Question on M.2
  • ZuluLima
    • 35
    • U.S.A.
    Question on M.2
    I am planning on a new build with the Gigabyte GA-Z97X-UD5H black edition with i7 4790K. Does anyone know if I can put a KillerN-1202 wireless adapter in the M.2 slot. Or will the bios not recognize it? I plan on using the computer case as a ground plane for the sma adapter cables as well. Any experience with the M.2 out there?
  • ZuluLima
    • 35
    • U.S.A.
    Re: Question on M.2
    Update: I dug out the adapter cables and they are RP-SMA. I will have to make nylon washers so I can adapt them to the I/O shield with a bracket or to the case. Can't use RP-SMA with a ground plane.
      • 31296
      Re: Question on M.2
      why? the body of the connector is still ground.
      • Chaks
        Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
        by Chaks
        TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
        The specs says ...
        High antenna efficiency 868MHz ISM Band
        5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
        The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
        1. Should I Fix it with a glue.
        2. Should I fix it with a double side adhesive tape
        3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
        12-09-2024, 11:06 AM
      • mkdj
        Acer TravelMate P214 - N19Q7 main power rail shorted to ground
        by mkdj
        Dear all,
        I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
        I have checked resistance across each of the 4 MOSFETS. I have the following readings:
        Both N-Channel Mosfets: nothing odd
        P-Channel MOSFET number 1:
        source - drain : 117 kOhm
        source - gate: 96 Ohm
        gate - drain: 117 kOhm
        P-Channel MOSFET...
        08-20-2025, 06:08 AM
      • barry101
        Apple 820-3662 VCore shorted to ground.
        by barry101
        Hi, Would appreciate some help.
        I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
        Get charger light but no fan spin or chime. No liquid damage.
        Found PPBUS and VCORE both shorted to ground. Other rails were ok.
        Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
        With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
        Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
        06-24-2025, 07:34 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • Geeker007
        9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
        by Geeker007
        Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
        I am new to electronics repair, so my queries could be naive but I am ready to learn.
        So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
        01-28-2025, 03:31 PM
