swaped hhd with win7
  • ivtec
    • Dec 2008
    • 1967
    Hi guys:today I removed a hard drive with win 7 from my Toshiba and installed in my other Hp laptop that had win vista that had trouble and I don't have the recover disc so I put in the hdd with win 7 and it's working,but I did updates and in the corner it says this is not a genuine copy win7 build 7601 but it's working for now,what you guys think is gonna happen?
    • 31298
    Re: swaped hhd with win7
    it probably started a countdown timer to just stop working eventually.
    it was registered to the serialnumber in the bios of the original laptop.
    • SuperDuty
      • Mar 2011
      • 299
      • France
      There's a way to get rid of that but it can't be discussed here, but I've used "non genuine" Windows like that in a test computer for a while and it hasn't stopped working. It just displays annoying messages and won't upgrade obviously, and it seems slower but it might be an illusion. In my case I don't care as I just use this computer for benchmarks and it's not connected to the internet.
        • 31298
        we discuss everything here afaik
        are we dicussing bios shadow files?
        • blasterboomer
          • Dec 2013
          • 135
          • United Kingdom
          not sure if this is allowed but search google for windows loader by daz, you may have to torrent it...
          • nojgib
            • Nov 2014
            • 30
            If you are not using the previous computer you took the HDD from just enter the key on the COA sticker. If it tells you it cannot be activated use the automated phone system(pretty easy).
            In most cases the key on the COA has never been used. Manufacturers use their own key when they load the HDD. Try running Belarc Advisor on an OEM system and compare the key listed to the one on the COA.
            • nojgib
              • Nov 2014
              • 30
              Also, the OS will not stop functioning. Some features will be disabled though like desktop background and other things that don't necessarily prevent the OS from working.
              • ivtec
                • Dec 2008
                • 1967
                Thanks Guys for all suggestions, but i took care of it all right,i just installed Ubuntu 14.04 64bt and now it runs perfect,better then WIN Vista that was in this laptop,
                the laptop in question is an Hp Pavillion DV-5-1254 US Intel Core (Tm) 2 Duo core CPU P7350 2.00GHZ 4.00GB Mem intel 4500 hd card,this was given too me.
                • ivtec
                  • Dec 2008
                  • 1967
                  http://h20564.www2.hp.com/hpsc/doc/p...r_na-c01792254
                  • Hondaman
                    Win7 Emulation in Linux
                    by Hondaman
                    If I install Win7 in VirtualBox or KVM, will Windows be tied to that exact hardware? Can I take the VM and move it to another machine at some point without having to re-activate Win7?
                    I bought a replacement board identical to the one Win7 is licensed on. But of course it failed. I have two more identical boards in my basement. Running out of acceptable hardware will not happen for quite a few years, hopefully.
                    But I am looking forward to that day when I cannot find any hardware, and I have to use emulation. Does anyone have experience with this?
                    07-21-2025, 12:46 AM
                  • eccerr0r
                    win7 home iso? can I get 10?
                    by eccerr0r
                    Well I think that I have a GTX660Ti that's dead but I think I should give it one last try with its original OS and drivers: win7 home premium. While I can't stomach using win* of any type (I'm 100% Linux these days) I think I have to give benefit of the doubt to drivers, etc.
                    So... I have the original CoA for Win7 home premium and it's an OEM license. And I have the whole computer that the GTX660Ti came in (it was reportedly working too), minus the original hard drive, what could I download and run the machine temporarily to verify the GTX660Ti works with Windows or not?
                    09-14-2023, 07:35 AM
                  • sdinelli
                    latitude e5550 - no charge- all battery not recognized as genuine
                    by sdinelli
                    -latitude e5550 all batteries sense as non genuine(ive tried two working genuine and two new non genuine).
                    -battery led flashing white and amber which indicated non genuine AC adapter. tried multiple bios.
                    -ive tried multiple genuine chargers
                    -the circuitry seems to be working fine and battery and charging seems to be controlled by EU2 which is ECE5048-LZY
                    https://datasheet.octopart.com/ECE50...-147335658.pdf
                    does this chip have to be programmed? or is it replaceable? do you all think this could be the reason?
                    i have two of these same...
                    11-14-2021, 09:52 AM
                  • Hondaman
                    Japanese language -- Win7 or Linux Mint?
                    by Hondaman
                    I ordered a Japanese book, it will never be published in English. A Mr. Fujumoto was a Japanese sushi chef who became a cook for Kim Jong-Il. He was not perceived as a threat to the dictator's power, so he became very close to the dictator. Apparently, the dictator is QUITE hedonistic, with a lot of debauchery. Although he can spend as much as $700,000 per year on alcoholic beverages and this alcohol is NOT actually the highest quality. Also, the dictator has 24 palaces. One of them is as large as TEN YANKEE STADIUMS PUT TOGETHER. Are they all that large?
                    Does anyone have experience...
                    09-12-2025, 04:32 AM
                  • Tjaytony
                    Where can I get genuine laptop chips.
                    by Tjaytony
                    Hello, please can anyone refer me to a store where i can get genuine laptop chips, especially for macbooks. The ones i get from aliexpress and ebay are usually fake. They don't work. Will appreciate if anyone could point me in the right direction....
                    03-22-2024, 01:01 AM
