IDE cable connections
  • Cohibaman
    • Jan 2015
    • 66
    I've got a music server using a PowerPC-based motherboard with an 300GB IDE hard drive and IDE CD-ROM. You pop in a CD and it rips it to the HD in either WAV or mp3 depending on user setting.
    The factory configuration of the HD jumper is master & the CD-Rom is slave. I imagine to accommodate the physical layout, they swapped system and master connections on the 40 conductor IDE cable (i.e., the "system" cable connector is connected to the HD while the "master" cable connector is connected to the motherboard). Works just fine in this configuration as it should.
    However, I replaced the 300GB with 750GB drive, also set to master - just like the original - but it won't boot with the swapped factory cable configuration. I had to get a longer 30" IDE cable to make it reach, connecting the "system" connector to the MB and the "master" connector to the HD.
    I've never had a computer that acted like this when jumpers are set to master/slave.
  • Agent24
    I see dead caps
    • Oct 2007
    • 5095
    • New Zealand
    Re: IDE cable connections
    Maybe it had something to do with putting the cable backwards...
    Don't even try it on 80-conductor cables. Pretty sure the design of the ground bus in those would cause something to get shorted.
    -David VanHorn
    • c_hegge
      • Sep 2009
      • 5219
      It's apple. 'nuff said.
      • Cohibaman
        • Jan 2015
        • 66
        Nope, it's not Apple.
        The longer cable is actually an 80 conductor.
        • c_hegge
          • Sep 2009
          • 5219
          Ah. OK. PowerPC is an Apple platform.
          • Cohibaman
            • Jan 2015
            • 66
            lol, so is an Intel Core i5
            • Agent24
              I see dead caps
              • Oct 2007
              • 5095
              • New Zealand
              But you're not using that one backwards, are you?
              -David VanHorn
              • Cohibaman
                • Jan 2015
                • 66
                Yes, it's the only way it works. It makes no sense to me.
                • joshnz
                  • Feb 2011
                  • 969
                  • New Zealand
                  by backwards he means the key upside down.
                  master and slave position are interchangeable provided the drives are set to master/slave.
                  My pc
                  CPU : AMD PHENOM II x4 @ 3.5Ghz
                  MB : ASUS M4A89TD PRO USB3
                  RAM : Kingston ValueRAM 16gb DDR3
                  PSU : Cooler Master 850W Silent Pro
                  GPU : ATI Radeon HD 6850
                  • Cohibaman
                    • Jan 2015
                    • 66
                    Sorry, I misspoke on how the new drive works....
                    This is the original configuration where MB & HDD are swapped, which will NOT work with the new larger drive.
                    []-----------14"---------------[]-----5.5"-----[]
                    (ABC left-to-right)
                    A is connected to the HDD (System connector)
                    B is connected to the CD ROM (Slave connector)
                    C is connected to the motherboard (Master connector)
                    The new drive ONLY works this way with ANY cable (literally tried 10 different cables)...
                    []-----------15"-----------------[]-----15"----------------[]
                    A is connected to the CD-ROM (System connector)
                    B is connected to the HDD (Slave connector)
                    • joshnz
                      • Feb 2011
                      • 969
                      • New Zealand
                      (ABC left-to-right)
                      seems like the drive is using cs
                      My pc
                      • Cohibaman
                        • Jan 2015
                        • 66
                        Nothing to do with the connector key
                        That's what I thought too.
                          master hoarder
                          • May 2008
                          • 12175
                          Have you tried putting the CD ROM and HDD on CS (Cable Select) and let the motheboard "figure it out"?
                          I've done the same as your original setup (i.e. the "motherboard" end of the IDE to a drive, and the "drive" end on the motherboard), and it never caused problems for me either, so I don't know what could be the issue. When you tried this, does the BIOS (or whatever that PowerPC motherboard has as equivalent... if any?) see the drive?
                            • 31301
                            the different coloured plugs are not the same internally on the ones i'v opened.
                            that configuration shouldnt work.
                            • Cohibaman
                              • Jan 2015
                              • 66
                              Yep, when it only fired up the one way, I thought, "screw this...cable select!" Nope, didn't work. Had to get the ridiculously long cable.
                              CS never worked at all. It's a long story and involved many late nights obcessing about upgrading the drive (to a "known to be" compatible drive) until I serendipitously figured out cable position mattered in this rig, but briefly...with factory cable config., it WILL discover the HD, but ONLY when first installing the operating system from a restore disc in the CD-ROM onto the new, freshly formatted HD. Once the operating system is loaded, the system hangs on reboot - even if I try to reinstall the OS. If I reformat the drive, it'll do the same over & over (rinse & repeat).
                              For what ever reason I swapped cable positions and it finally worked.
                              It does have a bios btw, but non-accessible, proprietary and fickle too.
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • Patch2
                                Cable Repair
                                by Patch2
                                I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
                                01-02-2025, 06:04 PM
                              • Tr0ll
                                by Tr0ll
                                Original T-con:
                                First replacement T-con:
                                10-07-2023, 07:48 PM
                              • conghuyms
                                I need datasheet cable eDP LCD 30 pin slim pls help me!
                                by conghuyms
                                My 30-pin eDP cable from the mainboard to the LCD screen got cut and damaged at the screen connector side. I found another cable and took the screen-side connector from it, but the wire colors are different. So I really need the wiring diagram for both ends of the eDP cable to solder it back properly. If anyone has the diagram, please kindly help me out. Thanks a lot...
                                08-22-2025, 11:16 AM
                              • fweonea
                                HP-Pavilion x360 Laptop Dead After USB-C Cable Connection
                                by fweonea
                                While at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
                                I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...
                                01-16-2024, 11:35 AM
