Gpu or vram issue?
  • reaper57
    • Sep 2014
    • 216
    • Norway
    Gpu or vram issue?
    First of all I am not sure whether or not this is the right section of the forum to post this in, so sorry if it's not. Feel free to move this thread to the right one.
    Hi, I'm a bit confused about a bga problem on one of my xbox 360s. Can someone help me determine whether this is a gpu or vram related problem? The pictures are in the attachments.
    I have reflowed the gpu two times, the first time it lasted about 3 months, the second about two months. The second time I even poked the gpu and it moved, so the solder was melted. I hoped that this was the end of it at least for a year or so, but here it is again freezing and displaying artifacts.
    I am starting to think that this is a ram issue as the error code it was giving me is a ram or gpu problem, some people say most of the times it's the gpu some say most of the times it's a ram problem.
    Any help and advice is appreciated.
    P.S. I tried using this link that I found on here in another thread some time ago, but it looks like it's giving symptoms of both gpu and vram failure.
    http://www.playtool.com/pages/artifacts/artifacts.html
    Keyboard not detected, press F1 to continue...
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Gpu or vram issue?
    Looks like the GPU to me. Considering that it was giving you trouble in the past also suggests this. Unless the chip's removed, and both it and the board prepared/cleaned, and properly fluxed/reballed, you'll never have a lasting repair.
    Microscum's idiotic idea of "silent game-puting" wasn't a help either. Modern junky lead free "solder," extreme thermal excursions, and terrible cooling are bad news...
    I think M$ planned it this way, you know, as usual, to increase their sales.
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
    • reaper57
      • Sep 2014
      • 216
      • Norway
      Thank you for your advice.
      Well I am not sure that it was the gpu giving me trouble. It worked after a gpu reflow, but the ram is right next to the gpu so it gets heated up as well, so it could still be the ram.
      I agree on the cooling part, the cooling in the 360 is a joke, that's why I modified mine to run cooler. It rarely goes over 55C under load with the stock fans set at 45 or 50%. Usually it's between 47C and 51C on the gpu. The cpu runs even cooler.
        master hoarder
        • May 2008
        • 12176
        • Bulgaria
        I think it is the GPU as well. If I remember correctly, when the RAM goes bad, board won't post and you'll keep getting RROD. Is you RAM made by Samsung, Hynix, or Quimonda (Infineon). The last one (Quimonda) are know to be more unstable and/or less durable. Might also help to check the RAM temperature. Just run the Xbox opened/disassembled for a bit and touch one of the RAM chips. If it's burning hot, the RAM could be on its way. But I've seen this only twice. I used to work in a repair shop that did a lot of these.
        • diif
          • Feb 2014
          • 6978
          • England
          The defects weren't planned by MS but they knew their manufacturing wasn't up to scratch.
          http://venturebeat.com/2008/09/05/xb...-console-woes/
          • reaper57
            • Sep 2014
            • 216
            • Norway
            Oh, it doesn't boot. The picture of the artifacts on the boot animation are the last I got from it. Now it just RRODs.
            I run the xbox open all the time with a modded cooling and transistor heat sinks on the ram. There was this one ram brick that was hotter than the rest, but even since the last reflow they've kept the same temperatures. I had installed an rgh in this console so I could monitor the temperatures. The ram was usually under 55-57C, after a few hours of being under load.
            • Nagyesz
              MSI RX 580, BGA or VRAM issue?
              by Nagyesz
              I've come across two graphics cards, but since I haven't dealt with graphics cards before, I only have basic knowledge. Both are the same type of card; one powers on, the other black screen, and the fan doesn't start either.
              I've roughly checked the coils and examined a few traces.
              My first question is about the card that powers on but has screen artifacts. Is that a BGA or VRAM issue? How can I find out?
              (The card doesn't overheat, and it doesn't cause windows to crash. It also visible in bios. I was able to open all kinds of applications...
              08-15-2024, 02:33 AM
            • Aliasgar Jamali
              Asus Gtx 1060 vram issue
              by Aliasgar Jamali
              guys I have a Asus gtx 1060 which has a Vram issue, I bought the right VRAM and waited a couple of weeks to arrive, but now when I reball the chip it is still showing an error in exact same channel.
              I have reball the proper C0 Channel, and reballing process also went perfectly ( no short in Mvdd and having 65 ohms resistance in the rail )
              Guys, i have a question if the GPU is not artifacting ( no display at all ) and while testing we found out a particular VRAM chip is faulty,
              Can we recover that card?...
              09-04-2022, 11:58 PM
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              🛠 Original Issue
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • ugamazing
              by ugamazing
              12-17-2024, 07:05 PM
            • ahmarzo
              Acer laptop battery draining issue
              by ahmarzo
              Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
              Help me to diagnose this issue as there is no shortage in the inputs MOSFET
              08-02-2025, 06:39 AM
