Dell Dimension does not see SATA hdd(s)
  • binsonk
    • Apr 2014
    • 182
    Here we go again. Sorry this issue is similar to a previous problem, but I believe the difficulty here is different. I am installing two identical Hitachi Cinema Star SATA 500 GB hard drives, and things are not going smoothly. These two hard drives were formerly server drives, so I'm told. There was an identical operating system on both drives before I used GParted to delete, restructure partitions and follow up with ext3 format. Several months ago this computer (Dell Dimension 3100, 2.8 GHz P4 w/HT, 1.0 GB DDR ram) was running a 1TB hdd on drive SATA-0 and 500GB hdd on drive SATA-2. [You may recall that I played around with BIOS quite a bit when I was trying (unsuccessfully) to install two identical Seagate 2TB hdd's. Those two large hdd's were installed to another faster computer, leaving this computer without hdd(s).] I ran a live CD of Linux to prepare the computer for a new OS. GParted detected the two drives with no problem, and there were desktop icons representing the partitions. After partitioning with GParted, those icons had changed to represent the new partition structure. I then installed Linux (Slacko 5.5 non-PAE) and legacy GRUB, and rebooted. The computer would not boot, giving the same error that occurred before partitioning. "Error auto-sensing secondary hard disk drive0. Press F1 to retry boot. No boot device available." As far as I know, there is no secondary hard disk drive0 (PATA-0??), and furthermore, this drive is turned OFF in Setup. When I looked at the boot order, whadya know, onboard SATA hard disk not present. I look at drive SATA-0 drive in Drives, the drive is described as "unknown" with no Drive ID. I removed the second SATA hdd at Drive 2, and got the same result when I rebooted with a single hdd at SATA-0, that there was an error auto-sensing secondary hard disk drive0, and also, no boot device present. Any idea what the trouble is?
    Possibilities:
    1. The used SATA drive(s) is defective.
    2. Need to update BIOS
    3. GRUB has misnamed hdd devices
    I reread my post above, and realize that I have discussed three different situations or circumstances, so take care to read carefully to distinguish between them, and the current problem.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    Re: Dell Dimension does not see SATA hdd(s)
    I'd bet the hard drives themselves are okay. You either have a BIOS issue with the machine failing to recognize the hard drives for whatever reason, or the Southbridge chip of that mainboard has gone flakey.
    If it's the SB, it's not worth fixing unless you have access to a BGA rework station and have the skills to use it.
    I'd try a smaller SATA drive like a 250 gig to see what gives.
    A working TV? How boring!
      • 31142
      if these are RAID drives you need to get info on any jumper options relating to spinup and timouts.
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        my MOBO wont boot off of PATA drives but a card fixed that, so i say you should push back with something like this: http://www.microcenter.com/product/3...h_RAID_Support
        Follow the white rabbit.
          • 31142
          SATA 1.0 ?
          you must be joking, most modern drives wont drop below SATA 2.0
          • goontron
            5000!
            • Dec 2011
            • 4108
            • US
            Originally posted by stj
            SATA 1.0 ?
            notice how most sata ii/iii are pci-e? i doubt his PC even has pci-e with the age he gave in the other threads. OTOH that could be why the modern drives don't work on the mobo headers, no sata ii/iii.
            if he does have a pci-e port than i suggest this:http://www.microcenter.com/product/4...ontroller_Card
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              SATA drives are fully backwards compatible. Only exception would be if the motherboard is using a VIA VT8237 southbridge in which case it only works with SATAI, due to an internal bug in the chipset.
                • 31142
                not 100% true, some have to be set "down" with a jumper.
                and some sata3 drives cant drop under sata2
                • binsonk
                  • Apr 2014
                  • 182
                  - mobo has a PCIe slot, 36-pin connector
                  - supports RAID 1 (mirroring)
                  - Intel 915GV chipset
                  - no jumpers present on hdd's
                  I would be inclined to say the BIOS needs upgrading, except for the fact that this mobo was running 1 TB and 500 GB drives for several years. I would rather avoid a RAID setup, if only to be consistent with my other computers, which have almost identical partitioning, drive numbers.
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    ^ try the card in post number 6, a RAID setup is optional and it has sata iii.
                    • binsonk
                      • Apr 2014
                      • 182
                      Is a PCI express card, which I don't have, better than a PCI SATA controller card, which I have? I would rather set up the drives on original equipment, on the mobo's provided SATA ports, and I don't see any great roadblock to doing so. I have accidentally set up a RAID using the PCI SATA controller card; it's possible, but not desired. As stated above, I would like to avoid a RAID setup. The two Hitachi drives are rated 3 Gb/s.
                      • ratdude747
                        Black Sheep
                        • Nov 2008
                        • 17136
                        IMHO the card is more to diagnose the fault, not as permanent solution.
                        sigpic
                        (Insert witty quote here)
                        • binsonk
                          • Apr 2014
                          • 182
                          I installed a 40 gig SATA hdd at drive SATA-0, and the computer booted up fine in WinXP. I then connected the same hdd at SATA-2, and after disabling SATA-0 in BIOS, the hdd booted to WinXP desktop without a hitch. So the mobo SATA ports and connectors are working good.
                          • Towncivilian
                            • Jul 2014
                            • 22
                            • US
                            Perhaps try updating the BIOS regardless? There may be a newer AHCI option ROM in the latest BIOS that may improve compatibility. Failing that, try forcing the drives to operate at SATA 1.5gbps speeds, if possible.
                            ASUS P8Z77-V LK, i7-3790, 32GB DDR3-1600, GTX 750 Ti, 256GB 840 Pro & 2x1TB / 1x2TB, Creative SoundBlaster ZxR, FSP Aurum S 400W
                            abit IP35 Pro, Q9300, 16GB DDR2-800, GTX 750 Ti, 128GB 840 Pro & 1TB WD Blue, Corsair CX430
                            HP d530 CMT, P4 EE 3.2ghz (with modded BIOS for correct microcode), 4GB DDR-400, ATI 9600XT, X-Fi, 80GB Velociraptor, 500GB WD Blue, XP SP3, Sony SDT-9000 & Seagate CTD-8000 DAT drive for ripping audio DATs
                            abit BX133-RAID (recapped + SMD caps installed in processor socket), PIII-S 1.4ghz Tualatin, 768MB PC133, FX5600, SoundBlaster AWE32, 40GB Deskstar, Windows 98SE
                            Depeche Mode Live Wiki
                            • binsonk
                              • Apr 2014
                              • 182
                              I updated the BIOS from A03 to A04, but there was no improvement. It would be nice if I could get BIOS to manually detect the hdd's, but I see no way to accomplish that task with this BIOS. Most setups for IDE drives allow a manual detection, but I don't find that functionality for this SATA setup.
                              The error I get when both drives are connected is
                              The error I get when I disconnect (and disable in BIOS) the first hdd at SATA-2 with OS is
                              Error auto-sensing secondary hard disk drive1
                              So BIOS is calling the hdd at SATA-0 "secondary hard disk drive0", and calling the hdd at SATA-2 "secondary hard disk drive1"
                              And both hdd's, installed separately, are producing the same auto-sensing error.
                              It's possible that these drives were taken out of a DVR.
                              • binsonk
                                • Apr 2014
                                • 182
                                Originally posted by Towncivilian
                                ...try forcing the drives to operate at SATA 1.5gbps speeds, if possible.
                                How would I do this exactly. I can't find jumper settings for this drive.
                                EDIT: There was only one jumper position. I jumpered it. No improvement.
                                  • 31142
                                  get the datasheet / info on the drives.
                                  raid drives otfen use different firmware similar to scsi drives.
                                  they wont spinup without a command, and they wont retry errors constantly - just report the problem to the controller.
                                  you see this over at WD's site, where they explaine the firmware differences between the RED and BLACK series drives.
                                  • binsonk
                                    • Apr 2014
                                    • 182
                                    Hitachi CinemaStar 500GB P/N 0A37097 Model HCP725050GLA380 Sata 3.0 7200 RPM
                                    from post at AnandTech forum:
                                    "I have a couple of hard drives that came out of DVR's that I was going to use in my computer but they either don't get recognized or windows can't be installed on the drive. I am not a advanced computer guy, I can follow basic instructions and put a computer together but most technical talk goes over my head quickly. During POST I get hard drive error or no drives found. Any help would be appreciated, are there jumpers or utilities to try and make these work?"
                                    http://forums.anandtech.com/showthread.php?t=2080953
                                    IMO, it's more likely these drives came out of DVR devices. Notice the name of the hard drive: Hitachi Cinema Star. Cinema = movies = DVR. Not sure if it means anything, but the same OS (spread across 5 partitions) was on both drives, so the drives probably operated as singles (in two DVRs), rather than a RAID.
                                    I really need to get my money back today, if these drives are not going to work.
                                    • binsonk
                                      • Apr 2014
                                      • 182
                                      The hdd's may be AV drives, which may not spin up during boot. This calls for the use of Linux command hdparm to change drive parameters.
                                      http://en.wikipedia.org/wiki/Hdparm
                                      I might be able to edit the firmware with Hitachi disk tools. Hitachi was bought by Western Digital.
                                        • 31142
                                        OR, if they are from security DVR's and not home settop-boxes, they may have the password set!
                                        if you connect one to a running linux box, can you mount and browse the content?
                                        incidentally, AV drives arent very good for data use.
                                        they are optimised for streaming rather than long life / low error rate.
                                        this is also explained at the WD site with differences between the GREEN, and AV-GREEN firmware.
                                        • eccerr0r
                                          failing hard drives after sitting for years...
                                          by eccerr0r
                                          With the discussion about water pumps failing when cars sit for a while, I wonder what people have seen with hard drives. Do people see hard drives failing after being sat on the shelf for a long time unpowered versus a hard drive that's at least powered up at least once in a while, say, weekly?
                                          Wonder if it's worth spinning up the spare spinners once in a while to keep the bearings lubricated?
                                          Wonder how I should best keep my cold spares for my RAID "fresh" for eventual failures of the working drives. Was thinking about keeping a hot spare but that's another...
                                          03-02-2023, 10:33 AM
                                        • abajor
                                          Evaluating Mechanical Hard Drives SMART Data in Linux (Ubuntu) Using the Disks Utility.
                                          by abajor
                                          I've gotten into the habit of Looking at peoples Mechanical Hard drives with a Ubuntu thumb drive to boot their system.
                                          I understand the raw values are not really uniform between manufacturers, but I have noticed that high seek and read error raw values at the very least correlate to a drive that is going to have sub par access time, and extremely slow OS booting.
                                          The odd thing is I've often seen very high seek and read error rates on drives with fairly low on time.
                                          Does anybody have any other takes on evaluating smart data? I've used Crystal Disk Info, It seems to present...
                                          04-23-2024, 11:43 PM
                                        • federalhouse
                                          **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                                          by federalhouse
                                          I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                                          **Background:**
                                          I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                                          **What I've Tried So Far:**
                                          1. I accessed
                                          08-01-2024, 07:03 PM
                                        • ChaosLegionnaire
                                          what to do with faulty hard drives?
                                          by ChaosLegionnaire
                                          i have several dead/bricked (not detected, doesnt show up or making constant clicks of death) and faulty bad sector hard drives. im moving house soon and need to get rid of some dead weight.
                                          i thought of selling them for parts or not working but they are quite heavy and shipping each drive internationally via local post is US$23 each. im using some of the drives as gym strength training dumbells by putting 4 of them in a box to make a 3kg dumbell. but since im moving i cant carry the deadweight with me. any ideas what to do with them that is cost-effective for ppl like me...
                                          11-25-2021, 02:42 AM
                                        • DynaxSC
                                          GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                          by DynaxSC
                                          I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                          There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                          The board is generally working now, all PCIe ports are working, Windows installs normally.
                                          However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                          The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                          03-10-2025, 12:27 PM
