burnt resistor in flasher relay
  • GR3Y5H3ART
    • Jan 2011
    • 146
    followed this guide but wanted the resistor ASAP and picked up one where the guy said it everything was almost 100%
    installed, and resistor burnt and left turn signal wont stop blinking?
    problem happened when installing LEDs in Front turn signal. had Rear turn signals
    http://www.v6performance.net/forums/...n-signals.html
    • 31077
    Re: burnt resistor in flasher relay
    you want to start again.
    in detail and without refering to a forum where nobody understands what they are doing.
    btw, if the flasher changes speed it's probably thermal(bi-metal strip) rather than electronic.
    the answer is to use an electronic relay, not load it down with ballast resistors that will get hot and burn stuff.
    • Mad_Professor
      A Mech Warrior
      • Feb 2011
      • 1587
      There is not enough information.
      The guide is great and all and I know what you're trying to do, but without any knowledge of car you are working on or relay in question, and the type of LEDs/ wattage per LED set, we can't help you.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4976
        • New Zealand
        Going on a wild guess that might be totally wrong, I'll try to interpret your post and say you were impatient to do the mod, didn't buy the specified 1 Watt resistors from Digikey, but instead bought some 1/4 Watt or so ones from a local shop, which couldn't handle the power dissipation and burnt up.
        That, or you did a bad soldering job and shorted something out.
        We need photos of YOUR flasher circuit, the resistors you bought, and your soldering work. Without these it's impossible to give any good advice aside from wild guessing!
        -David VanHorn
        • GR3Y5H3ART
          • Jan 2011
          • 146
          hopefully these pictures will be good enough. it was my 1st time soldering something like this but already unsoldered the old one
          • GR3Y5H3ART
            • Jan 2011
            • 146
            sort of but i called Radio Shack and they did not have it and referred to me to a specialty shop in Boulder, drove up there and it was watt for watt ohm everything
            info i'm getting now is it might have to be way lower like twice or 3 times lower.
            from a member on a site who had my same prob:
            That guide is good, but ignore the part where it says you need a .12 ohm, idk it wasnt strong enough for my car, I needed .24 and once I added LED's to the rear I needed a .48.
            • GR3Y5H3ART
              • Jan 2011
              • 146
              what i also tried was adding loaded resistors to the front 2 turn signals but that did not help
              i dont mind the hyper blinking but do need my left turn signal to work
              the right turn signal works and blinks normally which is nice but i would rather have both on and hyper blinking
              • GR3Y5H3ART
                • Jan 2011
                • 146
                I will try and provide more info but never had problem with the rears only when installed the 2 front ones
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 4976
                  • New Zealand
                  Yeah it looks like a 1 Watt resistor, but I'm not surprised it doesn't work.
                  What you've used is a 12 Ohm resistor, and the tutorial you linked to specified an 0.12 Ohm resistor. You're using a resistor which is 100x higher resistance than specified.
                  Have a look at this: http://www.digikey.co.nz/en/resource...or-code-4-band
                  -David VanHorn
                    Looking at the board lay out, that current sensing resistor is in series with the load, so if it burnt up that means the wattage raring of the resistor is too low, or the load is shorted or too low of the resistance.
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 4976
                      • New Zealand
                      Perhaps a different resistor on the board burnt? He didn't show the other side clear enough, but the one in his photos looks rather unscathed.
                      -David VanHorn
                      • redwire
                        • 3910
                        The resistor is the wrong value (12 ohm) and one leg looks like it is bent and shorting to the connector pin. Also, the module has power all the time, so best to disconnect your battery or the fuse when messing with it.
                        The flasher IC is an Atmel U2044B (datasheet)
                        Lamp outage (double-fast blink) gets activated below:
                        0.03 ohm = 2.7A / 32.4W
                        0.12 ohm = 0.68A / 8.1W
                        0.22 ohm = 0.37A / 4.4W
                        0.47 ohm = 0.17A / 2.1W
                        12 ohm = smoke
                        Power rating of 1/4W to 1/2W for the sense-resistor is fine.
                          The original resistor in the Video is also installed on the component side of the board, you guy have good eyes, the pictures are way out of focus for me.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4976
                            • New Zealand
                            I'm guessing the IC part number came from the photos in the original link.
                            -David VanHorn
                              • 31077
                              lifting pin5 on the chip may do what your after.
                              *after you repair it.
                              • GR3Y5H3ART
                                • Jan 2011
                                • 146
                                the Resistor arrived from DigiKey
                                Part #: 12ACCT-ND
                                RES 12 OHM 1W 5% Axial
                                i dont think the Resistor is causing the problem since it might be the wiring so based on the wiring diagram, is there a way to fix it before having to shell out for a new ECU? (already located one at a good price)
                                here's the best pics i could take of the OEM Relay
                                6 Pins
                                1 - E
                                2 - LL
                                3 - LR
                                4 - TL
                                5 - TR
                                6 - B
                                and 3rd pic, based on Haynes this should be the pic for the pins
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4976
                                  • New Zealand
                                  Part #: 12ACCT-ND
                                  I'm confused now. Why are you buying 12 Ohm resistors when the guide says to use 12 Milliohm resistors?
                                  The guide says to use this one: http://www.digikey.co.nz/product-det...CCT-ND/2059055
                                  -David VanHorn
                                  • GR3Y5H3ART
                                    • Jan 2011
                                    • 146
                                    based on this pic, and going Left to Right
                                    E, LL, LR, TL, TR, B
                                    then
                                    2 RED/BLU & 3 (BRN) should be the wires i should check and hopefully redoing them will fix the signal going to the MCU or Main Control Unit?
                                    • GR3Y5H3ART
                                      • Jan 2011
                                      • 146
                                      you are right, i got 12ACCT-ND when it should be 0.12ACCT-ND
                                      not sure why i disregarded that Zero
                                        • 31077
                                        can you take some decent well-lit foto's of the board - specially around the chip.
                                        there is some shadowing on the original foto's that could be a flash-mark.
                                        and then lifting pin5 on the chip instead of fitting a resistor would be worth a try.
                                        • CG2
                                          LED uplighter dimmer burnt resistor
                                          by CG2
                                          I've got a 240v LED uplighter which isn't working. Pulling it apart shows a clearly burnt resistor on the circuit board, and I'm hoping some of you will have suggestions on what to replace it with. First, here are some photos. Power comes in, through the fuse and choke, then through the big blue variable resistor labelled B500K (ignore the similar blue component at the bottom - it's a simple switch for an attached reading lamp). It then passes through the burnt resistor (or at least did once), through diac DB1 and the unburned 30 ohm resistor to the gate of the triac.Now I assume there's a simple...
                                          02-14-2024, 09:23 AM
                                        • trickartt
                                          Allen & Heath Xone:02 (DJ Mixer) - Burnt out Resistor
                                          by trickartt
                                          Hello Badcaps!
                                          I am trying to troubleshoot my Allen & Heath Xone:02 DJ mixer. I have had this for somewhere close to 20 years and have played music through it in one form or another pretty much every single day since I've had it, though these days it's usually from a wireless streaming receptacle (Apple Airport) more than the turntables that are also connected to it.
                                          This week my music stopped working, and after a bit of a wild goose chase, I realised my mixer was dead. I checked the 500mA fuse in the device beside the power supply and found it was blown, so I replaced...
                                          05-04-2024, 12:07 PM
                                        • sparcktikus
                                          Ersa Rds 80 soldering station burnt resistor
                                          by sparcktikus
                                          Hi
                                          I have an Ersa rds 80 soldering station which has developed a fault and just showing err on display
                                          I have found a burnt resistor on pcb can anyone help me identify this resistor if you have a circuit diagram or similar unit
                                          The printed circuit board markings are rd80 ver 2.0 and the resistor in question is R6
                                          Many thanks...
                                          04-04-2023, 04:29 AM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
