Logitech X-530.... popping noises.
  • stevo1210
    • Oct 2006
    • 4156
    Hello Everyone,
    I recently purchsed a set of Logitech X-530 series speakers. The speakers are 5.1ch speakers and the sound quality is great.... after all, it did cost me $100AUD which wasn't too bad.
    I have one problem with them though. They make a loud popping noise when someone turns on/off the lights which contain ballasts and electronic transformers. When a light is turned on, there is a small pop which is hardly noticeable. But when a light is turned off, I get a loud "pop" through the speakers.... and it's becoming a real pain.
    With tube lighting, I can hear a small pop for every flash the light takes to turn on.
    I turn the volume of the speaker down to the lowest and the pop emitted is still a loud pop.
    I've also plugged the speakers into the 15A line for the Air conditioner to run and there is still a loud pop noise that is transferred through the speakers when a light with an electronic transformer or ballast is turned on/off.
    Is there some way that I can get around this problem?? I don't know if anything like this exists but.... I was thinking of something like an EMI filter of some sort that plugs into the 240AC powerpoint and the speaker would be plugged into the back of that to eliminate the noise??
    These speakers are still under warranty but I don't really want to have to dismantle the whole speaker setup and return it to the store. I have another set of Logitech speakers, Logitech R-20 series 2.1ch and they don't make a loud popping noise when the lights are turned on or off. Same goes with the Creative SBS370 2.1ch I had before the Logitech X-530 5.1ch, they didn't make a noise when the lights were switched on or off.
    But the strange thing is that the Creative SBS370 and Logitech R20 speakers have an external wall wart type of power supply wheras this Logitech just has a power cord that is plugged into the wall.... which probably means that the power supply is inside the speaker/subwoofer.
    But I also have another set of 2.1ch "Soloman" brand speakers that are plugged directly into 240VAC like the Logitech X530 and they do not make any popping noise when a light is turned on/off.
    I don't know what going on here??
    Thanks.
    Don't find love, let love find you. That's why its called falling in love, because you don't force yourself to fall, you just fall. - Anonymous
  • stevo1210
    • Oct 2006
    • 4156
    Re: Logitech X-530.... popping noises.
    I went to my local electronics store this afternoon and I asked for a filter to filter out electrical noise inteference and I was told that there was no device that could stop or reduce electrical inteference noise.
    I don't know what to do now about the popping noises.
    Is there any solution to stop these popping noises??
    • gonzo0815
      • Feb 2006
      • 1600
      What a poor salesman at this shop. I would recommend on of those over voltage protector extension leads or adapters.
      If you want to mess around by yourself, i would suggest checkout this topic:
      https://www.badcaps.net/forum/showth...ght=EMI+filter
      • stevo1210
        • Oct 2006
        • 4156
        I have another problem now. I turned the speakers down all the way and I could hear feint radio signals from a radio station playing through my speakers!!.
        I didn't notice the radio signals until today because usually the computer room is quite noisy.
        I also got my brother and father to confirm on the radio signals and they are actually there.... so it's just not my imagination playing on me.
        I don't know what's going on here or how these radio signals are being picked up by the speakers.
        If I turn the speakers up, it disappears which is strage. My PC was not connected to the net at the time and had no applications running at the time.... So I can confirm that it wasn't my PC playing the radio.
        Is there something I can do to stop the radio signals being picked up on my speakers as well as the popping noises??
        • starfury1
          • May 2006
          • 1256
          well not sure on the radio station one
          guessing probably due to shielding or lack of beads on transistors whatever.
          Yeah probably a decent line filtered power board will fix that up switching pops.
          (better if they had built in in thought)
          Seems they didn't do their job when it came to protection the thing against these types interference
          I know it was only $100 but still it something they should have seen too, not you
          You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
          • Sparky
            High voltage
            • Jan 2007
            • 234
            Most every speaker set I've had pops some when the fluorescent lights are turned on or the compressor in the dehumidifier on the same circuit kicks on or off. This isn't limited to just my logitechs but others as well.
            • starfury1
              • May 2006
              • 1256
              to me its a bit like selling a car without a muffler...its just something you have to to and probably the best place is within the equipment.
              it doesn't reflect well on a company when your audio equipment goes "snap crackle and pop"
              my logitech's do the same, I haven't got a line filter but since its not very often I don't worry about it.
              but in stevos case sounds like he needs to do something about it
              should see if I can did up some info on it as we are all effected I suppose to a greater or lesser extent.
              keep us posted stevo on how you go.
              Cheers
              • starfury1
                • May 2006
                • 1256
                My advise to anyone
                If you are not skilled lic whatever to work on mains rated equipment or componets etc.
                Don't try and build these circuits
                Really posting it as informational references on how its done.
                please note;
                that caps used would have to meet X and Y specifications
                same, whatever the specs might be for an inductor @ mains
                not going to comment on this $
                but have a look whats in the box here
                (seen them somewhere before stevo)
                website that seems to keep popping up Jon R
                Silicon chip did a circuit but unfortunately you want the full article you got to pay for it
                http://www.siliconchip.com.au/cms/A_30291/article.html
                (Jaycar or Altronics might do a kit for it dont know ...DS forget them)
                (I think ETI AU did one years ago too.)
                not what I call an in depth article on it.
                http://www.triode-systems.com/module...hp?articleid=2
                here is a circuit and pcb
                http://www.triode-systems.com/module...p?articleid=26
                Anyway mostly same as the stuff in the BC link Gonzo posted above.
                here is an IEC power board fitted with filter, this as an example only
                some power boards are made like this too, they are the one you would need to seek out.
                http://www.olson.co.uk/iec320_options_filter.htm
                Iam sure I found better stuff in the past but just cant seem to find more informative links at the moment...
                anyway HTH
                As always
                ALL DISCLAIMERS apply here its MAINS VOLTAGE you are dealing with so you do at your own risk etc
                • plaxidia
                  • Jun 2013
                  • Sweden
                  Ok this is an old post I know. But I recently picked up a set of these speakers at a second hand store and was so exited when they actually worked UNTIL the horrid popping started shortly after I plugged them in. After a little research and allot of soul searching (I'm not always comforatable with messing with motherboards, circutboards ect) I figured since they were so cheep and I really had nothing to lose I would try to fix them myself. I found this post
                  http://forums.logitech.com/t5/Speake...t/false#M32004
                  It actually worked! After a day of running them non-stop they have not popped or buzzed or made any other odd noises since. Mind you it was time consuming and took a great deal of patience but rather than toss out a perfectly good set of speakers why not give it a shot. I personally am very happy right now and highly recommend trying the fix before you go buy new speakers
                  • plaxidia
                    • Jun 2013
                    • Sweden
                    Hmm can't edit the last post I made. I got the link wrong. Its here
                    http://forums.logitech.com/t5/Speake...t/false#M29885
                    sorry. If anyone can fix it please do
                    • cheapie
                      null
                      • Jul 2010
                      • 849
                      If you ever have a problem with interference coming in through the power however, essentially, if you've ever seen the input filtering section of a computer power supply, you're wanting to recreate that, more or less.
                      • Elysarian
                        • Mar 2013
                        • 200
                        • United Kingdom
                        I had a feeling it was going to be a floating ground line somewhere acting as an aerial, would have suggested a similar fix myself
                          LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech ThinkCentre M i5-9600T Specification for Upgrade or Repair
                          This specification for the LENOVO ThinkCentre ThinkSmart Edition Tiny M920q for Logitech can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre ThinkSmart Edition Tiny M920q for Logitech boardview and ThinkCentre ThinkSmart Edition Tiny M920q for Logitech schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                          09-12-2024, 01:58 PM
                        • howardc64
                          by howardc64
                          Problem
                          08-04-2024, 10:36 PM
                        • tony359
                          by tony359
                          11-28-2023, 05:18 AM
                        • MegaZAC
                          Onkyo TX-SR805 noise in one channel
                          by MegaZAC
                          Surprisingly enough, this receiver doesn't have the DSP chip issue. The HDMI board does not get hot, and sound over HDMI works fine.
                          Regardless of the input, the right channel has noise that is clearly noticeable even on average volume level. The only cases when there's no noise is when VCR input is selected (some tracks on the board are damaged, maybe that's why), or if HDMI input is selected but nothing plugged into it. In all other cases, even when no input is connected I still have the noise.
                          There's some logic behind it. As soon as I select an input I get only left...
                          04-23-2025, 10:09 PM
                        • courtcircuit
                          Philips HTS8000 home cinema noise problem
                          by courtcircuit
                          Hello
                          I have since a long time a Philips HTS8010S/01 which has been old but was doing the job.
                          Since a few days, it starts by making a weird "static" nois when switches on for a few seconds to a minute and then works like a charm.
                          Noise loudly outputs from the 3 channels, even if no signal is sent by the controler.DVD to the subwoofer/amp unit.
                          I was thinking of a soldering that was starting to be damaged and that was only doing the job after a few seconds of heating, most probbaly on the power board
                          Removed each of tyhe boards
                          02-08-2025, 08:22 AM
