Samsung UE43J5500 No red light despite PSU testing good
  • madyoyo
    • Aug 2018
    • 12
    • france
    Hi everybody.
    I have a Samsung UE43J5500 with a bad main board: No red light, and zero reaction from the remote or the power button. The PSU seems ok: 8.6V when plugged in, 12V and the backlight turning on when disconnected from main board. I also found 3.3v at the ir receiver, the power button also seems ok (i get 1.8v at the key_input1 test point, and it drops to zero when the button is pressed.
    Is there anything i can try before tossing this board? I'm running out of ideas
  • madyoyo
    • Aug 2018
    • 12
    • france
    Re: Samsung UE43J5500 No red light despite PSU testing good
    i've found a schematics for this main board: https://www.electronica-pt.com/esque...ileinfo/82533/
    Everything is done inside the microcontroller, so it's basically dead
    Its more than likely it was killed by a power surge, being powered on all the time
      09-07-2024, 05:50 AM
    • Kaar3l
      Samsung QLED QE65Q7FNAT only standby light
      by Kaar3l
      TV: Samsung QLED QE65Q7FNAT
      PSU: BN4400940A
      MB: BN94-12832K
      I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
      09-24-2024, 01:35 PM
    • marcinq
      Samsung UE60KS7000 No Standby Light
      by marcinq
      I've got a problem with a Samsung UE60KS7000 that was given to me and said that there was a problem with the One Connect box but as I understand the TV should turn on even with the One Connect box disconnected (which it doesn't). There is no stand by light.
      I've disconnected the Main Board from the PSU and when connecting to mains the backlight turns on which suggests the PSU might be ok. I've measured the voltages out of the PSU and they seem reasonable (like the labels say). The main board has no obvious burns, there are no shorts on the power rails anywhere....
      05-26-2025, 11:36 AM
    • ChristianBr01
      LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
      by ChristianBr01
      I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
      The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
      What I already found is that the 12.8V are not an the connector to the main board connector to the power...
      04-23-2025, 01:48 AM
      09-06-2024, 11:40 PM
