8kha C1
  • gdement
    • Jan 2007
    • 690
    Re: 8kha C1
    Don't that motherboard run the Athlon off the 5V rail?
    I'm pretty sure it does. The heatsinked mosfets and the 3x 2200uF caps to their left are all connected to the 5V input.
    (This is for the 8K7A, which Stevo mentioned is what he actually has. The title still says 8kha so just want to clarify that)
    • stevo1210
      • Oct 2006
      • 4156
      Re: 8kha C1
      Originally posted by stevo1210
      The bad news is that I still get random C1 errors which will disappear after the reset button has been pushed. I have replacement caps coming my way soon so I may recap this board along with some others.
      For some reson I have to wait really long before I can boot my PC up....
      What I mean is that I have to wait for about 3-5 minutes after I press the power button before I can press the rest button on my case and then I will be able to see the POST screen come on. After it POSTs the PC is rock solid and passes every burn-in test and benchmark test. If I had a bunch of bad caps wouldnt my system like crash continuosly and not be able to work properly?? or am I wrong??
      I don't know what's wrong with it and I feel like I might need a new board??
      Thanks.
      Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        Re: 8kha C1
        You're right: why did I wrote such a bullshit? I got it, my brain is Fujhyyu branded: it's getting rotten by time
        Zandrax
        Have an happy life.
        • bgavin
          • Jan 2007
          • 1355
          Re: 8kha C1
          Don't feel alone. I erroneously thought some of my dead Intel boards had some tiny Chinese caps... until I got out the magnifying glass and saw tiny Rubys instead. Bad eyes suck.
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Re: 8kha C1
            I think it's actually an occupational hazard.
            You open a PSU and find Fuhjyyu's.
            This causes a brain disfunction which affects memory, eye sight, and causes an uncontrollable spewing of 4 letter words to the point the paint on the walls begins peeling.
            Maybe we should call OSHA or something.
            Mann-Made Global Warming.
            - Dr Seuss
            • stevo1210
              • Oct 2006
              • 4156
              Re: 8kha C1
              Thanks.
              Ok, I've been a real dope. I set the VDIMM voltage too low with the jumpers to +0.0, increasing it to +0.1 (or was it 0.2?) solved the problem. Now it can POST every single time without any issues.
              I found the solution after reading bgavin's thread here: https://www.badcaps.net/forum/showth...highlight=8k7a
              Thanks.
              • bgavin
                • Jan 2007
                • 1355
                #27
                Re: 8kha C1
                This is the beauty of the internet. Passing along things where others can find them useful. Glad it worked for you.
                I had a guy recently do the same for me, regarding exotic heat sinks on Intel boards. I was all set to use Scythe Zipang coolers, but I was totally put off by the cheesy push-pin mount system for a kilogram cooler. Some smart guy posted that I can use the $7 Thermalright LGA775 bolt-through kit with backing plate with the Scythe coolers.
                • iMic
                  IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                  by iMic
                  Hi folks,
                  I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                  The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                  11-29-2023, 06:44 AM
                • kotel studios
                  DEER B350ATX PSU - tips on making it safer and "better"
                  by kotel studios
                  Since it looks like my excellent power PSU chances at living are now close to zero, I decided to give a shot at upgrading this DEER B350ATX PSU.
                  At first glance it looks like, well.... a shitty cheaped out DEER garbage (cause it is). Although it does have an LF 1250CD00 filter transformer (at least I think that's what it is) 😆
                  Tiny heatsinks, small transformators, single-pole ON/OFF switch. You name it.
                  Now since this one works, I'd like to know how can I make it safer and better (besides burning it with napal 😃). My plan is to make the switch double-pole...
                  03-04-2025, 12:09 PM
                • bauto601
                  KDM 480W PSU upgrade succes! (opinions?)
                  by bauto601
                  Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                  A "nice" YoungYear unit? - Badcaps
                  The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                  12-26-2023, 03:05 PM
                  by momaka
                  03-15-2023, 10:17 PM
                • socketa
                  Hipro D2537F3H - Teapo output capacitor replacemnt
                  by socketa
                  Thought that it would be worth rescuing this one, but it's got one bulged Teapo that is in front of the big coil.
                  Would it be perfectly OK to replace this 4700uf SC (which currently measures 600uf and 1.2ohm ESR) 5V output cap with XYJ 3300uf? More specifically, was the original 4700uf Teapo cap overkill?
                  i also (inline) tested the 3300uf SC (which is parallel with a 2200uf SC cap, that is right next to it) on the 12V rail, and get a measurement of 5500uf and around 0.1 ohms ESR - So those caps look like they are still healthy?
                  11-15-2019, 01:43 PM
