HP Recalls Notebook Computer AC Power Cords Due to Fire Hazards
    • 31087
    http://www.cpsc.gov/en/Recalls/2014/...C-Power-Cords/
  • SteveNielsen
    Retired Tech
    • Jun 2012
    • 2327
    Re: read this.
    Thanks for the alert. I have an HP mini but not the affected AC cord.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Re: read this.
      Mine did the that. Dell chargers are so much better.
      Follow the white rabbit.
        master hoarder
        • May 2008
        • 12175
        Re: read this.
        I would be highly surprised if HP used only one manufacturer for these power cords. Most are probably okay, but a few from a specific manufacturer are likely affected. Too bad they don't give more details which particular manufacturer is the problematic one (or if they just gave out the UL number, that would definitely help).
        Thanks for sharing, though. My sister does have an HP laptop that she bought back around 2010 I think (or possibly 2009, but I'm not sure), and her adapter has stopped working too. I wonder if this is the culprit or just the usual shorted/open output wires near the DC plug.
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          Re: read this.
          I just sent a HP brick of that era to mad professor... luckily I didn't ship it with the orginal AC cord (but a different one out of the pile). IIRC I never received the original AC cord (as it was a $1 GW score).
          Yet another reason why HP = (as does lenovo but that's neither here nor there)
          sigpic
          (Insert witty quote here)
          • binsonk
            • Apr 2014
            • 182
            Re: read this.
            I just purchased a HP dv5000 for under $20. The power adapter runs really hot: it would be uncomfortable to hold it in your hand. The power cord has the "mickey mouse" termination on one end, but the cable is round, not flat. Is the recall only for the mickey mouse flat cord?
            • mariushm
              • May 2011
              • 3799
              Re: read this.
              Awesome title. I'm sure EVERYBODY's going to read this thread just because you said so.
              Anyway.. for anyone that is too lazy to actually read the link, it's ONLY FOR CABLE, and only for the one with text LS-15 on it.
              Just buy a new power cord off Amazon or Newegg or some local store instead of wasting money on postage and waiting for HP to give you another cable.
              • Th3_uN1Qu3
                Believe in
                • Jul 2010
                • 6031
                Re: read this.
                I have several cords with that text on them and they've been fine for years. Must be confined to a particular lot.
                OTOH I did have random crap Chinese cords spew flames at the end that plugs in the charger. Cheap insulation got ripped due to regular wear and tear and the cord shorted out.
                A working TV? How boring!
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  Re: HP Recalls Notebook Computer AC Power Cords Due to Fire Hazards
                  Fixed the retarded thread title.
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                    master hoarder
                    • May 2008
                    • 12175
                    Re: read this.
                    I discourage anyone from purchasing cheap generic AC cords. They almost always either develop bad contacts in the plug (where the cord connects to the adapter) or the fragile wire rips near the AC plug (and usually either shorts or opens). Really, some are so crappy that you might as well take some phone wire and make your own. Probably equally unsafe anyways.
                      • 31087
                      i liked it.
                      besides, it seems to have worked.
                      • trebo
                        • 514
                        • Wales, UK
                        that it did alright
                        • ben7
                          Capaholic
                          • Jan 2011
                          • 4059
                          Hm, I have an HP computer with HP power adapter.
                          Cord is different than the recall, as it says:
                          I-SHENG
                          I3-034
                          The other side:
                          E55943
                          7A 125V
                          My cord looks SOOO much better quality wise than the one they have pics of.
                          Adapter is made by Delta
                          Muh-soggy-knee
                          • japlytic
                            • Oct 2005
                            • 2086
                            I had a mains lead from a Toshiba notebook AC adaptor which tripped the earth leakage - resistance tests on the lead not connected to anything else revealed a low enough resistance between Live and Earth, but the AC adaptor was OK.
                            Could undersized wiring have something to do with this and the HP recall?
                              • 31087
                              more likely, the problem is because most cables are spot-welded to the pins.
                              sometimes the spot is off-center or the strands break.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                I think I have a bunch of these "LS-15" cords, some are from my employer. Anyone know where the failure takes place (which connector end)? To me, these LS-15 cords don't look that bad, I wouldn't be able to tell a good one from a bad one.
                                I think HP is only replacing one per purchased serial numbered power brick so I can't box up all of them and get a replacement...
                                I thought most HP power bricks are made by Delta, HP tends to use them a lot for power supplies.
                                • goontron
                                  5000!
                                  • Dec 2011
                                  • 4108
                                  • US
                                  if one of us could get one up to Littleton i could put it through its paces. otherwise mine failed at the part that goes into the charger brick, hence why my HP now uses a Dell charger.
                                  • ben7
                                    Capaholic
                                    • Jan 2011
                                    • 4059
                                    I think so too, but it is likely that Delta doesn't make the cords. I think they only make the power supply itself. They might assemble the cord part that goes into the computer though (not the wall plug part.)
                                    Muh-soggy-knee
                                    • goontron
                                      5000!
                                      • Dec 2011
                                      • 4108
                                      • US
                                      i remember seeing the name "Longwell"
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        I actually broke the low voltage end of my laptop's power brick (ultrabook, cracked the plastic) and it's intermittent now. So I don't even use that power brick - I use an aftermarket power brick. It (the Targus branded brick)'s smaller but doesn't have a ground unlike the original.
                                        I need to find another connector to fix my OEM power brick, but sneaky HP made it such that standard coaxial plugs from rat shak would plug into the hole but the handle would hit against the side of the laptop, so it won't go in... GRR.
                                        Speaking of the "cloverleaf" or "mickey mouse" power connectors, these should be fairly common and standardized (looks like an IEC standard), I wonder how they screwed up making them...
                                        Then again even the more common rectangular-trapezoidal ones also occasionally has issues...
                                          HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook 400 Specification for Upgrade or Repair
                                          This specification for the HP ProBook HP ProBook 450 15.6 inch G10 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the HP ProBook 450 15.6 inch G10 Notebook PC boardview and HP ProBook 450 15.6 inch G10 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-07-2024, 07:12 AM
                                          09-07-2024, 06:40 AM
                                          HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                          This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                          09-07-2024, 05:50 AM
                                          HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                          This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
