Re: K8N no boot....
Hi, Stevo,
I would recommend using something besides a Dell PS. They went through a phase of altering the standard atx plug wiring in order to further force customers to rely on Dell repairs and parts. There was an article on the web a year or so back. There were some instances of fried mainboard and/or PS damage as a result. I think they have stopped but I'm still reluctant to use them.
Actually, on a basic no frills test ( cpu. ram, and video), a very low power supply will work. I usually use a 250 watt to test even on P4 system(if it has the necessary connectors). You do need to replace at least the one known bad cap. A single baddie will prevent boot, I have found this repeatedly. Fortunately for me, though not the original owner, they tendency is to pitch the board without even trying the repair. This has provided me with a number of very nice boards once crap caps have been yanked and replaced. Asus boards are good when they work but can be a nightmare to diagnose and repair.
Motherboards also have instances where they fry one of the tiny block resistors, making it nearly impossible to locate the problem much less repair it.
Hope this helps
Hi, Stevo,
Hope this helps
