MSI RX 580, BGA or VRAM issue?
  • Nagyesz
    • May 2024
    • 124
    • Hungary
    I've come across two graphics cards, but since I haven't dealt with graphics cards before, I only have basic knowledge. Both are the same type of card; one powers on, the other black screen, and the fan doesn't start either.
    I've roughly checked the coils and examined a few traces.
    My first question is about the card that powers on but has screen artifacts. Is that a BGA or VRAM issue? How can I find out?
    (The card doesn't overheat, and it doesn't cause windows to crash. It also visible in bios. I was able to open all kinds of applications without any problem. Windows shows error 43 for the card)
    For the other card; what should I check first to figure out why there's no display or fan?
    Click image for larger version  Name:	453714489_1225939048850595_654929578135863744_n.jpg Views:	0 Size:	450.8 KB ID:	3329665Click image for larger version  Name:	454434411_1229424238414259_465502482155037874_n.jpg Views:	0 Size:	277.7 KB ID:	3329666
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    errors on many channels. all rx580 needs reball
    • Nagyesz
      • May 2024
      • 124
      • Hungary
      I've never done that before, and I don't have the tools for it. Could reflow be a solution? And should I avoid experimenting to find out which VRAM is faulty?
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3628
        • slovakia
        its cheap card u can even kill. so try everything u can
        • Technomancer
          Nintendo 2DS SD Card Reader issue. Problem on the clock line?
          by Technomancer
          I have a 2DS that I am working on that has a problem reading SD cards. It knows that card is in the slot (which, means the detect pin is working anyway) but it says it can’t read the card.
          Here is what I have done so far:
          -Tried SD card in another 2DS and on PC, works great.
          -Tried piggybacking another SD card slot (just so I didn’t have to take the other one off), same issue.
          -Compared voltage drop readings from a working 2DS to the faulty one. All reads are very close except one, the 7th pin from the left, with the pins closest to you, which I believe...
          06-07-2022, 09:01 PM
        • grimacelord
          ASRock AMD Radeon RX 5500 XT Causes Computer To Lose Display Until Forced Reboot
          by grimacelord
          Hello. I have an AMD Radeon RX 5500 XT Phantom Gaming D 8G OC video card that recently began to give me trouble after 1 year of perfectly fine usage.
          The problem initially began after a year of use as the display randomly losing signal (i.e. screen goes black). The PC's fans would spin high, but the display would never recover until I hard shut down the PC and then rebooted. This would happen randomly and not too often.
          Over time, this problem became more and more frequent to the point where any moderate use of the video card in any capacity would trigger a black...
          11-19-2021, 11:06 AM
        • shybear
          Razer Blade 15 Advanced (RZ209-033) graphic card issue
          by shybear
          hi,
          this laptop works but temperature rise too much. I dismounted mb and cleaned well. There was a lot of dust inside.
          I think that there is a graphic chipset issue because when I power the machine I get this error:
          "the detected discrete gpu VBIOS is not meant for this system"
          This make me think that maybe the gpu VBIOS has to be re programmed.
          BTW someone already worked on this mainboard. Near graphic board there is Winbond flash memory that I think its stored the VBIOS.
          I attach some pictures and one of message error I get when I power on the ...
          03-26-2025, 02:36 PM
        • sauce
          MSI DUKE RTX 2080 Ti 11G OC V371 1.0
          by sauce
          I am trying to repair this graphic card and I am quite new in this (but not a newbie in repair in general)
          If I plug the card inside a x16 pcie PC slot, the card won't power (no led, no fans, voltages : PEX, 1.8v, GPU core missing, I have only 12v on coils, 5v and 3.3v on the back on L801)
          The card stays absolutely cold.
          But I have a razer PCE164-N09 (see picture) and if I plug the card on it, the card works perfectly ! I have a picture and the drivers load perfectly too no issue on windows.
          Do you have an idea where to check...
          09-10-2025, 01:35 AM
        • fiveseventy
          RX570 dies completely, then recovers.
          by fiveseventy
          Hello all,
          I have a Sapphire Radeon RX 570 Pulse ITX 4GB (single fan) which has started misbehaving recently.
          The card was bought used maybe 5 years ago and has worked without issue until recently.
          I have no reason to believe it has been worked on or physically damaged.
          For periods of time it will be 100% perfect.
          Perfect temperatures, no glitches or artefacts, solid FPS.
          I can game, run benchmarks, do whatever without any problem.
          I can reboot the machine as many times as I like and nothing changes
          however, most times...
          06-22-2024, 05:29 AM
