Another HDD issue
  • blasterboomer
    • Dec 2013
    • 135
    Another HDD issue
    I have an old WD1600AAJS HDD that i havent used in a few years now... so i did an error scan which came up all good then zero filled it and ran another error scan and checked SMART it was all fine... no errors whatsoever. i then tried to format the hdd within windows and it made the pc hang. This hdd has never been dropped or mistreated in any way so how could it suddenly develop so many errors after trying to format within windows...?
    also now if i try to zero fill the drive it does 6.8MB/s write speed... but the read speed is ~65MB/s. is there any fix for this drive or is it useless even for non critical data.. thats if i can get it to format...
    ps i cant use any bootable utilities as it doesnt have a monitor connected so i have to use remote desktop or teamviewer (this is not the OS drive and i dont care about any data that may be on it)
  • blasterboomer
    • Dec 2013
    • 135
    Re: Another HDD issue
    Update: this is how slow it is.. this is just the first pass and before it got all these bad sectors it wrote at around 65MB/s.. ive also tried it in another pc. same issue :/
    • diif
      • Feb 2014
      • 6978
      • England
      Try downloading the Western Digital Tools for Windows.
      http://support.wdc.com/product/downl...upid=612&sid=3
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        I wonder if it is autonegotiating the speed correctly. For a test you could jumper it to force 1.5 Gb/s and see if it behaves more like a normal drive.
        • blasterboomer
          • Dec 2013
          • 135
          Tried the jumper... still same speed and after that full erase that took 5 hours i ran an error scan and its like this... looks like this drive is dying.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Yeah, I'd say bad drive too.
            • goontron
              5000!
              • Dec 2011
              • 4108
              • US
              this isn't so odd. i wipe ~80 drives per day using badblocks (linux) and every single week i get two or three that are fine before the wipe starts but by the end they fail, usually getting very hot in the process.
              Follow the white rabbit.
              • RJARRRPCGP
                • Jul 2004
                • 6304
                The randomness reminds me of how Maxtor DiamondMax 8s (especially 6E0xxxx) fail. Especially if it randomly hangs.
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  I would get MHDD and write down the LBA addresses that HD Tune reported and use the "makebad" command in MHDD then "scan" in MHDD with "erase delays" option.
                  Arc A770 16 GB
                  • blasterboomer
                    • Dec 2013
                    • 135
                    I thought well lets see if i can get this drive to reallocate some sectors so put a minecraft server on it and let a few people just do whatever they want and it made a few sectors reallocate... This drive just done another 2 passes on the gutmann erase and no extra bad blocks... so if i can get it to stabilize i might use it for non important data. i was surprised this morning when i got up and it was still running (not hot either) i expected it to have the click of death or some other problem..
                    should i try a board swap as i have 3 or 4 of this exact same drive but the other 3 are fine
                    • blasterboomer
                      • Dec 2013
                      • 135
                      Is there any program that can read a certain area of the hdd endlessley to see if any bad blocks come back in that area
                      • goontron
                        5000!
                        • Dec 2011
                        • 4108
                        • US
                        ^badblocks (linux) just run a data destructive test. how strange, it makes a quantum bigfoot sound like a clock.
                          master hoarder
                          • May 2008
                          • 12175
                          Looks like it might be developing a bad write head or something.
                          I have a 500 GB Seagate with similar issues. Scans fine on a quick scan with HDTune, but not on a normal scan. On a normal scan, it get through about 2 or 3 blocks, marks them as bad in HDD tune, then the HDD drops out and makes the PC freeze.
                          My solution to that was: quick-format and pretend that everything is working fine . I split it into 3 partitions (so that hopefully, if one craps itself badly, I could still use the other two). I tried installing Windows XP on the first and failed 3 times - data would just go corrupt after Windows copied its files. On the second partition, though, I installed successfully. It's not like the second partition is all fine, however. It has the same problems as the first, but just a lot less often. So overall, the HDD is usable. Just not very trustworthy.
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            Looks a lot like a platter issue and I would try to get it to remap, but it will be hard, at least at first.
                            The Maxtor DiamondMax 8s (aka "slimline") appear to have a firmware bug where it fails to remap and/or the SMART reporting a problem when it should.
                            Arc A770 16 GB
                            • blasterboomer
                              • Dec 2013
                              • 135
                              i installed a virtual machine on it (vista as thats the only iso i had) and it worked fine.
                                master hoarder
                                • May 2008
                                • 12175
                                Yeah, just squeeze the last bit of life out of it. When it goes down, you can extract a nice pair of Neodymium magnets at the very least .
                                • blasterboomer
                                  • Dec 2013
                                  • 135
                                  i might even keep the board as a spare for the other drives i have that are the same.. i tried a board swap so i know they are compatible
                                  • chozo4
                                    Nothing Special
                                    • 134
                                    I've dealt with a 350gb drive that showed similar symptoms. What happened is that the drive had overheated due to being in a case that provided next to no airflow to the drive while it was being thrashed by swap activity all the time. As a result it was running slow, would develop hundreds of bad sectors etc. It would run perfect while cold but the moment it ran for more than a minute or so the speeds would drop from about 96mb/sec to ~6mb/sec read and write.
                                    Being as you haven't used the drive in a while the grease inside on the spindle or otherwise may have dried up or other refuse may have somehow worked it's way in through the vent hole.
                                    Even crap caps can be useful... such as blank rounds for prop gunfights.
                                    • cheapie
                                      null
                                      • Jul 2010
                                      • 849
                                      I've had two WD drives die that way. Both of them were Caviar SE 250GB drives. They seemed to just start running way hotter than usual one day. The first one then started making clunking sounds accompanied by a syslog full of messages stating that the "READ DMA EXT" commands that were sent failed. I didn't bother to try to recover any data, I just purchased a new drive and reinstalled the OS. The second one, on the other hand, made clunking noises but was eventually able to read everything. That one had slightly more important data, so I let it cool, then used dd to transfer everything to a new drive. That all worked fine, then once it was all off, I took it apart and made a speaker out of it.
                                      These two things were enough to more or less turn me off from WD. Sure, I hardly ever buy hard drives, but when I do, they're generally Seagate now. I do have one WD drive still in use, but that's just because I haven't bothered to move the data to one of my spare drives yet.
                                      • SteveNielsen
                                        Retired Tech
                                        • Jun 2012
                                        • 2327
                                        Many years ago I bought a new WD 80G drive. It ran hot from day one but it worked fine. I didn't crowd it and kept it ventilated. It never developed any bad sectors or suffered performance hits until the end, but it eventaully get hot enough to die completely and very quickly.
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                                          🛠 Original Issue
                                          The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ugamazing
                                          Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                                          by ugamazing
                                          I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                                          We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                                          12-17-2024, 07:05 PM
                                        • ahmarzo
                                          Acer laptop battery draining issue
                                          by ahmarzo
                                          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                          08-02-2025, 06:39 AM
                                        • elmark
                                          HP 15-cw1002ua strange keyboard issue
                                          by elmark
                                          HP Pavilion 15-CW1002UA
                                          S/N 5CD0251CBC
                                          P/N 7KE54EA
                                          Hello guys!
                                          I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                                          It powers on OK and has no other issues except the following:
                                          • CAPS LOCK does not work at all
                                          • Fn button toggles Flight Mode
                                          • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                                          • (with SHIFT pressed: 't%' and 'y^' respectively)
                                          I initially thought it was a keyboard malfunction (internal short, etc.),
                                          but when I press and hold...
                                          06-27-2025, 01:10 AM
                                        • Simone Vergani
                                          Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                                          by Simone Vergani
                                          I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                                          To assist with troubleshooting, I'm attaching two power circuit schematics:
                                          • Power
                                          03-05-2025, 02:25 PM
