Did such Mobo configurations ever exist?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Did such Mobo configurations ever exist?
    Whoa,
    I completely missed that the DDR is registered.
    - Gotta go look some more.
    How does it kill the boards?
    If it's pulling too much power you can reference the AGP pin-out and trace the circuit on the card to find some attachment points for wires and add your own molex to the card. It would be on wires instead of hard mounted but so what.
    Mann-Made Global Warming.
    - Dr Seuss
    • zandrax
      Hit and miss
      • Dec 2007
      • 1157
      • Italy
      Originally posted by pentium
      EDIT: One thing that I have noticed with the 4000 is that it kills boards.
      Excluding my Dimension 4100 it has killed the AGP slot on every board I have tried it in.
      Are you kidding, aren't you?
      I've heard of 8x graphic card destroyed because someone tried them in a board feturing a old 4x or 2x universal slot: the slot feed the card with a killer voltage (3.3 or 1.5 vs 0.8v).
      Surprisingly, I've never heard of graphic cards killing mobos: I fear your Wildcat 4000 is shortcircuiting the slot and, since the Agp is directly connected to the northbridge, it could definitively trash the board. Even more strange, the Dimension 4100 is built around the Intel 815E, who supports Agp 2.0: you shouldn't have such a problem with any other Agp 2.0 compliant board.
      Keep us updated.
      Zandrax
      Edit: I suddently remember that the first Agp mobo (around 1996-97) could have their traces burnt by the GeForce 256: this card required much more power than most contemporary cards and mobos weren't engineered to sustain that load.
      However, since then every board was designed to allow the maximum draw expected by the last Agp revision, so it shouldn't be an issue.
      Have an happy life.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        What is this super secret ISA device anyway?
        Are you the one that out bid me on the ISA O'scope card?
        - Dr Seuss
        • zandrax
          Hit and miss
          • Dec 2007
          • 1157
          • Italy
          I hope there isn't a Pci equivalent, otherwise I'd curse pentium's Wildcats . He'd have two killing cards, in the literal sense .
          Zandrax
          Have an happy life.
          • zandrax
            Hit and miss
            • Dec 2007
            • 1157
            • Italy
            Whoa,
            Forget the registered ram: I haven't found any Athlon server board with an Agp Pro *and* an Isa slot. Even Tyan, which supports Amd since long ago, has only a few Athlon boards with a plain Agp and an Isa slot.
            The 4000 card worries me: I simply hope pentium doesn't want to try into the Agp Pro board. It could be called a suicide...
            Zandrax
            Have an happy life.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Can also eliminate all the Intel chipsets that have 3 numbers in them i810, i845, i875 and so forth. None of those support registered memory (unless it's RDRAM ).
              For Intel only the 4 number chipsets work for DDR registered. E7505 and so forth.
              It's going to be much cheaper to replace the RAM that to buy this mystical motherboard if there even is one to be found.
              - Dr Seuss
              • zandrax
                Hit and miss
                • Dec 2007
                • 1157
                • Italy
                #27
                I agree: I've found a Tyan Thunder HEsl (S2567), a dual P3 board with an Agp Pro and an Isa slot, but its chipset supports only registered Sdram. Boards which require registered ddr don't have the Agp or the Isa slot, so pentium is a bit out of luck.
                Zandrax
                Have an happy life.
                • pentium
                  • Mar 2006
                  • 2778
                  Zandrax
                  <shifty eyes>
                  No sadly there is no pci equivalent and it's not a scope card (those exist?).
                  Find Nedry!
                  Check the Vending machines!!
                  • zandrax
                    Hit and miss
                    • Dec 2007
                    • 1157
                    • Italy
                    #29
                    <shifty eyes>
                    Of course Isa oscilloscope cards do exist: this bus has been the preferred one for industrial applications for about 20 years. BTW, I managed to find one on e-bay. A bit large, you know: a full-length isa card. Picture attached.
                    I'm really curious now: it's an odd 8 bit proprietary controller?
                    Zandrax
                    Have an happy life.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      It might be 8-bit ISA. That's all a scope really needs.
                      There were also Apple/MAC versions and versions for IBM's MCA bus.
                      There are also PCI, Parallel Port, and USB versions.
                      - Dr Seuss
                      • zandrax
                        Hit and miss
                        • Dec 2007
                        • 1157
                        • Italy
                        #31
                        Don't worry PCBONEZ, the picture is a photo of an old isa oscilloscope card.
                        I wonder what pentium's card is: maybe an old, 8 bit proprietary controller?
                        Zandrax
                        Have an happy life.
                        • pentium
                          • Mar 2006
                          • 2778
                          Time to let the cat out.
                          The ISA card in question is the controller card for my VFX1 headset.
                          The reason that I want to run one of those video cards is that they output a stereographic signal (the Mini-DIN port)
                          Once I have finished with my current Linkbox I want to see if the stereo output from the card can be used to help eliminate components in the Linkbox.
                          Find Nedry!
                          • zandrax
                            Hit and miss
                            • Dec 2007
                            • 1157
                            • Italy
                            #33
                            @ pentium: you have an old lcd shutter glasses and an 8 bit isa controller.
                            Though drivers for win98 do exist, I would never use them unless you are willing to see every game looking as a low-res Wolfenstein 3d [yeah, I used to play Wolfenstein on my old 486dx with a (slow) Trident 8900c (so slooooow) and I could get a decent framerate only by switching to a 320x240 low resolution. Later I got an used Cirrus logic CL5420 and I could enjoy the [then] hi-res vga graphic ].
                            Lcd shutter glasses are still produced: I found a 2005 review, there are listed over 100 products.
                            Unless you are an 1980's nostalgic [do you own an Amiga, do you?], I'd look for a more recent pair of glasses. Of course it's all IMHO.
                            Zandrax
                            Have an happy life.
                            • zandrax
                              Hit and miss
                              • Dec 2007
                              • 1157
                              • Italy
                              #34
                              Zandrax
                              I apologize for my bad grammar.
                              I noticed your VXF1 homemade controller thread after writing my post, so I'll add some information here.
                              Each lcd screen of your VXF1 pair of glasses has a native resolution of 263x230 pixels: the combined resolution (789x230: why 789 and not 526?) is roughly half a vga res (640x480). While it was stunning at the time, any resolution inferior to a svga one (800x600) is both limited and limiting nowadays.
                              If I were you, I'd look for the E-D 3D glasses: they are cheap enough ($100 + shipping the wireless version, $70 the wired one if you manage to find it) and are supposed to work on any Windows version and most graphic cards, nVidia ones through the official stereo Detonator and others through the generic E3D driver. They don't require a controller card, because they work by doubling the monitor's refresh frequency or, in short, sync-doubling: the card generates two images, one for each lcd screen, these are joint togheter and transmitted at a double frequency; the drawback is you should have a good quality crt monitor whose refresh at your working resolution is at least 120 Hz (2 * 60 Hz) in order to avoid eyestrain and, of course, a graphic card powerful enough, since it has to draw two images instead of one at the same time. Sadly, the manifacturer doesn't declare any native resolution and no reviewer inquired into it; however, the Guru3D review is a good start point.
                              A similar product, the iArt Eye3D, is sligthly more expensive and harder to get; besides this, it can reach a 2048x1536 resolution at 120 Hz. There are two reviews, the Guru3D and the Stereo3D ones.
                              If you are lucky and patient, you may even look for an used pair: years ago there were the Asus and the Elsa ones, bundled with their graphic cards.
                              Zandrax
                              Have an happy life.
                              • pentium
                                • Mar 2006
                                • 2778
                                Can we not get in to that? I was just looking for a specific board, I was not looking for an alternative for my VFX1.
                                Find Nedry!
                                • zandrax
                                  Hit and miss
                                  • Dec 2007
                                  • 1157
                                  • Italy
                                  #36
                                  I had simply point out that alternatives exist, are affordable and, IMHO, more realistic then hoping one of few boards equipped with both an Agp pro and an Isa slot will be on sale someday. Perhaps a Pci controller for your headset would be an even better solution (no more "damn isa, where are you" talking ), but I had no luck while looking for.
                                  Nevertheless I wont stop you from hoping this and from having fun in building the new controller: do it if you like doing it.
                                  Just keep us updated.
                                  Zandrax
                                  Have an happy life.
                                  • pentium
                                    • Mar 2006
                                    • 2778
                                    I just wanted to add a cool factor by using a Wildcat. If it's just too much work, I'll just drop it another board I have and use my Radeon 9600XT.
                                    :P
                                    Find Nedry!
                                    • zandrax
                                      Hit and miss
                                      • Dec 2007
                                      • 1157
                                      • Italy
                                      #38
                                      Well, better try first with a cheap board and a cheap card: if it all ok you can try with other components, if they get damaged you lose very little.
                                      Destroing your long-awaited board with an hard-to-find OpenGl accelerator and an homebrew VR controller is a good way to drving you mad. Or, at least, to burn some money.
                                      Zandrax
                                      Have an happy life.
                                      • pentium
                                        • Mar 2006
                                        • 2778
                                        Okay then. Go cheap and if it works there and I am okay with it I will got for something better.
                                        Find Nedry!
                                        • gdement
                                          • Jan 2007
                                          • 690
                                          #40
                                          So what's wrong with the Biostar AMD761 board mentioned earlier in the thread? I don't see why that won't work.
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • Cerberuska
                                            Mobo MSI B550-A PRO password popup
                                            by Cerberuska
                                            Hello guys,
                                            I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                                            BIOS I updated to last one.
                                            any suggestions?
                                            And same thing for two different 5600G, and yes, MoBo supposed to support it.
                                            Thank you...
                                            11-10-2024, 01:23 PM
                                          • mrsith
                                            Dell G3 17 3779 - no display after mobo replacement
                                            by mrsith
                                            Hi guys,
                                            I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                                            Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                                            04-30-2023, 05:11 AM
                                          • Ibod
                                            Corsair cx600 psu & ASRock B450Pro4 mobo wont start
                                            by Ibod
                                            HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
                                            With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
                                            Not sure where to go from here ?
                                            Is the PSU at fault or is the mobo causing the problem
                                            Look forward to any help :-)
                                            If I plug the 24...
                                            02-08-2023, 11:00 AM
                                          • Felipe_Serra_83
                                            Dell Inspiron 14-5448 - fan turns off and mobo keeps running
                                            by Felipe_Serra_83
                                            Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
                                            So I got this Dell Inspiron to play with.
                                            No charger, so I connected to my bench PSU.
                                            The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
                                            ------What it did (and didn't do)------
                                            1) I turned it on and it powered on. Powered down in 2 seconds by itself.
                                            2) Removed RAM, changed slot. Same...
                                            04-04-2024, 12:39 PM
