifer, a system burn in prog, and CPU burn on there.
          Another alternative is using BART-PE to run diagnostics programs from a known-good operating system.
          The problem with BART is, the application programs have to be stand-alone execution, not the usual Registry + "do you want to reboot now" crap. That means the programmer actually has to know something, other than how to call the endless stream of Microsoft macros.
          I use BART with the DriverPack mass storage drivers. This lets it load on any current or obsolete disk controller system. All I have to do is keep the .7Z driver pack file current when I recompile BART. I do this regularly, to keep my antivirus files current.
