Here we go again. Sorry this issue is similar to a previous problem, but I believe the difficulty here is different. I am installing two identical Hitachi Cinema Star SATA 500 GB hard drives, and things are not going smoothly. These two hard drives were formerly server drives, so I'm told. There was an identical operating system on both drives before I used GParted to delete, restructure partitions and follow up with ext3 format. Several months ago this computer (Dell Dimension 3100, 2.8 GHz P4 w/HT, 1.0 GB DDR ram) was running a 1TB hdd on drive SATA-0 and 500GB hdd on drive SATA-2. [You may recall that I played around with BIOS quite a bit when I was trying (unsuccessfully) to install two identical Seagate 2TB hdd's. Those two large hdd's were installed to another faster computer, leaving this computer without hdd(s).] I ran a live CD of Linux to prepare the computer for a new OS. GParted detected the two drives with no problem, and there were desktop icons representing the partitions. After partitioning with GParted, those icons had changed to represent the new partition structure. I then installed Linux (Slacko 5.5 non-PAE) and legacy GRUB, and rebooted. The computer would not boot, giving the same error that occurred before partitioning. "Error auto-sensing secondary hard disk drive0. Press F1 to retry boot. No boot device available." As far as I know, there is no secondary hard disk drive0 (PATA-0??), and furthermore, this drive is turned OFF in Setup. When I looked at the boot order, whadya know, onboard SATA hard disk not present. I look at drive SATA-0 drive in Drives, the drive is described as "unknown" with no Drive ID. I removed the second SATA hdd at Drive 2, and got the same result when I rebooted with a single hdd at SATA-0, that there was an error auto-sensing secondary hard disk drive0, and also, no boot device present. Any idea what the trouble is?
Possibilities:
1. The used SATA drive(s) is defective.
2. Need to update BIOS
3. GRUB has misnamed hdd devices
I reread my post above, and realize that I have discussed three different situations or circumstances, so take care to read carefully to distinguish between them, and the current problem.
Possibilities:
